Solved BSOD after regular shutdown and restart
2
Hi all - whenever I shut down my Alienware M14X, all seems fine. However, when I turn it on again the next time, I get an "IRQ is less than or equal to" error. The laptop crashes, restarts, and works again, until I shut it down and start it up - and it all happens again.
Dump files attached - can someone help?
yowanvista
BSOD Hunter
Mauritius
545
Your Killer Wireless-N 1103 LAN device driver is the cause, update the driver. I would strongly recommend using Windows 8-certified drivers on your system.
Killer Gaming :: Support :: Driver Downloads
BugCheck D1, {18, 2, 0, fffff880068f9111}
Unable to load image \SystemRoot\system32\DRIVERS\Ak27x64.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for Ak27x64.sys
*** ERROR: Module load completed but symbols could not be loaded for Ak27x64.sys
Probably caused by : Ak27x64.sys ( Ak27x64+9111 )
fffff880`068f0000 fffff880`06c7f000   Ak27x64  T (no symbols)
    Loaded symbol image file: Ak27x64.sys
    Image path: \SystemRoot\system32\DRIVERS\Ak27x64.sys
    Image name: Ak27x64.sys
    Timestamp:        Tue Jan 24 22:05:44 2012 (4F1EF2F8)
    CheckSum:         003738E2
    ImageSize:        0038F000
    Translations:     0000.04b0 0000.04e4 0409.04b0 0409.04e4
    Windows 8.1 Pro x64
    Custom Build
    Core2 Quad Q8200 2.8Ghz
    Asus Rampage Forumla
    8GB DDR2 PC6400
    Zotac GTX460 2GB/Asus EN9600GT 1GB
    Asus Supreme FX2
    AOC 22
    1650x1080
    2X500GB+ 1x2TB
    Cooler Master GX 650W
    Standard
    3X Fans
    1024Kbps(which is the average speed in my country)
