BSOD after launching system NTFS_FILE_SYSTEM
nismo
Today I turn on my laptop as usual and after launching system without doing anything BSOD appears - NTFS_FILE_SYSTEM. I think I have all drivers updated. What should I do?
Microsoft (R) Windows Debugger Version 6.3.9600.17237 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Users\Mihael\Desktop\111514-7781-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
************* Symbol Path validation summary **************
Response                         Time (ms)     Location
Deferred                                       SRV*C:\SymCache*http://msdl.microsoft.com/download/symbols
Symbol search path is: SRV*C:\SymCache*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 8 Kernel Version 9600 MP (8 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Built by: 9600.17328.amd64fre.winblue_r3.140827-1500
Machine Name:
Kernel base = 0xfffff801`6a612000 PsLoadedModuleList = 0xfffff801`6a8e8370
Debug session time: Sat Nov 15 11:51:18.036 2014 (UTC + 1:00)
System Uptime: 1 days 14:40:19.778
Loading Kernel Symbols
Press ctrl-c (cdb, kd, ntsd) or ctrl-break (windbg) to abort symbol loads that take too long.
Run !sym noisy before .reload to track down problems loading symbols.
Loading User Symbols
Loading unloaded module list
BugCheck 24, {b500190637, ffffd001149d9a68, ffffd001149d9270, fffff8016a659dfc}
Probably caused by : memory_corruption ( nt!MiOffsetToProtos+1ac )
Followup: MachineOwner
6: kd> !analyze -v
NTFS_FILE_SYSTEM (24)
    If you see NtfsExceptionFilter on the stack then the 2nd and 3rd
    parameters are the exception record and context record. Do a .cxr
    on the 3rd parameter and then kb to obtain a more informative stack
    trace.
Arguments:
Arg1: 000000b500190637
Arg2: ffffd001149d9a68
Arg3: ffffd001149d9270
Arg4: fffff8016a659dfc
Debugging Details:
EXCEPTION_RECORD:  ffffd001149d9a68 -- (.exr 0xffffd001149d9a68)
ExceptionAddress: fffff8016a659dfc (nt!MiOffsetToProtos+0x00000000000001ac)
   ExceptionCode: c0000005 (Access violation)
  ExceptionFlags: 00000000
NumberParameters: 2
   Parameter[0]: 0000000000000000
   Parameter[1]: 0000000000000028
Attempt to read from address 0000000000000028
CONTEXT:  ffffd001149d9270 -- (.cxr 0xffffd001149d9270;r)
rax=0000000000000000 rbx=ffffe000ff1b62a0 rcx=000000000000ca5c
rdx=000000000000fff0 rsi=0000000000000000 rdi=0000000000000000
rip=fffff8016a659dfc rsp=ffffd001149d9ca0 rbp=0000000000000000
 r8=0000000000000000  r9=000002c094ab60b0 r10=000002bfca55afd8
r11=7ffffffffffffffc r12=0000000000000000 r13=ffffe000ff1b6318
r14=0000000000000000 r15=ffffd001149d9d88
iopl=0         nv up ei pl zr na po nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00010246
nt!MiOffsetToProtos+0x1ac:
fffff801`6a659dfc 0fb74e28        movzx   ecx,word ptr [rsi+28h] ds:002b:00000000`00000028=????
Last set context:
Resetting default scope
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  explorer.exe
CURRENT_IRQL:  0
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
EXCEPTION_PARAMETER1:  0000000000000000
EXCEPTION_PARAMETER2:  0000000000000028
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff8016a972138
unable to get nt!MmNonPagedPoolStart
unable to get nt!MmSizeOfNonPagedPoolInBytes
 0000000000000028
FOLLOWUP_IP:
FAULTING_IP:
BUGCHECK_STR:  0x24
DEFAULT_BUCKET_ID:  NULL_CLASS_PTR_DEREFERENCE
ANALYSIS_VERSION: 6.3.9600.17237 (debuggers(dbg).140716-0327) amd64fre
LAST_CONTROL_TRANSFER:  from fffff8016a65c3dd to fffff8016a659dfc
STACK_TEXT:
ffffd001`149d9ca0 fffff801`6a65c3dd : 00000000`00000000 00000000`00000000 00000000`00000040 ffffe000`ff1b62a0 : nt!MiOffsetToProtos+0x1ac
ffffd001`149d9d60 fffff801`6a65d0ba : 00000000`00000000 ffffe000`f35ea070 00000001`00000001 ffffd001`0fb40830 : nt!MmMapViewInSystemCache+0x79
ffffd001`149d9ed0 fffff801`6a659aaf : 00000000`00000001 ffffe000`fa3394d0 00000000`00000001 fffff801`00000001 : nt!CcGetVacbMiss+0x122
ffffd001`149d9f60 fffff801`6a9c35f6 : 00000000`00000001 00000000`00000000 ffffd001`149da070 ffffd001`149da088 : nt!CcGetVirtualAddress+0x36f
ffffd001`149da000 fffff801`ab18244e : ffffc000`8bb7d000 ffffc000`a3d2f438 00000000`00001000 ffffc000`a3d2f430 : nt!CcMapData+0x72
ffffd001`149da070 fffff801`ab17ee34 : ffffe000`f8b9a018 ffffc000`a3d2f430 ffffc000`a3d2f390 ffffc000`a462f140 : Ntfs!ReadIndexBuffer+0xde
ffffd001`149da0f0 fffff801`ab179074 : 00000000`00000001 fffff801`aaf16ff8 ffffe000`f7542380 ffffc000`9a42d920 : Ntfs!FindFirstIndexEntry+0x154
ffffd001`149da180 fffff801`ab16b3e9 : ffffc000`a462f140 ffffc000`a462f140 ffffe000`fb7c1368 00000000`0000002a : Ntfs!NtfsRestartIndexEnumeration+0x154
ffffd001`149da3f0 fffff801`ab1834c2 : 00000000`00000000 ffffe000`f37d66c0 ffffd001`149da910 00000000`00000000 : Ntfs!NtfsQueryDirectory+0xaed
ffffd001`149da7a0 fffff801`ab183619 : 00000000`00000000 ffffe000`fb7c1010 00000000`00000000 ffffd001`149da910 : Ntfs!NtfsCommonDirectoryControl+0xa2
ffffd001`149da7e0 fffff801`aad7fcf8 : ffffe000`fb7c1368 ffffe000`fb7c1010 ffffe000`f8b9a018 ffffd001`149da808 : Ntfs!NtfsFsdDirectoryControl+0xb9
ffffd001`149da850 fffff801`aad7e0b6 : ffffe000`f4d2ddf0 00000000`00000000 ffffe000`fb7c1010 ffffe000`fb8a3070 : fltmgr!FltpLegacyProcessingAfterPreCallbacksCompleted+0x258
ffffd001`149da8f0 fffff801`6aa50e30 : 00000000`00000002 ffffd001`149daa49 00000000`00000000 00000000`00000000 : fltmgr!FltpDispatch+0xb6
ffffd001`149da950 fffff801`6a76c9b3 : 00000000`00000000 00000000`0b2f26fc ffffe000`f7542380 ffffd001`149dab80 : nt!NtQueryDirectoryFile+0x1cc
ffffd001`149daa90 00007fff`564819ca : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`0446e4b8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007fff`564819ca
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  nt!MiOffsetToProtos+1ac
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
DEBUG_FLR_IMAGE_TIMESTAMP:  53fe6f2e
IMAGE_VERSION:  6.3.9600.17328
STACK_COMMAND:  .cxr 0xffffd001149d9270 ; kb
IMAGE_NAME:  memory_corruption
BUCKET_ID_FUNC_OFFSET:  1ac
FAILURE_BUCKET_ID:  0x24_nt!MiOffsetToProtos
ANALYSIS_SOURCE:  KM
FAILURE_ID_HASH_STRING:  km:0x24_nt!mioffsettoprotos
FAILURE_ID_HASH:  {66fb006a-b066-dd1f-f2c2-6e8caaa30c35}
Check your RAM using Memtest RAM - Test with Memtest86+ - Windows 7 Help Forums make sure you test each stick separately. Also, run SFC. SFC /SCANNOW : Run in Command Prompt at Boot - Windows 7 Help Forums
