Better no fan graphics card for upgrade
corei5
11
Hi,
I assembled my PC in mid 2010 and it's still runs OK for my purposes except that I feel that Firefox and other programs that I use feel somehow sluggish and I attribute this to the naive graphics card I'm using (AMD RADEON HD 5450) even with the latest Catalyst drivers. I picked this up on purpose because it has no fan (I'm not a gamer anyway).
Now that it's 2014, I'm asking a recommendation for a more powerful graphics card that uses no fan at all in order to enjoy more powerful graphics in Firefox, youtube, flash, photoshop,...etc without adding any extra noise.
Thanks in advance.
    Windows 7 x64
    Core i5 - Stock Speed
    Gigabyte GA-UD3P
    8 GB
    ATI Radeon HD 5450
    Samsung SyncMaster S22B300
    1920*1080
    Avast
popeye
United States
3,090
I sort of doubt that it is your sluggish problem especially with Firefox. That could be due to your internet connection.
What size hard drive and is it close to being full? Do you defrag it periodically?
With that said, check out the Zotac NVIDIA GeForce GT730 4GB.
    Windows 8.1 Pro 64-bit
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    8GB DDR3 PC3-12800 (800 MHz)
    HD4000 + GeForce GT 730M
    Realtek High Definition Audio
    1600x900 pixels
    Samsung SSD 850 EVO 250 GB
    ADATA SSD SP900 128GB
    90 watt brick
    Bluetooth
    Comodo
CountMike
Belgrade , Serbia
4,664
Most of newer video cards have adjustable fan speeds and in normal use are turning at very low speeds and are very quiet, quieter even than CPU and PSU and are normally inaudible yet if need be they speed up.
    Home made
    AMD FX 6350Be @4.8GHz
    Gigabyte GA-990XA-UD3
    8GB Kingston 1866
    MSI AMD R7 260 oc
    Silicon Power V70 240GB SSD
    Kingston V300 120GB SSD
    WD 750GB Green
    WD 500GB black
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    CM Dragon Tower
    CCM Nepton 140xl
    10/2 Mbps
    WD
corei5
11
Thanks for your suggestion. My connections is fine (around 7mbps), hard drive is spacious, De fragmentation is regular...etc. I just feel the weak point is the graphics card which I think should be upgraded to give a snappier interface. I'm not sure if I have to wait for Windows 10 to see graphics improvements without upgrading (since they switch to a flat design) but I'm not sure about that.
    Windows 7 x64
    Gigabyte GA-UD3P
    8 GB
    ATI Radeon HD 5450
    1920*1080
    Avast
corei5
11
The main reason that I'm trying to shy away from these cards as much as possible is that if the fan dies for any reason, I'm hosed and I have to get a new card!
    Windows 7 x64
    Gigabyte GA-UD3P
    8 GB
    ATI Radeon HD 5450
    1920*1080
    Avast
CountMike
Belgrade , Serbia
4,664
Well not really big problem, most are fans replaceable and I have an8 year old video card that still works.
Back to your problem, most gain with newer cards is in 3D applications like games etc., in 2D, years back, they all work same speed, about 300 MHz. About only things you can expect to be better are higher resolutions and better filters and better support for HD video. In those spheres, except for some rare, dedicated video cards your present one will be no worse than best new one. My newest one AMD R7 260 is actually a tad slower in 2D (couple %) than older one, HD3850 I just replaced. There is a way by changing BIOS in them to boost 2D speed by 100MHz or so but is a risky affair.
    Home made
    8GB Kingston 1866
    MSI AMD R7 260 oc
    WD 750GB Green
    WD 500GB black
    CM Dragon Tower
    CCM Nepton 140xl
    10/2 Mbps
    WD
MrShowdown
Jakarta, Indonesia
1,048
Usually, smaller GPU's (like the ones without any some sort of cover, just plain PCB) fans can be easily replaceable. Also, GPU fans rarely die out, especially in your case, not being used for heavy gaming.
    Windows 10 Pro x64
    Homemade PC
    AMD Athlon X4 760K
    MSI A88XM-E35
    4GB DDR3-1600
    AMD Radeon HD 6770
    Realtek onboard
    1366x768 - 1920x1080
    Seagate Barracuda 500 GB
    Power Logic 225X
    Power Logic Xenon Graphite-1
    AMD OEM fans
    Logitech K120
    Genius NetScroll 120
    6 Mbps
    Microsoft Security Essentials
    Laptop:
    Intel Celeron N2920 1.8 GHz
    4 GB DDR3-1066
    Intel HD Graphics
    500 GB HDD
    Windows 10 Pro x64
Helmut
123
#8
You don't need a new Graphics Card for those applications at all, just a waste of money. Windows 8.1/10 whatever is irrelevant. Replace it if you wish but it won't make a difference.
A decent Internet download speed is far more important along with adequate RAM, Software maintenance, being free of Malware and so on.
Graphics Cards in general at the lower levels have pathetic fans, sometimes odd sizes, on my last desktop they were for ever grinding to a halt every 2/3 years. Finally I replaced that card with a passive heatsink model.
