Bluetooth Dongle Not Detecting Bluetooth Mobile
sri2000
Gone Crazy
Hi all this is my first post/question so bear with me if it hurts the rules :eek:
Ok now i bought this usb dongle today and installed it successfully on windows 8 for 4 hrs trying to make it connect my android phone to the pc using bluetooth but in vain. It worked one time but went of in an instant.
plz give me my fix. The drivers all have been installed correctly, and i have tried reinstalling with all the drivers available but it nvr worked plz give me a solution asap.
Regards,
Sri Vardhan
    Windows 8.1 Pro Update 1
    Dell
    Inspiron 530S
    64Bit X64 based Processor
    4.5GB Ram
    1GB - XFX ONE ATI Radeon HD 5450 - Plus Edition
    Inbuilt
    Dell Monitor
    1440*900
    1*Seagate 150gb + 1*Seagate 320gb
    3 x fans
    Dell Analog
    Dell USB Mouse
    1Mbps, 100kbps Download Speed
    Kaspersky, Norton, Avast, Bitdefender, but Switched off
archer
Hi Sri, Welcome to 8 forums.
On windows type "msconfig" in search field at the start menu and open MSconfig. Go to the Services Tab and search for services related to Bluetooth. If any of them are unchecked they will not load on Windows start so make sure you have checked them.
Keep us posted.
    Windows 7 x64/ Windows 8.1 x64
    Self Made
    Intel i5 2500K @ 3.3GHz
    Asus Z68 V Pro
    16GB DDR 3
    HIS 6870 ICEq edition
    Samsung 22" Display
    WD 1 TB
    Seagate 2 TB
    WD 320 GB
    coolermaster 750 W
    Coolermaster HAF 912
    TVS Gold
    Samsumg
    4 Mbps
    AVG 2013 IS
sri2000
Gone Crazy
yes i have tried it. it has been checked the bluetooth support service. Have been trying for almost 6hrs no luck plz tell me a way!
    Dell
    Inspiron 530S
    4.5GB Ram
    Inbuilt
    Dell Monitor
    1440*900
    3 x fans
    Dell Analog
    Dell USB Mouse
Make sure your mobile phone is turned on to accept the blue tooth connection. Most phones have the setting to off by default. Once set up correctly it should connect.
    Custom build
    AMD Phenom II X 4 965 BE
    Gigabyte GA-MA790X-DS4
    G-Skill 8 GB PC 8500
    AMD XFX HD Radeon 6790D
    Realtek HD onboard
    2l Samsung SyncMaster S20B300
    1600 X 900
    Seagate Barracuda 320 GB w/OS
    Cooler Master Hyper212 120mm
    Logitech G510
    Razor DeathAdder 3.5
    Custom build
    Realtek HD onboard
    1600 X 900
    Logitech G510
sri2000
Gone Crazy
yes i know that and i have tried evrythin possible sir.
    Dell
    Inspiron 530S
    4.5GB Ram
    Inbuilt
    Dell Monitor
    1440*900
    3 x fans
    Dell Analog
    Dell USB Mouse
sri2000
Gone Crazy
when i do the add devices thing it finds my mobile as "mobile Phone" not by the name wen i click connect it tells me to wait then shows the same angry try again we cudnt establish a connection msg
    Dell
    Inspiron 530S
    4.5GB Ram
    Inbuilt
    Dell Monitor
    1440*900
    3 x fans
    Dell Analog
    Dell USB Mouse
Is the bluetooth dongle you purchased compatible with your phone's OS...whether it be Droid, iOS or Windows?
    Custom build
    Realtek HD onboard
    1600 X 900
    Logitech G510
What's the make/model of your phone and the dongle your purchased?
    Custom build
    Realtek HD onboard
    1600 X 900
    Logitech G510
sri2000
Gone Crazy
well its not about the brand i have a lava android phone , a nokia asha and a nokia classic. i have tried evry setting possible!
    Dell
    Inspiron 530S
    4.5GB Ram
    Inbuilt
    Dell Monitor
    1440*900
    3 x fans
    Dell Analog
    Dell USB Mouse
sri2000
Gone Crazy
well there isnt a name for the dongle it just says bluetooth usb dongle the drivers are installed correctly and accrding to its ratings it has worked for evryone who purchased it xcept me
    Dell
    Inspiron 530S
    4.5GB Ram
    Inbuilt
    Dell Monitor
    1440*900
    3 x fans
    Dell Analog
    Dell USB Mouse
sri2000
Gone Crazy
    Dell
    Inspiron 530S
    4.5GB Ram
    Inbuilt
    Dell Monitor
    1440*900
    3 x fans
    Dell Analog
    Dell USB Mouse
archer
Replace the dongle. I think the dongle is bad.
    Self Made
    Asus Z68 V Pro
    16GB DDR 3
    Samsung 22" Display
    WD 1 TB
    Seagate 2 TB
    WD 320 GB
    coolermaster 750 W
    TVS Gold
    Samsumg
    4 Mbps
    AVG 2013 IS
Since the phone settings are correct according to you, then my guess would be that the dongle is the problem. Seeing as you say there is no brand name of the bluetooth dongle and I'm guessing it's using some random generic driver with no real specifications for what OS it's compatible for on the PC side of it. I would try a different bluetooth dongle, one that has great reviews and highly recommended. It may cost a bit more...but would be well worth it.
    Custom build
    Realtek HD onboard
    1600 X 900
    Logitech G510
sri2000
Gone Crazy
:what:
    Dell
    Inspiron 530S
    4.5GB Ram
    Inbuilt
    Dell Monitor
    1440*900
    3 x fans
    Dell Analog
    Dell USB Mouse
