BSOD(63) Help please :\
Epochi
Hi, I'm going on my second year with this fresh, new computer I built and I frequently get a Blue Screen of Death when I play Graphics-heavy games, as of late it's been Overwatch. I have a strong cpu, graphics card, with high RAAM. This computer has some firepower and works exquisitely... besides the frequent BSOD crashes. I have Malwarebytes Anti-Malware and believe it may be causing some of my issues. I've run a defragger on my drives and a memory check to see if that was what was at fault and (un)fortunately, no dice. I am relatively new to computers and am learning day-to-day, so i'd appreciate patience. Here are some of my frequent error codes I get.
[TD="width: 15"] - [/TD]
[TD="width: 130"] System [/TD]
[TD="width: 15"] -
[TD="width: 15"][/TD]
[TD="width: 130"] Provider [/TD]
Microsoft-Windows-Kernel-Power
[TD="width: 12"][/TD]
[TD="width: 105"][ Name ] [/TD]
{331C3B3A-2005-44C2-AC5E-77220C37D6B4}
[TD="width: 105"][ Guid ] [/TD]
[/TD]
[TD="width: 15"]
41
[TD="width: 130"] EventID [/TD]
[/TD]
[TD="width: 15"]
[TD="width: 130"] Version [/TD]
[/TD]
[TD="width: 15"]
1
[TD="width: 130"] Level [/TD]
[/TD]
[TD="width: 15"]
63
[TD="width: 130"] Task [/TD]
[/TD]
[TD="width: 15"]
0
[TD="width: 130"] Opcode [/TD]
[/TD]
[TD="width: 15"]
0x8000000000000002
[TD="width: 130"] Keywords [/TD]
[/TD]
[TD="width: 15"] -
[TD="width: 130"] TimeCreated [/TD]
2016-06-25T07:26:36.669852600Z
[TD="width: 105"][ SystemTime ] [/TD]
[/TD]
[TD="width: 15"]
32483
[TD="width: 130"] EventRecordID [/TD]
[/TD]
[TD="width: 15"]
Correlation
[/TD]
[TD="width: 15"] -
[TD="width: 130"] Execution [/TD]
4
[TD="width: 105"][ ProcessID ] [/TD]
8
[TD="width: 105"][ ThreadID ] [/TD]
[/TD]
[TD="width: 15"]
System
[TD="width: 130"] Channel [/TD]
[/TD]
[TD="width: 15"]
__WRAITH__
[TD="width: 130"] Computer [/TD]
[/TD]
[TD="width: 15"] -
[TD="width: 130"] Security [/TD]
S-1-5-18
[TD="width: 105"][ UserID ] [/TD]
[/TD]
[TD="width: 130"] EventData [/TD]
126
[TD="width: 130"] BugcheckCode [/TD]
0xffffffffc0000005
[TD="width: 130"] BugcheckParameter1 [/TD]
0xfffff800db8504ba
[TD="width: 130"] BugcheckParameter2 [/TD]
0xffffd002001292f8
[TD="width: 130"] BugcheckParameter3 [/TD]
0xffffd00200128b00
[TD="width: 130"] BugcheckParameter4 [/TD]
0
[TD="width: 130"] SleepInProgress [/TD]
0
[TD="width: 130"] PowerButtonTimestamp [/TD]
0
[TD="width: 130"] BootAppStatus [/TD]
[TD="width: 15"] -
[/TD]
[TD="width: 15"]
41
[/TD]
[TD="width: 15"]
[/TD]
[TD="width: 15"]
1
[/TD]
[TD="width: 15"]
63
[/TD]
[TD="width: 15"]
0
[/TD]
[TD="width: 15"]
0x8000000000000002
[/TD]
[TD="width: 15"] -
2016-06-23T01:25:05.904377600Z
[/TD]
[TD="width: 15"]
32079
[/TD]
[TD="width: 15"]
Correlation
[/TD]
[TD="width: 15"] -
4
8
[/TD]
[TD="width: 15"]
System
[/TD]
[TD="width: 15"]
__WRAITH__
[/TD]
[TD="width: 15"] -
S-1-5-18
[/TD]
209
0x2900000004
0x2
0x0
0xfffff8017089bbd4
0
0
0
[TD="width: 15"] -
[/TD]
[TD="width: 15"]
41
[/TD]
[TD="width: 15"]
[/TD]
[TD="width: 15"]
1
[/TD]
[TD="width: 15"]
63
[/TD]
[TD="width: 15"]
0
[/TD]
[TD="width: 15"]
0x8000000000000002
[/TD]
[TD="width: 15"] -
2016-06-22T20:38:18.935746700Z
[/TD]
[TD="width: 15"]
31951
[/TD]
[TD="width: 15"]
Correlation
[/TD]
[TD="width: 15"] -
4
8
[/TD]
[TD="width: 15"]
System
[/TD]
[TD="width: 15"]
__WRAITH__
[/TD]
[TD="width: 15"] -
S-1-5-18
[/TD]
190
0xfffff801690469b0
0x5f50000358f86021
0xffffd000398ce240
0xb
0
0
0
[TD="width: 15"] -
[/TD]
[TD="width: 15"]
41
[/TD]
[TD="width: 15"]
[/TD]
[TD="width: 15"]
1
[/TD]
[TD="width: 15"]
63
[/TD]
[TD="width: 15"]
0
[/TD]
[TD="width: 15"]
0x8000000000000002
[/TD]
[TD="width: 15"] -
2016-06-10T15:04:24.013934700Z
[/TD]
[TD="width: 15"]
30148
[/TD]
[TD="width: 15"]
Correlation
[/TD]
[TD="width: 15"] -
4
8
[/TD]
[TD="width: 15"]
System
[/TD]
[TD="width: 15"]
__WRAITH__
[/TD]
[TD="width: 15"] -
S-1-5-18
[/TD]
30
0xffffffffc0000005
0xfffff8008407f997
0x0
0xa0
0
0
0
[TD="width: 15"] -
[/TD]
[TD="width: 15"]
41
[/TD]
[TD="width: 15"]
[/TD]
[TD="width: 15"]
1
[/TD]
[TD="width: 15"]
63
[/TD]
[TD="width: 15"]
0
[/TD]
[TD="width: 15"]
0x8000000000000002
[/TD]
[TD="width: 15"] -
2016-06-09T19:50:31.779279500Z
[/TD]
[TD="width: 15"]
29935
[/TD]
[TD="width: 15"]
Correlation
[/TD]
[TD="width: 15"] -
4
8
[/TD]
[TD="width: 15"]
System
[/TD]
[TD="width: 15"]
__WRAITH__
[/TD]
[TD="width: 15"] -
S-1-5-18
[/TD]
126
0xffffffffc0000005
0xfffff800027c58f2
0xffffd000e320d3c8
0xffffd000e320cbd0
0
0
0
[TD="width: 15"] -
[/TD]
[TD="width: 15"]
41
[/TD]
[TD="width: 15"]
[/TD]
[TD="width: 15"]
1
[/TD]
[TD="width: 15"]
63
[/TD]
[TD="width: 15"]
0
[/TD]
[TD="width: 15"]
0x8000000000000002
[/TD]
[TD="width: 15"] -
2016-06-09T19:09:55.872916900Z
[/TD]
[TD="width: 15"]
29886
[/TD]
[TD="width: 15"]
Correlation
[/TD]
[TD="width: 15"] -
4
8
[/TD]
[TD="width: 15"]
System
[/TD]
[TD="width: 15"]
__WRAITH__
[/TD]
[TD="width: 15"] -
S-1-5-18
[/TD]
126
0xffffffffc0000005
0xfffff800d3d6e414
0xffffd000346272a8
0xffffd00034626ab0
0
0
0
... and that's just some of the multiple bsod's I have gotten ;-;. Please assist in any way, shape, or form if possible! Thank you for your time.
I would want to ask that you run MemTest86+, you ran the built-in memory diagnostics test but MemTest86+ is better in finding errors :)
Diagnostic Test
RAM TEST
Run MemTest86+ to analyse your RAM. MemTest86+ - Test RAM - Windows 10 Forums
picture.php
MemTest86+ needs to be run for at least 8 complete passes for conclusive results. Set it running before you go to bed and leave it overnight. We're looking for zero errors here. Even a single error will indicate RAM failure.
Make a photo of the result and post it.
Addition:
If errors show up you can stop the test, remove all sticks but 1 and test this single stick in each slot for 8 passes or until errors show, switch sticks and repeat.
If errors show up and you see them a lot later, no problem, the errors don't affect the test.
