Solved BSOD again after a few months...
CK1985NL
161
For a while I had no trace of BSOD (since 30 July). After a while (few months) it occurs again, today for four times I get BSOD. I made a rar file of the minidump files. I think maybe the problem is the video card, but I don't know for sure, please help somebody, blueelvis, I hope you can help me again. Thanks all for now.
    Windows 10 Pro 64Bit
    AMD FX-8150 Black Edition, sAM3+ 3.60 GHz, Octa-Core, 16MB, 125W
    Asus Sabertooth 990FX AM3+
    Corsair Vengeance 32GB DDR3 kit (4x 8GB), CMZ32GX3M4X1866C10'
    EVGA GTX 970 Superclocked ACX 2.0
    Philips 32"PFL9606H/12
    Samsung 850 Pro series 1 TB
softwaremaniac
2,480
    Windows 10 Pro x64
    INTEL Core i7-2700K 3.5GHz
    ASROCK Fatal1ty P67 Main Board
    HyperX Blu 8GB (2 x 4GB) DDR3 1600
    Gigabyte GTX 980 Ti G1 Gaming
    On-board
    Philips Brilliance BDM4065UC
    3840x2160
    SSD: Samsung EVO 250 GB
    Internal HDD: WD Black 1TB
    External: 2x2TB MyBook drives
    1x4TB MyBook
    1x1TB Seagate Freeagent drive
    Corsair GS 700W
    Silverstone Kublai KL04
    Artic Cooling Freezer Pro
    Logitech G710+
    Razer Mamba Elite 2012
    FF 39.0.3, Microsoft Edge, Chrome 44
    Avast 10.0
CK1985NL
161
I think I've tried 1st step once. I will try 2nd step and I'll let you know.
CK1985NL
161
@ softwaremaniac
I've tried the 2nd step all steps in it, but it won't work. So I tried my own step, I deleted my older version driver (14.7) with DDU (display driver uninstaller) and I installed the newest driver of amd (14.9). I will try a few days and look of BSOD still occurs, I'll let you know.
softwaremaniac
2,480
That could help to as the new version of the problematic driver is now installed. Please report back if the BSOD occurs again.
    Windows 10 Pro x64
    On-board
    3840x2160
    1x4TB MyBook
    Corsair GS 700W
    Logitech G710+
    Avast 10.0
CK1985NL
161
Oké, thanks! I'll let you know...
blueelvis
OMG Debugger!
India
2,097
Dang CK1985NL :p
You are having too many issues. Earlier it was the Creative Headset if I remember correctly, then the USB Thing and now this...
Don't worry, we got you covered ^_^
    Windows 8.1 Industry Pro B-)
    Toshiba
    Core I5 2430M @ 2.4GHz
    Intel HD 3000 B-)
    1366x768
    Toshiba 500 GB
CK1985NL
161
#8
Hi all.
I got a BSOD again, this time not during gaming, but watching a program on internet on google chrome. I made a rar file of the minidump. What I'm asking myself is, my brother has a videocard from nvidia and he has no problems of BSOD, but I've a videocard from AMD and BSOD occurs a lot of time, so my question is should I choose for an Nvidia Geforce videocard the next time or doesn't that matter. Please help.
softwaremaniac
2,480
#9
BugCheck D1, {bdbc83f0, 2, 1, fffff8015b94f2d7}
*** [COLOR=#ff0000]WARNING: Unable to verify timestamp for Rt630x64.sys
*** ERROR: Module load completed but symbols could not be loaded for Rt630x64.sys
*** WARNING: Unable to verify timestamp for win32k.sys
*** ERROR: Module load completed but symbols could not be loaded for win32k.sys[/COLOR]
Probably caused by : memory_corruption
Followup: memory_corruption
2: kd> !analyze -v
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high.  This is usually
caused by drivers using improper addresses.
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: 00000000bdbc83f0, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000001, value 0 = read operation, 1 = write operation
Arg4: fffff8015b94f2d7, address which referenced memory
Debugging Details:
WRITE_ADDRESS: GetPointerFromAddress: unable to read from fffff80277170138
unable to get nt!MmNonPagedPoolStart
unable to get nt!MmSizeOfNonPagedPoolInBytes
 00000000bdbc83f0
CURRENT_IRQL:  2
FAULTING_IP:
wfplwfs!memset+d7
fffff801`5b94f2d7 48895130        mov     qword ptr [rcx+30h],rdx
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  CODE_CORRUPTION
BUGCHECK_STR:  AV
PROCESS_NAME:  System
ANALYSIS_VERSION: 6.3.9600.17237 (debuggers(dbg).140716-0327) amd64fre
TRAP_FRAME:  ffffd000bdbc81d0 -- (.trap 0xffffd000bdbc81d0)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=00000000bdbc83f0 rbx=0000000000000000 rcx=00000000bdbc83c0
rdx=0000000000000101 rsi=0000000000000000 rdi=0000000000000000
rip=fffff8015b94f2d7 rsp=ffffd000bdbc8360 rbp=ffffd000bdbc8460
 r8=0000000000000050  r9=0000000000000006 r10=0000000000000002
r11=fffff8015b94f2d7 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0         nv up ei pl nz na pe cy
wfplwfs!memset+0xd7:
fffff801`5b94f2d7 48895130        mov     qword ptr [rcx+30h],rdx ds:00000000`bdbc83f0=????????????????
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff80276f7b7e9 to fffff80276f6fca0
STACK_TEXT:
ffffd000`bdbc8088 fffff802`76f7b7e9 : 00000000`0000000a 00000000`bdbc83f0 00000000`00000002 00000000`00000001 : nt!KeBugCheckEx
ffffd000`bdbc8090 fffff802`76f7a03a : 00000000`00000001 00000000`00000000 ffffd000`bdbc8200 ffffd000`bdbc81d0 : nt!KiBugCheckDispatch+0x69
ffffd000`bdbc81d0 fffff801`5b94f2d7 : ffffe000`29652c10 fffff801`5b4dc903 00000000`00000000 ffffd000`bdbc83d1 : nt!KiPageFault+0x23a
ffffd000`bdbc8360 ffffe000`29652c10 : fffff801`5b4dc903 00000000`00000000 ffffd000`bdbc83d1 00000000`00000001 : wfplwfs!memset+0xd7
ffffd000`bdbc8368 fffff801`5b4dc903 : 00000000`00000000 ffffd000`bdbc83d1 00000000`00000001 fffff801`5d7cac27 : 0xffffe000`29652c10
ffffd000`bdbc8370 fffff801`5b4ec1fd : 00000000`00000001 00000000`00000000 00000000`00000000 00000000`00000001 : ndis!ndisMIndicateNetBufferListsToOpen+0x123
ffffd000`bdbc8430 fffff801`5b4dd8d4 : ffffe000`289321a0 ffffe000`00000001 ffffd000`00000000 00000000`00000000 : ndis!ndisMTopReceiveNetBufferLists+0x23d
ffffd000`bdbc84c0 fffff801`5da9f35b : ffffe000`f0e08fd5 ffffe000`28ee6000 ffffd000`bdbc8800 ffffe000`00000001 : ndis!NdisMIndicateReceiveNetBufferLists+0xb74
ffffd000`bdbc86a0 ffffe000`f0e08fd5 : ffffe000`28ee6000 ffffd000`bdbc8800 ffffe000`00000001 ffffd000`00000001 : Rt630x64+0x1835b
ffffd000`bdbc86a8 ffffe000`28ee6000 : ffffd000`bdbc8800 ffffe000`00000001 ffffd000`00000001 ffffd000`00000001 : 0xffffe000`f0e08fd5
ffffd000`bdbc86b0 ffffd000`bdbc8800 : ffffe000`00000001 ffffd000`00000001 ffffd000`00000001 00000001`28fe0001 : 0xffffe000`28ee6000
ffffd000`bdbc86b8 ffffe000`00000001 : ffffd000`00000001 ffffd000`00000001 00000001`28fe0001 ff000001`00000001 : 0xffffd000`bdbc8800
ffffd000`bdbc86c0 ffffd000`00000001 : ffffd000`00000001 00000001`28fe0001 ff000001`00000001 00008000`00000020 : 0xffffe000`00000001
ffffd000`bdbc86c8 ffffd000`00000001 : 00000001`28fe0001 ff000001`00000001 00008000`00000020 00000000`00000000 : 0xffffd000`00000001
ffffd000`bdbc86d0 00000001`28fe0001 : ff000001`00000001 00008000`00000020 00000000`00000000 00000000`00000000 : 0xffffd000`00000001
ffffd000`bdbc86d8 ff000001`00000001 : 00008000`00000020 00000000`00000000 00000000`00000000 00000010`00000001 : 0x00000001`28fe0001
ffffd000`bdbc86e0 00008000`00000020 : 00000000`00000000 00000000`00000000 00000010`00000001 0000000a`00000020 : 0xff000001`00000001
ffffd000`bdbc86e8 00000000`00000000 : 00000000`00000000 00000010`00000001 0000000a`00000020 ffffe000`00000020 : 0x00008000`00000020
STACK_COMMAND:  kb
CHKIMG_EXTENSION: !chkimg -lo 50 -db !wfplwfs
6 errors : !wfplwfs (fffff8015b94f200-fffff8015b94f238)
fffff8015b94f200 *58  8b  c1  49  83  f8  08  72 *3c  0f  b6  d2  49  b9  01  01 X..I...r<...I...
fffff8015b94f210  01  01  01  01  01  01  49  0f *bf  d1  49  83  f8  47  73  60 ......I...I..Gs`
fffff8015b94f220 *45  8b  c8  49  83  e1  f8  49 *0b  c9  49  89  54  01  f8  49 E..I...I..I.T..I
fffff8015b94f230  83  e9  08  75  f5  49  83  e0 *0f  74  0f  0f  1f  44  00  00 ...u.I...t...D..
MODULE_NAME: memory_corruption
IMAGE_NAME:  memory_corruption
FOLLOWUP_NAME:  memory_corruption
DEBUG_FLR_IMAGE_TIMESTAMP:  0
MEMORY_CORRUPTOR:  STRIDE
FAILURE_BUCKET_ID:  MEMORY_CORRUPTION_STRIDE
ANALYSIS_SOURCE:  KM
FAILURE_ID_HASH_STRING:  km:memory_corruption_stride
FAILURE_ID_HASH:  {574dbc1b-92cb-fb09-cb7a-cacc1bb2c511}
You have a lot of problems. Check your RAM one stick at the time for 8 passes using this tool: RAM - Test with Memtest86+ - Windows 7 Help Forums
Please update your Realtek PCI/PCIe Adapter driver: Driver Reference Table - Rt630x64.sys
Check your HDD for errors.
    Windows 10 Pro x64
    On-board
    3840x2160
    1x4TB MyBook
    Corsair GS 700W
    Logitech G710+
    Avast 10.0
CK1985NL
161
#10
On the first test with all the memory cards plugged in there was more then thousand errors. I stopped immediately the the test and unplugged all of them. Than I plugged in the first memory card and tested for about one hour and it still not ended with the test, so I shut down the pc and I'm testing memory card 2 now. How long must I wait with the tests?
CK1985NL
161
#11
I see, I read the page you gave me again, I must wait thill the 7 passes has finished, it takes a couple of hours. I will do that and follow the steps. I let you know.
CK1985NL
161
#12
The first three memory sticks I tested, it took about 7 hours each test. The last memory stick gave 2 errors in the last motherboard stick. I plugged in a good one memory stick (stick nr. 1) and it is looking for errors now. I'll keep you updated.
CK1985NL
161
#13
I'm now testing the good memory card nr 1 in the motherboard stick where memory card nr 4 failed and for so far no errors. I will look at the end if there occurs errors, if it doesn't than I think memory card 4 is bad.
CK1985NL
161
#14
Memory card #4 got errors and I'm testing now memory card #1 on the same motherboard stick where memory card #4 failed, for so far no errors. This means that memory card #4 is bad, I'll get new one of them because I've got warranty for it. I really want to know the last step, how I test my HDD for errors? Thanks.
CK1985NL
161
#15
Step 2 about updating Realtek PCI/PCIe Adapter driver I could not find. Please help...
CK1985NL
161
#16
I go to the shop a few minutes ago, I must pay much money for a new one, so I decided to use the good 3 sticks memory card, or must I use two of them, 2 x 4GB memory card, will using 3 cards be a problem? Thanks
blueelvis
OMG Debugger!
India
2,097
#17
Hi CK1985NL ^_^,
I don't see a problem using 3 RAM cards at a time. Even my HP desktop has got 3x1GB RAM Modules and it works flawlessly. There shouldn't beany problem in running the 3 cards.
Do not hesitate to post back in case of any further problems ^_^
-Pranav
    Toshiba
    Intel HD 3000 B-)
    1366x768
    Toshiba 500 GB
CK1985NL
161
#18
Thanks blueelvis, the three memory cards work fine. I'll keep you updated if there's any problem.
softwaremaniac
2,480
#19
I agree. I am sorry for such a late reply.
    Windows 10 Pro x64
    On-board
    3840x2160
    1x4TB MyBook
    Corsair GS 700W
    Logitech G710+
    Avast 10.0
blueelvis
OMG Debugger!
India
2,097
#20
    Toshiba
    Intel HD 3000 B-)
    1366x768
    Toshiba 500 GB
