Blinking power light
chefdementia
I've had Windows 8 sitting around since February, and got around to installing it yesterday. So far all is well, except for when I shut my computer off the power LED will keep flashing. At first I thought my computer was just in sleep mode, but after hitting a couple keys that was not the case. Is there a setting some where that would cause this. I know it's a minor issue but damn that LED is bright.
My systems specs
[h=1]Intel Core 2 Quad Q9300[/h][h=1]EVGA 123-YW-E175-A1 LGA 775 NVIDIA nForce 750i [/h][h=1]Seagate Barracuda 7200.10 ST3750640AS 750GB [/h][h=1]CORSAIR XMS2 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800[/h]
Yeah this machine is over five years old, working on getting a new one together soon.
    8 pro
alphanumeric
slightly off center
Gold Member
    Windows 10 Education 64 Bit
    Asus
    Thermaltake TR 620
    Stock heatsink fan
    Logitech Wireless K350 Wave
    80 Mbps Down 30 Mbps Up
Hello Chef, and welcome to Eight Forums. :)
In addition, your BIOS/UEFI settings may have an option to enable/disable this blinking night light.
What brand and model is your motherboard? I'll be happy to look up it's manual to see if I may be able to help spot the setting for this if there's one.
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
XweAponX
I think your Blinking Light may be some kind of Error indicator for your specific Motherboard.
You did not list what MB you have, if we know what it is, we can look up the error codes. Look for a pattern to the Flashing, two flashes, 3 flashes? Usually a Single Flash indicates that a stick of RAM is bad, try running Memtest on it.
    AMD 4400+/4200+
    2 GB/3GB
    GeForce 8400 GS/GeForce 210
    Hitachi 40" LCD HDTV
    "1842 x 1036"
    WD My Book 1140 USB Device
    Works 550w
    MSI "M-Box"
    Water Cooled
    Dell Keyboard
    Microsoft Intellimouse
    Cable Medium Speed
    Chrome/IE 10
    Eset NOD32 6.x/Win Defend
