BSOD caused by ntoskrnl.exe and hal.dll, need help!!
imcylee
2
Hi All,
I upgraded my PC from win8 to win8.1 and i get BSOD very frequently. Tried to solve it by update all drivers, but it doesn't helps.
I ran memory diagnostic before, it show no errors. Please advice.:cry:
Attached with my dump files.
Thanks in advance
lifetec
660
[FONT=Courier New][SIZE=3][COLOR=#000000]Use !analyze -v to get detailed debugging information.[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]BugCheck A, {901d503, d, 1, fffff801ed4bd23f}[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]Probably caused by : hardware ( nt!KeClockInterruptNotify+34f )[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]Followup: MachineOwner
---------[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]6: kd> !analyze -v
*******************************************************************************[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high.  This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: 000000000901d503, memory referenced
Arg2: 000000000000000d, IRQL
Arg3: 0000000000000001, bitfield :
 bit 0 : value 0 = read operation, 1 = write operation
 bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: fffff801ed4bd23f, address which referenced memory[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]Debugging Details:
------------------[/COLOR][/SIZE][/FONT]
WRITE_ADDRESS: GetPointerFromAddress: unable to read from fffff801ed75d138
unable to get nt!MmNonPagedPoolStart
unable to get nt!MmSizeOfNonPagedPoolInBytes
 000000000901d503 [/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]CURRENT_IRQL:  d[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]FAULTING_IP:
fffff801`ed4bd23f 0000            add     byte ptr [rax],al[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]CUSTOMER_CRASH_COUNT:  1[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]DEFAULT_BUCKET_ID:  WIN8_DRIVER_FAULT[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]BUGCHECK_STR:  AV[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]PROCESS_NAME:  System[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]ANALYSIS_VERSION: 6.3.9600.16384 (debuggers(dbg).130821-1623) amd64fre[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]TRAP_FRAME:  ffffd000b99b8ba0 -- (.trap 0xffffd000b99b8ba0)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=000000000901d503 rbx=0000000000000000 rcx=0000000000000015
rdx=0000000000002930 rsi=0000000000000000 rdi=0000000000000000
rip=fffff801ed4bd23f rsp=ffffd000b99b8d30 rbp=01cf63690c220989
 r8=0000000000148e25  r9=000000010940ff85 r10=0000000000200000
r11=0000000000000015 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0         nv up di pl nz na po nc
nt!KeClockInterruptNotify+0x34f:
fffff801`ed4bd23f 0000            add     byte ptr [rax],al ds:00000000`0901d503=??
Resetting default scope[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]MISALIGNED_IP:
[FONT=Courier New][SIZE=3][COLOR=#000000]LAST_CONTROL_TRANSFER:  from fffff801ed568ae9 to fffff801ed55cfa0[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]STACK_TEXT:
ffffd000`b99b8a58 fffff801`ed568ae9 : 00000000`0000000a 00000000`0901d503 00000000`0000000d 00000000`00000001 : nt!KeBugCheckEx
ffffd000`b99b8a60 fffff801`ed56733a : 00000000`00000001 00000000`00000000 00000718`143ab000 ffffd000`b99b8ba0 : nt!KiBugCheckDispatch+0x69
ffffd000`b99b8ba0 fffff801`ed4bd23f : 00000000`00000000 00000000`00328c12 00000000`00000001 00000000`00000000 : nt!KiPageFault+0x23a
ffffd000`b99b8d30 fffff801`edb9a67f : fffff801`ed409000 fffff801`ed4f3426 ffffe001`05a017b0 fffff801`ed409000 : nt!KeClockInterruptNotify+0x34f
ffffd000`b99b8f40 fffff801`ed4d8363 : ffffe001`05a01700 fffff801`ed51073b ffff1ce7`0acb1412 00000000`00000000 : hal!HalpTimerClockInterrupt+0x4f
ffffd000`b99b8f70 fffff801`ed55e42a : ffffe001`05a01700 ffffe001`0c19a880 00000000`00000000 ffffe001`0588a900 : nt!KiCallInterruptServiceRoutine+0xa3
ffffd000`b99b8fb0 fffff801`ed55e80f : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiInterruptSubDispatchNoLockNoEtw+0xea
ffffd000`b99aaad0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiInterruptDispatchLBControl+0x11f[/COLOR][/SIZE][/FONT]
STACK_COMMAND:  kb[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]FOLLOWUP_IP:
[FONT=Courier New][SIZE=3][COLOR=#000000]SYMBOL_STACK_INDEX:  3[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]SYMBOL_NAME:  nt!KeClockInterruptNotify+34f[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]FOLLOWUP_NAME:  MachineOwner[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]IMAGE_NAME:  hardware[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]DEBUG_FLR_IMAGE_TIMESTAMP:  0[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]IMAGE_VERSION:  6.3.9600.17041[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]MODULE_NAME: hardware[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]FAILURE_BUCKET_ID:  IP_MISALIGNED[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]BUCKET_ID:  IP_MISALIGNED[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]ANALYSIS_SOURCE:  KM[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]FAILURE_ID_HASH_STRING:  km:ip_misaligned[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]FAILURE_ID_HASH:  {201b0e5d-db2a-63d2-77be-8ce8ff234750}[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]BugCheck 133, {0, 501, 500, 0}[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+2f626 )[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]4: kd> !analyze -v
[FONT=Courier New][SIZE=3][COLOR=#000000]DPC_WATCHDOG_VIOLATION (133)
The DPC watchdog detected a prolonged run time at an IRQL of DISPATCH_LEVEL
or above.
Arguments:
Arg1: 0000000000000000, A single DPC or ISR exceeded its time allotment. The offending
 component can usually be identified with a stack trace.
Arg2: 0000000000000501, The DPC time count (in ticks).
Arg3: 0000000000000500, The DPC time allotment (in ticks).
Arg4: 0000000000000000[/COLOR][/SIZE][/FONT]
DPC_TIMEOUT_TYPE:  SINGLE_DPC_TIMEOUT_EXCEEDED[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]BUGCHECK_STR:  0x133[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]TRAP_FRAME:  ffffd0017f4b8b60 -- (.trap 0xffffd0017f4b8b60)
rax=0000000000010936 rbx=0000000000000000 rcx=ffffe001fe4712b8
rdx=ffffe001fe4711a0 rsi=0000000000000000 rdi=0000000000000000
rip=fffff8018a2c53a0 rsp=ffffd0017f4b8cf8 rbp=ffffd0017f4b8e00
 r8=00000000b5d51421  r9=0000000001cf62ae r10=fffff802cc968f80
r11=ffffe001f9005760 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei ng nz na po nc
ndis!ndisMWakeUpDpcX:
fffff801`8a2c53a0 488bc4          mov     rax,rsp
[FONT=Courier New][SIZE=3][COLOR=#000000]LAST_CONTROL_TRANSFER:  from fffff802cc813ad6 to fffff802cc7d3fa0[/COLOR][/SIZE][/FONT]
ffffd001`7f4bfc98 fffff802`cc813ad6 : 00000000`00000133 00000000`00000000 00000000`00000501 00000000`00000500 : nt!KeBugCheckEx
ffffd001`7f4bfca0 fffff802`cc734678 : 00000000`00000000 00000000`00000000 00000000`00000001 00000000`00000000 : nt! ?? ::FNODOBFM::`string'+0x2f626
ffffd001`7f4bfd30 fffff802`cc61867f : 00000000`000000ff 00000000`c1597bdf ffffe001`f8a00db0 fffff802`00000000 : nt!KeClockInterruptNotify+0x788
ffffd001`7f4bff40 fffff802`cc74f363 : ffffe001`f8a00d00 fffff802`cc78773b ffff2632`f389ebda 00000000`00000000 : hal!HalpTimerClockInterrupt+0x4f
ffffd001`7f4bff70 fffff802`cc7d542a : ffffe001`f8a00d00 ffffd001`7f487180 00000000`0000002c ffffe001`fe4712b8 : nt!KiCallInterruptServiceRoutine+0xa3
ffffd001`7f4bffb0 fffff802`cc7d580f : ffffd001`7f4b89e0 fffff802`cc7a5f9e 00000000`00000000 00001f80`004b0280 : nt!KiInterruptSubDispatchNoLockNoEtw+0xea
ffffd001`7f4b89d0 fffff802`cc7de1f3 : 00000000`00000008 ffffd001`7f4b8e60 fffffff6`00000000 ffffd001`7f4b8b60 : nt!KiInterruptDispatchLBControl+0x11f
ffffd001`7f4b8b60 fffff801`8a2c53a0 : fffff802`cc6d9810 00000000`00000000 ffffd001`7f4b8e00 ffffe001`fe471278 : nt!KiPageFault+0xf3
ffffd001`7f4b8cf8 fffff802`cc6d9810 : 00000000`00000000 ffffd001`7f4b8e00 ffffe001`fe471278 ffffd001`7f480f45 : ndis!ndisMWakeUpDpcX
ffffd001`7f4b8d00 fffff802`cc7d70d5 : 00000000`00000000 ffffd001`7f487180 ffffe001`f8a00d00 ffffe001`f888a900 : nt!KiRetireDpcList+0x4f0
ffffd001`7f4b8fb0 fffff802`cc7d6ed9 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxRetireDpcList+0x5
ffffd000`2666b7e0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiDispatchInterruptContinue[/COLOR][/SIZE][/FONT]
fffff802`cc813ad6 cc              int     3[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]SYMBOL_STACK_INDEX:  1[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]SYMBOL_NAME:  nt! ?? ::FNODOBFM::`string'+2f626[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]MODULE_NAME: nt[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]IMAGE_NAME:  ntkrnlmp.exe[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]DEBUG_FLR_IMAGE_TIMESTAMP:  5318053f[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]BUCKET_ID_FUNC_OFFSET:  2f626[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]FAILURE_BUCKET_ID:  0x133_DPC_nt!_??_::FNODOBFM::_string_[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]BUCKET_ID:  0x133_DPC_nt!_??_::FNODOBFM::_string_[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]FAILURE_ID_HASH_STRING:  km:0x133_dpc_nt!_??_::fnodobfm::_string_[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]FAILURE_ID_HASH:  {12e2b1b6-39a2-9cfe-dc70-25086917b8e2}[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]BugCheck A, {0, 2, 1, fffff8031e15c180}[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]*** WARNING: Unable to verify timestamp for win32k.sys
*** ERROR: Module load completed but symbols could not be loaded for win32k.sys
Probably caused by : hardware ( nt!KiInitialPCR+180 )[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]0: kd> !analyze -v
Arguments:
Arg1: 0000000000000000, memory referenced
Arg2: 0000000000000002, IRQL
Arg4: fffff8031e15c180, address which referenced memory[/COLOR][/SIZE][/FONT]
WRITE_ADDRESS: GetPointerFromAddress: unable to read from fffff8031e1ca138
 0000000000000000 [/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]CURRENT_IRQL:  2[/COLOR][/SIZE][/FONT]
nt!KiInitialPCR+180
fffff803`1e15c180 801f00          sbb     byte ptr [rdi],0[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]DPC_STACK_BASE:  FFFFF8031F7D7FB0[/COLOR][/SIZE][/FONT]
[FONT=Courier New][SIZE=3][COLOR=#000000]TRAP_FRAME:  fffff8031f7d0ae0 -- (.trap 0xfffff8031f7d0ae0)
rax=0000000000000001 rbx=0000000000000000 rcx=253a468272460000
rdx=000003de00000000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff8031e15c180 rsp=fffff8031f7d0c70 rbp=fffff8031e15c180
 r8=0000000000000000  r9=0000000000400a02 r10=0000000000000002
r11=fffff8031f7d0c40 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up di pl zr na po nc
nt!KiInitialPCR+0x180:
fffff803`1e15c180 801f00          sbb     byte ptr [rdi],0 ds:00000000`00000000=??
nt!KiInitialPCR+180
[FONT=Courier New][SIZE=3][COLOR=#000000]LAST_CONTROL_TRANSFER:  from fffff8031dfd5ae9 to fffff8031dfc9fa0[/COLOR][/SIZE][/FONT]
fffff803`1f7d0998 fffff803`1dfd5ae9 : 00000000`0000000a 00000000`00000000 00000000`00000002 00000000`00000001 : nt!KeBugCheckEx
fffff803`1f7d09a0 fffff803`1dfd433a : 00000000`00000001 ffffe000`92452880 ffffe000`00000000 fffff803`1f7d0ae0 : nt!KiBugCheckDispatch+0x69
fffff803`1f7d0ae0 fffff803`1e15c180 : fffff803`1e1c3a00 ffffe000`92452880 00000000`00000000 00000000`00000000 : nt!KiPageFault+0x23a
fffff803`1f7d0c70 fffff803`1e1c3a00 : ffffe000`92452880 00000000`00000000 00000000`00000000 fffff803`1f7d1000 : nt!KiInitialPCR+0x180
fffff803`1f7d0c78 ffffe000`92452880 : 00000000`00000000 00000000`00000000 fffff803`1f7d1000 fffff803`1f7cb000 : nt!KiInitialThread
fffff803`1f7d0c80 00000000`00000000 : 00000000`00000000 fffff803`1f7d1000 fffff803`1f7cb000 00000000`00000000 : 0xffffe000`92452880[/COLOR][/SIZE][/FONT]
nt!KiInitialPCR+180
[FONT=Courier New][SIZE=3][COLOR=#000000]SYMBOL_NAME:  nt!KiInitialPCR+180[/COLOR][/SIZE][/FONT]
Analyse based on canned speech of John carrona:
Out of the last 18 memory dumps there were 11 different BSOD error codes. The differing error codesare usually symptomatic of a lower level problem within the system. They areusually caused by one of these things:
- borked (broken) hardware (several different procedures used to isolate theproblem device)
- BIOS issues (check for updates at the motherboard manufacturer's website)
- overclocking/overheating - You'll know if you're overclocking or not. Ifuncertain we can suggest things to check.
- compatibility issues (3rd party hardware/drivers)
- low-level driver problems
- or even malware (scanned for when we ask for hardware diagnostics from
Initial Hardware Diagnostics or Hardware Diagnostics ).
You can get ahead start on the hardware diagnostics if you'd like - they are located here: Hardware Diagnostics .
But i suspect that it is hardware related, the latest dumpfile even mentioned Probably caused by : hardware ( nt!KeClockInterruptNotify+34f ), 2 other dumpfiles mentioned HAL.dll.
If your system is still under warranty, I would recommend contacting your supplier and sending it in to have diagnostic tests done and have any bad hardware replaced.
    windows 8.1
    self build
    Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz
    Asrock P55 Pro
    DDR3 Team--Elite-1333 8 gb
    Sapphire R9 280x
    Realtek Alc 855
    Acer V233H
    1920 x 1020
    Samsung evo 850 SSd
    Seagate ST 320 gb
    Samsung HD 750 gb
    Seagate ST 3000gb
    OCZ Stealth 600 watt
    Antec 300
    Speedlink Ledos and Nexus
imcylee
2
thanks lifetec, this pc bought from Dell, I called them before.
They ask me to run their own hardware diagnostic tool, But can't found any errors/faulty hardware.
So I can't claim warranty from them.
I tried to update my drivers and BIOS over and over again. It doesn't helps as well.:(
lifetec
660
To exclude other possibilities than faulty hardware, please update the older drivers, see below, on your system.
You are using Trend Micro Internet security please check if you have the latest windows 8.1 compatible version.
If the BSOD's continue after updating.
You could run the Hardware Diagnostics and see if this test find any faulty hardware.
But i would first contact Dell again because you still have warranty and mention that the analyses of your BSOD's names probably caused by Hardware and Hal.dll. ( reference this thread, send them the SF.zip).
Note: first check the support/driver downloadsite of your OEM model or system for the latest windows 8.1 drivers.
lvrs64 fffff801`add20000 fffff801`add74000 Tue Oct 23 04:11:24 2012 (5085fccc) 00058cf8 lvrs64.sys
lvuvc64 fffff801`ad87a000 fffff801`add01d80 Tue Oct 23 04:12:08 2012 (5085fcf8) 004912c7 lvuvc64.sys
Driver Description: Logitech Camera driver
Driver Description: Logitech USB Video Class Driver (WebCam)
Driver Update Site: Logitech Support - Downloads, Manuals, FAQs & More
btath_lwflt fffff801`ad861000 fffff801`ad879000 Fri Nov 02 06:35:44 2012 (50935bb0) 000209c1 btath_lwflt.sys
btath_hcrp fffff801`acbb1000 fffff801`acbfd000 Tue Dec 18 10:54:54 2012 (50d03d6e) 0002e794 btath_hcrp.sys
btath_bus fffff801`ad130000 fffff801`ad13d000 Mon Jan 21 10:18:42 2013 (50fd07f2) 00011722 btath_bus.sys
btath_flt fffff801`abc6f000 fffff801`abc8b000 Thu May 23 08:10:29 2013 (519db2d5) 00020379 btath_flt.sys
btath_rcp fffff801`ad285000 fffff801`ad2d1000 Fri Jun 21 11:11:54 2013 (51c418da) 0003154d btath_rcp.sys
btath_avdt fffff801`acc39000 fffff801`acc64000 Thu Jul 25 12:10:29 2013 (51f0f995) 0002226f btath_avdt.sys
btath_a2dp fffff801`aca78000 fffff801`acae0000 Thu Jul 25 12:11:51 2013 (51f0f9e7) 00053de8 btath_a2dp.sys
Driver Description: Atheros Bluetooth Driver
Driver Update Site: ATHEROS drivers for Microsoft Windows (Atheros?????) or ATHEROS drivers for Microsoft Windows (Atheros?????)
HECIx64 fffff801`ac985000 fffff801`ac998000 Mon Dec 17 20:32:21 2012 (50cf7345) 0001803d HECIx64.sys
Driver Description: Intel Management Engine Interface
Driver Update Site: http://downloadcenter.intel.com/Default.aspx
btmaux fffff801`ac9b0000 fffff801`ac9d5000 Tue Apr 23 13:28:02 2013 (51767042) 00025885 btmaux.sys
Driver Description: Intel Bluetooth Auxiliary Service
Driver Update Site: http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword;="bluetooth"
RTKVHD64 fffff801`ad2d2000 fffff801`ad611900 Tue May 14 15:45:12 2013 (51923fe8) 003461db RTKVHD64.sys
Driver Description: Realtek High Definition Audio Function Driver
Driver Update Site: Realtek
athwbx fffff801`acc73000 fffff801`ad028000 Mon Jul 15 09:29:50 2013 (51e3a4ee) 003a9587 athwbx.sys
Driver Description: Qualcomm Atheros AR9485WB-EG Wireless Network Adapter (Version: 10.0.0.274 is the first one after the release of Win8.1)
Although I do not recommend drivers from places other than the manufacturer's website - this is the exception to that rule. Please scan with an anti-virus before opening any file that you download from the internet.
Driver Update Site: Drivers for Atheros AR9485WB and Windows 8 (OEM drivers appear to be a version behind this one for Win8.1)
VSApiNt fffff801`ae0eb000 fffff801`ae316000 Wed Aug 14 09:16:40 2013 (520b2ed8) 00230036 VSApiNt.sys
TmPreFlt fffff801`ac9eb000 fffff801`ac9fa000 Wed Aug 14 09:27:38 2013 (520b316a) 000135e7 TmPreFlt.sys
TmXPFlt fffff801`ae316000 fffff801`ae37c000 Wed Aug 14 09:27:40 2013 (520b316c) 0005c5a8 TmXPFlt.sys
Driver Description: Trend Micro Internet Security
Driver Update Site: Free Security Software Trials - Software Downloads - Trend Micro USA
    windows 8.1
    self build
    Asrock P55 Pro
    Sapphire R9 280x
    Realtek Alc 855
    Acer V233H
    1920 x 1020
    Samsung evo 850 SSd
    Seagate ST 320 gb
    Samsung HD 750 gb
    Seagate ST 3000gb
    Antec 300
