Solved BOSD on my GT72Pro Notebook - Please help!
phila delphia
Merry Christmas!
I beg your help, as I get the "Page_Fault_In_Non_Paged_Area" BOSD from time to time.
The eventmanager says something about "Kernel 41" Error.
Below there is the log file. I created with the debugger tool you advised!
Best regards.
phila
EDIT: First steps I took to prevent the issue:
I performed the following repair routine
- Dism /Online /Cleanup-Image /CheckHealth - Dism /Online /Cleanup-Image /ScanHealth
- Dism /Online /Cleanup-Image /RestoreHealth
- Restart
- sfc /scannow
- I as well realized that my virtual RAM might be to small to small (4096) in relation to my 32GB RAM. So due to a small amount of space on my SSD I downgraded 16 GB RAM and in return set higer values for pagefile.sys (8192MB) and hyberfile.sys (12286MB).
(you`ll notice the change in comparisson to the log files I guess)
- I am acurrently also testing powercfg /h off
Here an Update as today the screen turned black (due to the proweconfig?) but was not to be turned on again. Analyting the memory.dmp with bluescreen view showed this (see below). Though I am not sore if this issues had someting to do with the energy settings?!
Only 91 Windows Updates installed. Most systems have 100 or more. Please visit Windows Update and get ALL available updates (it may take several trips to get them all).
Don't worry about the specific number, it's just important that you have checked and installed any updates that were available (and didn't experience any errors).
There are no memory dumps in the uploaded files. Please do this:
Upload Dump Files:
NOTE: If using a disk cleaning utility, please stop using it while we are troubleshooting your issues.
Please go to C:\Windows\Minidump and zip up the contents of the folder. Then upload/attach the .zip file with your next post.
Left click on the first minidump file.
Hold down the "Shift" key and left click on the last minidump file.
Right click on the blue highlighted area and select "Send to"
Select "Compressed (zipped) folder" and note where the folder is saved.
Upload that .zip file with your next post.
If you have issues with "Access Denied" errors, try copying the files to your desktop and zipping them up from there. If it still won't let you zip them up, post back for further advice.
If you don't have anything in that folder, please check in C:\Windows for a file named MEMORY.DMP. If you find it, zip it up and upload it to a free file hosting service. Then post the link to it in your topic so that we can download it.
Also, search your entire hard drive for files ending in .dmp, .mdmp, and .hdmp. Zip up any that you find and upload them with your next post.
Then, follow the directions here to set your system for Minidumps (much smaller than the MEMORY.DMP file): Set MiniDumpMore info on dump file options here: Overview of memory dump file options for Windows 2000, Windows XP, Windows Server 2003, Windows Vista, Windows Server 2008, Windows 7, and Windows Server 2008 R2
You have 5 or more hard drives. Please explain this configuration as you're using a laptop.
These 2 devices have problems in Device Manager:
HID-konforme Maus HID\VID_1038&PID_1000&REV_0100&MI_02\3&12B2788C&0&0000 Das Gerät wurde deaktiviert.
Nicht verfügbar ROOT\SCSIADAPTER\0000 Die Treiber für dieses Gerät wurden nicht installiert.
The first is a mouse that is disabled. Is this deliberate? If so, why? The second is a device that helps to control your SCSI Adapter - this one isn't installed. I'd suggest visiting the MSI website to obtain the proper driver for this device.
You have a number of Live Kernel Events in the WER section of MSINFO32. Please do the following:
- open Event Viewer (run eventvwr.msc from the "Run" dialog)
- expand the Custom Views category (left click on the > next to the words "Custom Views")
- right click on Administrative Events
- select "Save all Events in Custom View as..."
- save the file as Admin.evtx
- zip up the file (right click on it, select "Send to", select "Compressed (zipped) folder")
- upload it with your next post (if it's too big, then upload it to a free file-hosting service and post a link here).
FYI - If we're looking for Event ID 41 errors (unexplained shutdowns), there's more info on that here: Windows Kernel event ID 41 error "The system has rebooted without cleanly shutting down first" in Windows 8.1, Windows 8, Windows Server 2012 R2, Windows Server 2012, Windows 7, or Windows Server 2008 R2
While waiting for a reply, please monitor your temps with this free utility: HWMonitor CPUID - System & hardware benchmark, monitoring, reporting
Do not run Panda Security and MalwareBytes at the same time - it'll cause problems.
MSI Afterburner and Riva Tuner (along with EVGA Precision) is known to cause BSOD's in some Windows systems (it's driver is usually RTCore64.sys). Please un-install them immediately!
If you're overclocking, please stop the overclock while we're troubleshooting. Feel free to resume the overclock once the system has been stabilized.
Beyond this, I have these 4 suggestions:
1. Get ALL available Windows Updates. It may take several trips to get them all
2. Get ALL available, Win8.1 compatible updates from the manufacturer's website.
3. Start with these free hardware diagnostics: Hardware Diagnostics
4. If all of the hardware tests pass, then run Driver Verifier according to these instructions: http://www.carrona.org/verifier.html
Hi there and thank you for the quick response - even on the holidays (Merry Christmas by the way)!
Now I have got a lot of homework to do ;-) but I am greatful for the advice and I`l try to keep up:
- The Updates: Right now I have everythin installed that the Win 8.1 Updater shows... Is there an other source of updates?
- As for the hard drives: There are 2 external HDD via USB 3.0 with 2 partitions each. I use them to do backups
Onboard i have an ssd Raid 0 with 2x128 GB (system) + 1000GB HDD with three partitions (data / mirror and / repair).
- I did not know that MSI Afterburner was causing problems... So thx also I do not part glady with this usefull program ;-(
- One of the mice is disabled, yes I am not sure why I did this - might be ther former mouse I used?
- The SCSI thing?! I`ll have to look this one up. Could this be the data bridge I used to connect one of the external HDD?
I tried to upload the zipped file but I am told it is invalid? Do you have any idea why this is?
Here is the dropbox link of the zipped file: https://www.dropbox.com/s/9q4y36tard22yxe/Admin.7z?dl=0
Best regards
Phil
P.S.: Oh the Temps of the system never surpased 79 degree celsius (even under stress) and in general are a lot cooler.
Concearning the system test? Is it possible that with an uefi bios I cannot boot from the usb stick with memtest on it?!
Best regards
Phil
I was able to see that the system wasn't able to make a minidump - but that it did create a MEMORY.dmp file in C:\Windows
Please zip that up and upload it to Dropbox and post a link here.
Then ensure that your system is set to make minidumps (from my previous instructions).
Then run Driver Verifier according to these instructions: Driver Verifier Settings
Running MemTest will require that you change settings in the UEFI. If you don't know how to do that, don't worry - just run Prime95's Blend test from within Windows (it's not identical to MemTest, but it does test the RAM in a different way).
Prime95 is an excellent suggestion then. I know how to use from ocing my last desktop pc.
As to the dump file... I allready trashed that after taking the screenshot in the second post - sorry (won`t happen again...)
I´ll start going through the rest of the process you mentioned above now.
Best regards
Phil
P.S.: Yet another question - If MSI Afterburner or Overclocking was involved would`t that suggest that the BOSD would happen while the GPU is stressed? I never had a BOSD while gaming - even with max GPU Load. Dont`get me wrong. I`ll refrain from using Afterburner to exclude the stability issues - but...
The times it occured was:
-surfing the internet 5-6 times
-using OpenOffice 1 time
-copying a large amount of files from one external HDD to another (with to less virtual RAM)
Hi John!
With the verifier I cought two minidumps: I`ll load them up via dropbox again as the uploader again told me they are invalid:
Dump 1: https://www.dropbox.com/s/kn7fhwb0gro74m5/MSI01.dmp?dl=0
Dump 2: https://www.dropbox.com/s/b5mulqfejdg4rpx/MSI02.dmp?dl=0
The notebook crashed two times right after I typed in my pasword and crashed before the desktop showed up.
I as well made to scrrens with the bluescreenanalyzer.
Thank you for your help.
Besr regards
Phil
Update: Two more dumps:
Dump 3: https://www.dropbox.com/s/newqlv0ytcskauw/MSI03.dmp?dl=0
Dump 4: https://www.dropbox.com/s/gic0m1ni1b87hx0/MSI04.dmp?dl=0
Hi John!
Please have a look at the above post as well it allready contains 4 minidumps
I collected two more since (see below). Before doing so I did the following.
- deinstalled MSI Afterburner
- deinstalled RivaMonitor (Linked with MSI Afterburner)
- reverted to the Nvidia driver version issued by MSI
- checked for Windows Updates agiain (no new ones)
- installed all the new dirvers/software provided by MSI for my system
- run prime95 (if only for 20 min - I´ll do some more over night) without issues
Still with verifier I get the same chrash before reaching the desktop:
Dump 5: https://www.dropbox.com/s/1c1tmyu5p676n79/MSI05.dmp?dl=0
Dump 6: https://www.dropbox.com/s/1neieshn9kbbna9/MSI06.dmp?dl=0
Best regards
Phil
Update: The next thing I will try is the following - MSI offers the option to manually switch between Nvidia graphics and Intel onboard graphics. So I`ll disable Nvidia and try "verifier" with Intel onboard graphics. Just to be sure it is not an Issue of the graphics card. I`ll post the dumps to come below.
Update: The following two dumps were made with nvidia card disabled - still the dumps keep comming:
Dump 7: https://www.dropbox.com/s/bljul0upn7tlejz/MSI07.dmp?dl=0
Dump 8: https://www.dropbox.com/s/9n865n9ytzz6ce1/MSI08.dmp?dl=0
Update: At the last sartup something curious happened. Win 8.1 was booting to the UEFI as the tow preceding bootups were not succesful. On choosing advanced startup the notebook shutdown allof a sudden and started regulary - this time I came past the log on screen and am now writing to you... The system seems extremely slow...
Update: I`ve done several startups now (with verifier running) and the computer did not crash... I wonder why?! The only things I have disables in verifier are "Simulation of Low Resouces", "Systematic Simulation of low resoucres" and "Force Pending I/O Requests"...
Update: Really weired... The Pandasecurity PSUMain.exe suddenly stresses my CPU a lot - with or without verifier settings applied. It occupys up to 50% of my CPU. This was why the Notebook was so slow... I deinstalled it for now (especially as I read about Panda causing BSOD as well occasinonally).
Update: This one happened while ideling over night - Nothing save the mouse was connected - System allways kept comming to the desktop now - Never crashed at Startup - Yet Panda cant be it...
Dump 9: https://www.dropbox.com/s/7vsevxm5j6y8zgy/MSI09.dmp?dl=0
Update: After reading around a bit: Seems like BasicRender.sys and Msfs.sys - but what does that mean?
Update: There is a bios Update for my notebook, yet the despription does not sound promissing: H10 "Fixed logo show 3 times under legacy". Might be noobish but after reading here: http://www.eightforums.com/bsod-crashes-debugging/38073-random-bsods.html - I also checked the LAN and WIFI drivers for updates - but they are up to date.
Update: Two more things I can think of - I use MSI fan control tool to adjust the fan speed of my GPU ad CPU fans. The program is propriate MSI (like Afterburner ;-P) - Could it be the cause? Plus: up to now I have naver had bluescreen under heavy load - only ideling, surfing or while i was occupied with regular desktop business.
Update: I did run chkdsk form boot and got the following output (google translate as my system is german)
Phase 1: The basic file system structure is studied ...
584,960 records processed . File verification completed .
5043 large data sets processed. 0 bad file records processed .
Phase 2: The file name link is investigated ...
703,874 index entries processed. Index verification completed .
0 unindexed files reviewed. 0 unindexed files recovered.
Phase 3: security descriptors are investigated ...
2383 unused index entries from index $ SII of file 0x9 to be cleaned up .
2383 unused index entries from index $ SDH of file 0x9 to be cleaned up .
2383 unused security descriptors to be cleaned up .
Security descriptor verification completed.
59458 data files processed. CHKDSK is verifying Usn Journal ...
36212104 USN bytes processed. The review of USN journal is complete.
There corrections were made to the file system.
No further action is required.
249006079 KB total disk space
200316868 KB in 204952 files
336364 KB in 59459 indices
0 KB in bad sectors
698779 KB used by the system
65536 KB of the log file is
47654068 KB available on disk
4096 bytes in each allocation unit
62251519 allocation units on disk in total
11913517 allocation units available on disk
Internal information:
Ed 00 08 00 08 04 00 15 ce da 07 00 00 00 00 00 ................
C5 01 00 00 34 00 00 00 00 00 00 00 00 00 00 00 4 .... ...........
The disk check has been completed.
Please wait until the computer is restarted.
I generally only get online in the early morning in the Eastern US (UTC-5 hours).
Maybe yes, maybe no. If it's the driver causing the problem (as is usually the case with MSI Afterburner), then it can happen at any time that the system hits that special place that causes the BSOD. If it's the overclocking causing it, then most likely it should have problems when the system (not necessarily the GPU) is stressed. For example here, if your Northbridge is overheating, you probably won't see anything when stressing the GPU (unless you're also stressing the Northbridge). In addition to all of that, if you stress a certain part of the GPU - and that's not the part of the GPU that's failing - then you'll likely not see any problems from it either.
Please don't rename the dump files - I use the names to sort those that I have to run from those that I have already run.
Have you tried zipping up the memory dumps and uploading them here. I expect that the .dmp extension (along with others) is blocked.
From the chkdsk output:
This says that there was a problem with the NTFS file system on your hard drive - and that it had corrections made.
1) Please run these free hardware diagnostics: Hardware Diagnostics Start with the hard drive diagnostics because of the chkdsk results
2) In a week or two, run chkdsk again and see if it again corrects the file system. If it does, then there's a persistent problem that'll have to be looked into.
All memory dumps (except for the last one) were caused by psinknc.sys - a driver for the Panda Cloud antivirus.
The latest memory dump points to a networking driver problem, but doesn't point to anything in particular.
BUT, there have been problems with MSI systems recently, and in the past with MSI networking issues.
So, first let's work on these 2 drivers:
winio64.sys Fri Jun 4 00:08:03 2010 (4C087C23)
Nuvoton Technology Corporation PCIeBridge[br]Part of MSI Dragoon Gaming Center also
http://www.carrona.org/drivers/driver.php?id=winio64.sys
NTIOLib_X64.sys Thu Oct 25 06:27:58 2012 (5089142E)
MSI Afterburner driver (known BSOD issues with Windows) Also found to be a part of MSI Live Update 5[br][br]Recently (Nov 2014) there have been numerous instances of this driver in memory dumps. Analysis reveals that they are scattered throughout the filesystem by the installed MSI command utilities. For now I suggest uninstalling them all.
http://www.carrona.org/drivers/driver.php?id=NTIOLib_X64.sys
Please temporarily uninstall the MSI Dragoon Gaming Center software.
Also, please uninstall the MSI Afterburner software and the MSI Live Update software (this driver was in the "drivers" folder, so it's not likely that it's a part of the MSI Command Utilities.
Then check to be sure that both winio64.sys and NTIOLib_X64.sys are not in the C:\Windows\System32\drivers directory (DO NOT delete them, it may render your system unbootable!!! If needed I can provide a method to safely remove them manually).
Uninstall your iTunes, and download/install a fresh copy. The GEARAspiWDM.sys driver on your system dates from 2009 - and the latest version dates from 2012.
Analysis:
[font=lucida console]**************************Thu Dec 25 20:19:46.249 2014 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\MSI09.dmp]
Windows 8 Kernel Version 9600 MP (8 procs) Free x64
Built by: [B]9600[/B].17476.amd64fre.winblue_r5.141029-1500
System Uptime:[B]0 days 0:27:05.078[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!IopProcessWorkItem+80 )[/B]
BugCheck [B]C4, {9200f, fffff80091d58c50, ffffe001648c8d30, ffffe001648c8dc8}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x000000C4]DRIVER_VERIFIER_DETECTED_VIOLATION (c4)[/url]
Arguments:
Arg1: 000000000009200f, ID of the 'NdisTimedDataHang' rule that was violated.
Arg2: fffff80091d58c50, A pointer to the string describing the violated rule condition.
Arg3: ffffe001648c8d30, Address of internal rule state (second argument to !ruleinfo).
Arg4: ffffe001648c8dc8, Address of supplemental states (third argument to !ruleinfo).
BUGCHECK_STR:  0xc4_NdisTimedDataHang_XDV
PROCESS_NAME:  System
FAILURE_BUCKET_ID: [B]0xc4_NdisTimedDataHang_XDV_nt!IopProcessWorkItem[/B]
CPUID:        "Intel(R) Core(TM) i7-4710HQ CPU @ 2.50GHz"
MaxSpeed:     2500
CurrentSpeed: [B]2494[/B]
  BIOS Version                  E1781IMS.10D
  BIOS Release Date             09/15/2014
  Manufacturer                  Micro-Star International Co., Ltd.
  Product Name                  GT72 2QE
**************************Thu Dec 25 17:40:27.357 2014 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\MSI08.dmp]
System Uptime:[B]0 days 0:01:55.184[/B]
*** WARNING: Unable to verify timestamp for psinknc.sys
*** ERROR: Module load completed but symbols could not be loaded for psinknc.sys
Probably caused by :[B]psinknc.sys ( psinknc+199b1 )[/B]
BugCheck [B]C4, {2001f, fffff800f0f5dd50, 0, 0}[/B]
Arguments:
Arg1: 000000000002001f, ID of the 'IrqlZwPassive' rule that was violated.
Arg2: fffff800f0f5dd50, A pointer to the string describing the violated rule condition.
Arg3: 0000000000000000, Reserved (unused).
Arg4: 0000000000000000, Reserved (unused).
BUGCHECK_STR:  0xc4_IrqlZwPassive_XDV
FAILURE_BUCKET_ID: [B]0xc4_IrqlZwPassive_XDV_psinknc+199b1[/B]
MaxSpeed:     2500
  Product Name                  GT72
**************************Thu Dec 25 17:38:11.930 2014 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\MSI07.dmp]
System Uptime:[B]0 days 0:01:20.757[/B]
BugCheck [B]C4, {2001f, fffff800a04ded50, 0, 0}[/B]
Arguments:
Arg2: fffff800a04ded50, A pointer to the string describing the violated rule condition.
MaxSpeed:     2500
  Product Name                  GT72
**************************Thu Dec 25 17:19:42.219 2014 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\MSI06.dmp]
System Uptime:[B]0 days 0:01:51.044[/B]
BugCheck [B]C4, {2001f, fffff8016c293d50, 0, 0}[/B]
Arguments:
Arg2: fffff8016c293d50, A pointer to the string describing the violated rule condition.
**************************Thu Dec 25 17:17:33.049 2014 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\MSI05.dmp]
System Uptime:[B]0 days 0:01:58.876[/B]
BugCheck [B]C4, {2001f, fffff801cb73ed50, 0, 0}[/B]
Arguments:
Arg2: fffff801cb73ed50, A pointer to the string describing the violated rule condition.
**************************Thu Dec 25 16:08:07.297 2014 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\MSI04.dmp]
System Uptime:[B]0 days 0:01:30.123[/B]
BugCheck [B]C4, {2001f, fffff801708f9d50, 0, 0}[/B]
Arguments:
Arg2: fffff801708f9d50, A pointer to the string describing the violated rule condition.
**************************Thu Dec 25 16:06:20.308 2014 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\MSI03.dmp]
System Uptime:[B]0 days 0:00:59.134[/B]
BugCheck [B]C4, {2001f, fffff80046757d50, 0, 0}[/B]
Arguments:
Arg2: fffff80046757d50, A pointer to the string describing the violated rule condition.
**************************Thu Dec 25 15:30:07.721 2014 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\MSI01.dmp]
System Uptime:[B]0 days 0:01:33.548[/B]
BugCheck [B]C4, {2001f, fffff8012d87ed50, 0, 0}[/B]
Arguments:
Arg2: fffff8012d87ed50, A pointer to the string describing the violated rule condition.
**************************Thu Dec 25 15:28:17.059 2014 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\MSI02.dmp]
System Uptime:[B]0 days 0:01:35.885[/B]
BugCheck [B]C4, {2001f, fffff8011db51d50, 0, 0}[/B]
Arguments:
Arg2: fffff8011db51d50, A pointer to the string describing the violated rule condition.
[/font]
3rd Party Drivers:
GEARAspiWDM.sys            Mon May 18 08:17:04 2009 (4A1151C0)
MBfilt64.sys               Thu Jul 30 23:40:32 2009 (4A7267B0)[/B][/COLOR]
[COLOR=RED][B]LGBusEnum.sys              Mon Nov 23 20:36:48 2009 (4B0B38B0)
[COLOR=RED][B]winio64.sys                Fri Jun  4 00:08:03 2010 (4C087C23)[/B][/COLOR]
tbhsd.sys                  Tue Oct  9 18:01:42 2012 (50749EC6)
rsvcdwdr.sys               Tue Oct  9 18:36:49 2012 (5074A701)
[COLOR=RED][B]NTIOLib_X64.sys            Thu Oct 25 06:27:58 2012 (5089142E)[/B][/COLOR]
rikvm_38F51D56.sys         Mon Jun 17 00:05:56 2013 (51BE8B24)
intelppm.sys               Thu Aug 22 04:46:35 2013 (5215CFEB)
RrNetCapFilterDriver.sys   Mon Sep 30 09:54:17 2013 (52498289)
TeeDriverx64.sys           Wed Nov 27 12:56:32 2013 (52963250)
RtsPer.sys                 Fri Feb 21 02:35:56 2014 (530701DC)
SAlphaPS264.sys            Wed Mar  5 10:00:39 2014 (53173C17)
e22w8x64.sys               Wed Mar 26 11:58:37 2014 (5332F92D)
SteelBus64.sys             Tue May 27 12:42:05 2014 (5384C05D)
RTKVHD64.sys               Tue Jun 17 07:21:32 2014 (53A024BC)
iwdbus.sys                 Tue Jun 17 17:54:22 2014 (53A0B90E)
nvhda64v.sys               Mon Jul 21 10:17:53 2014 (53CD2111)
Qcamainx64.sys             Fri Aug  8 02:04:41 2014 (53E46879)
bwcW8x64.sys               Wed Aug 13 12:58:49 2014 (53EB9949)
iaStorA.sys                Fri Aug 22 17:26:36 2014 (53F7B58C)
dump_iaStorA.sys           Fri Aug 22 17:26:36 2014 (53F7B58C)
btfilter.sys               Mon Sep 15 19:30:21 2014 (5417768D)
nvlddmkm.sys               Fri Sep 26 21:35:37 2014 (54261469)
nvvadarm.sys               Fri Sep 26 21:53:26 2014 (54261896)
SynTP.sys                  Thu Oct  9 01:07:46 2014 (54361822)
Smb_driver_Intel.sys       Thu Oct  9 01:12:24 2014 (54361938)
nvvad64v.sys               Thu Nov 20 10:33:54 2014 (546E09E2)
NvStreamKms.sys            Sat Nov 22 02:46:45 2014 (54703F65)
NNSNAHSL.sys               Thu Jan 16 12:27:55 2014 (52D8169B)
PSKMAD.sys                 Tue Mar 25 08:55:02 2014 (53317CA6)
NNSPrv.sys                 Wed Jun  4 10:27:34 2014 (538F2CD6)
NNSAlpc.sys                Wed Jun  4 10:31:10 2014 (538F2DAE)
NNSTlsc.sys                Wed Jun  4 10:33:39 2014 (538F2E43)
NNSStrm.sys                Wed Jun  4 10:37:37 2014 (538F2F31)
NNSPicc.sys                Wed Jun  4 11:26:42 2014 (538F3AB2)
NNSProt.sys                Wed Jun  4 11:30:03 2014 (538F3B7B)
NNSIds.sys                 Wed Jun  4 11:37:05 2014 (538F3D21)
NNSPop3.sys                Wed Jun  4 11:43:40 2014 (538F3EAC)
NNSSmtp.sys                Wed Jun  4 11:52:12 2014 (538F40AC)
NNSPihsw.sys               Wed Jun  4 11:54:24 2014 (538F4130)
NNSHttps.sys               Wed Jun  4 11:57:09 2014 (538F41D5)
NNSHttp.sys                Wed Jun 18 06:13:53 2014 (53A16661)
psinknc.sys                Thu Jul 24 14:07:41 2014 (53D14B6D)
PSINProc.sys               Thu Jul 24 14:11:18 2014 (53D14C46)
PSINProt.sys               Thu Jul 24 14:12:11 2014 (53D14C7B)
nvvad64v.sys               Thu Sep  4 13:10:48 2014 (54089D18)
igdkmd64.sys               Mon Sep 29 13:51:21 2014 (54299C19)
NvStreamKms.sys            Thu Oct  2 21:39:09 2014 (542DFE3D)
PSINAflt.sys               Mon Oct 13 15:41:52 2014 (543C2B00)
PSINFile.sys               Mon Oct 13 15:44:42 2014 (543C2BAA)
PSINReg.sys                Mon Oct 13 15:47:12 2014 (543C2C40)
nvvadarm.sys               Sat Dec 13 02:16:06 2014 (548BE7B6)
dump_iaStorA.sys           Mon Oct 28 17:15:26 2013 (526ED3EE)
SynTP.sys                  Thu Jan  9 22:16:42 2014 (52CF661A)
Smb_driver_Intel.sys       Thu Jan  9 22:21:21 2014 (52CF6731)
btfilter.sys               Fri Aug  8 02:17:53 2014 (53E46B91)
nvlddmkm.sys               Thu Nov 20 18:01:23 2014 (546E72C3)
nvvadarm.sys               Thu Nov 20 18:16:18 2014 (546E7642)
[/font]
http://www.carrona.org/drivers/driver.php?id=GEARAspiWDM.sys
http://www.carrona.org/drivers/driver.php?id=MBfilt64.sys
http://www.carrona.org/drivers/driver.php?id=LGBusEnum.sys
http://www.carrona.org/drivers/driver.php?id=tbhsd.sys
rsvcdwdr.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=rikvm_38F51D56.sys
RrNetCapFilterDriver.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=TeeDriverx64.sys
http://www.carrona.org/drivers/driver.php?id=RtsPer.sys
SAlphaPS264.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=e22w8x64.sys
http://www.carrona.org/drivers/driver.php?id=SteelBus64.sys
http://www.carrona.org/drivers/driver.php?id=iwdbus.sys
http://www.carrona.org/drivers/driver.php?id=nvhda64v.sys
Qcamainx64.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=bwcW8x64.sys
http://www.carrona.org/drivers/driver.php?id=btfilter.sys
nvvadarm.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=SynTP.sys
http://www.carrona.org/drivers/driver.php?id=Smb_driver_Intel.sys
http://www.carrona.org/drivers/driver.php?id=nvvad64v.sys
http://www.carrona.org/drivers/driver.php?id=NvStreamKms.sys
http://www.carrona.org/drivers/driver.php?id=NNSNAHSL.sys
http://www.carrona.org/drivers/driver.php?id=PSKMAD.sys
http://www.carrona.org/drivers/driver.php?id=NNSPrv.sys
http://www.carrona.org/drivers/driver.php?id=NNSAlpc.sys
http://www.carrona.org/drivers/driver.php?id=NNSTlsc.sys
http://www.carrona.org/drivers/driver.php?id=NNSStrm.sys
http://www.carrona.org/drivers/driver.php?id=NNSPicc.sys
http://www.carrona.org/drivers/driver.php?id=NNSProt.sys
http://www.carrona.org/drivers/driver.php?id=NNSIds.sys
http://www.carrona.org/drivers/driver.php?id=NNSPop3.sys
http://www.carrona.org/drivers/driver.php?id=NNSSmtp.sys
http://www.carrona.org/drivers/driver.php?id=NNSPihsw.sys
http://www.carrona.org/drivers/driver.php?id=NNSHttps.sys
http://www.carrona.org/drivers/driver.php?id=NNSHttp.sys
http://www.carrona.org/drivers/driver.php?id=psinknc.sys
http://www.carrona.org/drivers/driver.php?id=PSINProc.sys
http://www.carrona.org/drivers/driver.php?id=PSINProt.sys
http://www.carrona.org/drivers/driver.php?id=igdkmd64.sys
http://www.carrona.org/drivers/driver.php?id=PSINAflt.sys
http://www.carrona.org/drivers/driver.php?id=PSINFile.sys
http://www.carrona.org/drivers/driver.php?id=PSINReg.sys
Hi John! No problem there, I am thankful that you care to take time. I just want to understand the issue myself and thought it would be good to log the events/ideas that crossed me as complete as I could.
As to the DMP files I tried to zip them (7z) but they are not allowed in this format.
Do you want me to upload the DMPs with the original names again?
Furthermore: I`ll do as you adviced and will uninstall the programs you mentioned. Then I`ll report if winio64.sys and ntiolib_x.sys are still there.
Best regards
Phil
Update: I`ll Deinstalled the following Programs (together with some other stuff like CyberlinkDVD):
- MSI Remind Manager
- MSI Supercharger
- MSI Dragon Gaming Center
- MSI Battery Calibration
- MSI BurnRecovery
The MSI programs I did not/could not deinstall are:
- MSI Fan Control as it helps me to keep the fans quiet (this version is portable / had not to be installed / contains no *.sys files)
- MSI System Control Manager (this is the only way to switch between dedicated GPU and on board GPU)
Update:
- I was not able to find MSI Live Update on my system?!
- winio64.sys is NOT in C:\Windows\System32\drivers (anymore)!
- NTIOLib_X64 is NOT in C:\Windows\System32\drivers (anymore)!
- old iTunes deinstalled -> actual iTunes installed
Update:
I did some integrity checking:
1.) on the C: Intel Raid 0 VolumeE
Error Scan
Scanned data : 244102 MB
Damaged Blocks : 0.0 %
Elapsed Time : 3:56
2.) on internal HDD: HGST
Error ScanScanned data : 953488 MB
Elapsed Time : 157:31
On the DMP files, you want to upload them in the .zip format.
Hi there and thank you for the infromation.
As to my problem - After all went well at first (see my last post), I had to face unexpected trouble yesterday in the evening. After the deinstallation of the MSI apps the overall performance of my GPU went down in an extreme way. In several programms I had massive frame drops due to downclocking of the GPU. Reinstalling drivers did not help.
In the end only the playback of a mirror image from Dec 24th fixed it. So it does not seem to be a hardware issue but some kind of throttlestop performed by one of the MSI apps...
I was really frustrated...
I try to deinstall the apps one at a time now... and will have to see. Of course I`ll load up the dumps...
Best regards
Phil
Hi!
I cought this DUMP with verifier on (again while ideling! I am working for an hour now... with verifier on - and no problem?!). For this time I kept the MSI Products but tried a new Anti-Virus-Program. Could you please check if ti was the 360 Anti-Vir? or could you tell how to see which driver crashed?
Best regards
Phil
P.S.: I had no bluescreen/restart without verifier since I deinstalled PANDA SECURITY and reinstalled iTunes and all Drivers and firmeware I could get
P.P.S.: I allready learned a lot thourgh this erros and through your posts and this forums! So Thank you very much!
Update: I downloaded Microsoft SDK: This is what I got. If I guess correctly, is this the network thing again?
ADDITIONAL_DEBUG_TEXT:
You can run '.symfix; .reload' to try to fix the symbol path and load symbols.
MODULE_NAME: nt
FAULTING_MODULE: fffff8024be16000 nt
DEBUG_FLR_IMAGE_TIMESTAMP: 545167e0
DUMP_FILE_ATTRIBUTES: 0x8
Kernel Generated Triage Dump
DV_VIOLATED_CONDITION: The miniport driver hasn't processed any NBL in the past 22 seconds.
DV_MSDN_LINK: NdisTimedDataHang rule (ndis) (Windows Drivers)
DV_RULE_INFO: 0x9200F
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
CURRENT_IRQL: 0
ANALYSIS_VERSION: 6.3.9600.17298 (debuggers(dbg).141024-1500) amd64fre
LAST_CONTROL_TRANSFER: from fffff80132357487 to fffff8024bf66aa0
STACK_TEXT:
ffffd000`430ae968 fffff801`32357487 : 00000000`000000c4 00000000`0009200f fffff801`32363c50 ffffe000`3d8492f0 : nt+0x150aa0
ffffd000`430ae970 00000000`000000c4 : 00000000`0009200f fffff801`32363c50 ffffe000`3d8492f0 ffffe000`3d849388 : VerifierExt+0x12487
ffffd000`430ae978 00000000`0009200f : fffff801`32363c50 ffffe000`3d8492f0 ffffe000`3d849388 00000000`00000000 : 0xc4
ffffd000`430ae980 fffff801`32363c50 : ffffe000`3d8492f0 ffffe000`3d849388 00000000`00000000 00000000`00000000 : 0x9200f
ffffd000`430ae988 ffffe000`3d8492f0 : ffffe000`3d849388 00000000`00000000 00000000`00000000 00000000`00000000 : VerifierExt+0x1ec50
ffffd000`430ae990 ffffe000`3d849388 : 00000000`00000000 00000000`00000000 00000000`00000000 ffffe000`3d9c11a0 : 0xffffe000`3d8492f0
ffffd000`430ae998 00000000`00000000 : 00000000`00000000 00000000`00000000 ffffe000`3d9c11a0 00000000`00000000 : 0xffffe000`3d849388
STACK_COMMAND: kb
FOLLOWUP_IP:
nt+150aa0
fffff802`4bf66aa0 48894c2408 mov qword ptr [rsp+8],rcx
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: nt+150aa0
FOLLOWUP_NAME: MachineOwner
IMAGE_NAME: ntoskrnl.exe
BUCKET_ID: WRONG_SYMBOLS
FAILURE_BUCKET_ID: WRONG_SYMBOLS
ANALYSIS_SOURCE: KM
FAILURE_ID_HASH_STRING: km:wrong_symbols
FAILURE_ID_HASH: {70b057e8-2462-896f-28e7-ac72d4d365f8}
Followup: MachineOwner
You've done a great job with the debugger!
Please see step E at this link to set your symbols: WinDbg Analysis Report
In most cases, when the system crashes the debugger will blame the module that owns the memory space that the crash occurred in. In this case it was nt (ntoskrnl.exe or ntkrnlmp.exe). When this happens we presume the following:
- we rule out 3rd party drivers (over 90% of BSOD's are due to this)
- we rule out hardware (less than 10% of BSOD's are due to this)
- we then look at Windows problems (less than 1% of BSOD's are due to this - as long as Windows Updates are fully up to date).
And, since ntoskrnl.exe/ntkrnlmp.exe is the kernel (core) of the Operating System - it has lot's of built in protections. As such, it's not likely to be at fault (and if it was, you'd be seeing many more problems other than the occasional BSOD).
We then look at the Stack Text to see if there are any 3rd party drivers there (in your case there aren't).
Then we look at the rest of the report.
In this case, we see evidence of Ndis related to the verifier enabled crash.
NDIS stands for Network Driver Interface Specification ( http://www.google.com/url?sa=t&rct=...=5ctIwCYU7vovM1VBl7sFAg&bvm=bv.82001339,d.eXY )
As such, we have to suspect something that's accessing the network.
We're now at the point where we need to extract a bit more info out of the memory dump. I use an automated program to do this, but you can do the same thing by using the command !analyze -v;!thread;r;kv;lmtn;lmtsmn;.bugcheck (type this in the box at the very bottom of the active debugger window) and then press Enter
So, looking at the memory dump below, I note that the winio64.sys and the NTIOLib_X64.sys are both present in the memory dump. I also see RTCore64.sys so it may be linked to something from MSI that you reinstalled. If so, what did you reinstall?
So, my question is - did this memory dump happen before or after you made sure that they weren't in C:\Windows\System32\drivers?
Please note that while 360 Anti-Vir is in the memory dump, it's not necessarily to blame (but we haven't ruled it out either).
It's not likely to be at fault though, because you were having BSOD's before you installed it.
The next thing we'll look at after the above stuff is these 3 drivers:
tbhsd.sys (more info on it here: Driver Reference Table - tbhsd.sys )
rsvcdwdr.sys (more info on it here: Rsvcdwdr.sys driver | What is Rsvcdwdr.sys file? )
RrNetCapFilterDriver.sys (more info on it here: Malware scan of rrnetcapfilterdriver.sys (RadioRip) 5270a06acf151cc862f418b0171b5f8ccbc59694 - herdProtect )
(FYI - they are merely the next oldest drivers in the debugger's output)
Analysis:
[font=lucida console]**************************Sun Dec 28 06:50:24.133 2014 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\122814-49609-01.dmp]
System Uptime:[B]0 days 0:25:29.959[/B]
BugCheck [B]C4, {9200f, fffff80132363c50, ffffe0003d8492f0, ffffe0003d849388}[/B]
Arguments:
Arg2: fffff80132363c50, A pointer to the string describing the violated rule condition.
Arg3: ffffe0003d8492f0, Address of internal rule state (second argument to !ruleinfo).
Arg4: ffffe0003d849388, Address of supplemental states (third argument to !ruleinfo).
MaxSpeed:     2500
[/font]
3rd Party Drivers:
[COLOR=RED][B]LGBusEnum.sys              Mon Nov 23 20:36:48 2009 (4B0B38B0)[/B][/COLOR]
GEARAspiWDM.sys            Thu May  3 15:56:17 2012 (4FA2E2E1)
[COLOR=RED][B]RTCore64.sys               Mon Mar 11 01:32:06 2013 (513D6C56)[/B][/COLOR]
360Box64.sys               Fri Nov 29 01:51:33 2013 (52983975)
360AntiHacker64.sys        Sun Apr 20 23:48:04 2014 (535494F4)
360AvFlt.sys               Tue Apr 22 23:54:35 2014 (5357397B)
360Camera64.sys            Mon Apr 28 07:39:27 2014 (535E3DEF)
360FsFlt.sys               Wed May  7 05:34:14 2014 (5369FE16)
RTKVHD64.sys               Tue Sep 16 06:44:17 2014 (54181481)
[/font]
http://www.carrona.org/drivers/driver.php?id=RTCore64.sys
http://www.carrona.org/drivers/driver.php?id=360Box64.sys
http://www.carrona.org/drivers/driver.php?id=360AntiHacker64.sys
http://www.carrona.org/drivers/driver.php?id=360AvFlt.sys
http://www.carrona.org/drivers/driver.php?id=360Camera64.sys
http://www.carrona.org/drivers/driver.php?id=360FsFlt.sys
Hi John!
First of all: Thank you for the hint concearning the debugger!
Then: I am afraid to say that - as I had this drastic throtteling issues with the graphics card after deinstalling the MSI programs - I reinstalled them all again to the result that the latest DMP file is had NTIOLib_X64.sys and WINIO64.sys present together with the reinstalled MSI Afterburner (the source of the RTCore64.sys).
As you see above I now start uninstalling MSI Programs one at a time (NTIOLib_X64 from MSI Supercharger ist allready gone) to see which effect this has on the graphics card. I presume that MSI Dragon Gaming Center has some sort of throttelstop effect on the graphics card... So lets see. I am SORRY that I reinstalled Afterburner again as well but I had to monitor the for the above reason.
The only positive thing I can say that - even though they were installed - none of the drivers (NTIOLib_X64.sys / WINIO64.sys / RTCore64.sys) are or were locates in the "C:\Windows\System32\drivers" folder. I hope this helps?
Third: Does it even make any sense to work on the next drivers you suggested (updating tunebite for example) while those two MSI drivers still hang out on my system? Don`t I have to try to sort them out first?
Once again best regards and Thank you for your help!
Phil
P.S.: I laughed so hard when I read your comments on your system specs. Seems like you have no bluescreens - but many other projects to work on regarding your notebook ;-P
Wow... One Moment! The drivers you mentioned...
They all belong to the same software: Audials one.
An this software made my system freeze yesterday (see the extraction of DMP below) - without bluescreen at least - but this was the only freez i expreienced in the last 5 days in normal mode (without having verifier on)...
Could this be a trail?
Best regards
Phila
Update:
I installed a actual version of Audials One so those drivers...
...should be recent now. Perhaps this helps?!
Best regards
Phil
Update: Verifier crash again. I analyzed it allready (the method you mentioned)
