Booting from DVD issue, "Reboot and select proper boot device".
muckpuck
5
Hi! I just burned a copy of the Windows 8 Developer Preview onto a DVD. I have created a partition for the new OS (because I don't want to install over Windows 7).
When Windows 7 is running and I pop in the DVD, the computer directly recognizes it as a runnable program. I'm also able to install Windows 8 when Windows is running.
But because I want to install it to another partition I need to boot from the DVD. But I can't. First it just ignores the DVD, and boots right into Windows 7. So I tried to force boot via BIOS. Then it just said "Reboot and select proper boot device or insert boot media in selected". Can someone please help me?
I have an ASUS N82J laptop, 4GB RAM, Nvidia GT335M, i3-350M processor, 500GB HDD.
Thank you in advance
    Windows 7 Ultimate x64
boohbah
Closed by request
cornwall,uk
157
im thinking it ignores the disc because the order you have for booting 7 is from hardrive first, if you press f1 or f8 or one of the f buttons at the black screen before 7 loads you will get the order of which to boot from first ,select disc and it should load the install screens .
    windows 7 /windows 8 Dev
muckpuck
5
Forgot to mention that booting from the DVD-drive is set to number 1 in booting order. Still doesn't see the DVD while starting :/
Thank you for the quick answer though :)
Dwarf
The Contemplator, (1963-2013)
Moderator
Doncaster, UK
638
Is the disk actually bootable? Your statement here would seem to confirm this as the problem.
Have you checked with a known bootable disk, such as a copy of XP, Vista, or Windows 7?
How did you burn the .iso image of WDP to disk?
    Windows 8.1 Pro RTM x64
    Dwarf Dwf/11/2012 r09/2013
    Intel Core-i5-3570K 4-core @ 3.4GHz (Ivy Bridge) (OC 4.2GHz)
    ASRock Z77 Extreme4-M
    4 x 4GB DDR3-1600 Corsair Vengeance CMZ8GX3M2A1600C9B (16GB)
    MSI GeForce GTX770 Gaming OC 2GB
    Realtek High Definition on board solution (ALC 898)
    ViewSonic VA1912w Widescreen
    1440x900
    OCZ Agility 3 120GB SATA III x2 (RAID 0)
    Samsung HD501LJ 500GB SATA II x2
    Hitachi HDS721010CLA332 1TB SATA II
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    XFX Pro Series 850W Semi-Modular
    Gigabyte IF233
    1 x 120mm Front Inlet 1 x 120mm Rear Exhaust
    Microsoft Comfort Curve Keyboard 3000 (USB)
    Microsoft Comfort Mouse 3000 for Business (USB)
    NetGear DG834Gv3 ADSL Modem/Router (Ethernet) ~4.0 Mb/sec (O2)
    IE 11
    Avast! 8.0.1497 MalwareBytes 1.75.0.1300
    Optical Drive: HL-DT-ST BD-RE BH10LS30 SATA Bluray
    Lexmark S305 Printer/Scanner/Copier (USB)
    WEI Score: 8.1/8.1/8.5/8.5/8.25
    Asus Eee PC 1011PX Netbook (Windows 7 x86 Starter)
muckpuck
5
Haven't tested with another DVD. Will do :)
Umm, like I always do. Open with WinRAR, and then copy over to the DVD. I know that sounds weird, but it has always worked perfectly fine when booting through DVD:s. Maybe I should try with a real DVD-burner just to be on the safe side xD
Dwarf
Moderator
Doncaster, UK
638
#8
That's the reason. I take it that you have extracted the contents of the .iso file and then copied the extracted contents to disk, correct?
    1440x900
    Gigabyte IF233
    IE 11
Dwarf
Moderator
Doncaster, UK
638
#10
That method works if you are making a USB installation stick, but as part of the preparation you have to make the stick active, i.e. bootable. With a CD/DVD, the only way of making it bootable is to burn the .iso image directly without extracting its contents first. A suitable program for this purpose is ImgBurn, available from The Official ImgBurn Website
    1440x900
    Gigabyte IF233
    IE 11
