Solved Best way to share with other users on same PC?
way2ob2se
I have one Win 8.1 computer that husband and I share. Also a printer and two external backup drives. I have an account as owner/administrator, and have created a standard user account for daily non-admin use that I changed permissions for to be able to read/write each of the folders under This PC. But, the new account can't see them.
I've been reading about "Public Folders" and "Homegroup" but really don't know what way to go. Do I need a Homegroup because of the printer/external drives? Or should I use Public Folders? If Folders, where exactly would I save new items, like a document or song? Would they have to be saved in the User/Public folders and then automatically show up in a matching folder in the Library, but not really saved there?
I'm technically fairly illiterate, and my husband is whatever is worse than that...so I want it to be as easy to share as possible.
I guess, in a nutshell, I'm just not understanding this part of 8.1. :eek:
    Windows 8.1 (x64)
    HP Envy 700-010
    AMD A10-6700 APU
    MSI (if this is the same as BaseBaord)
    8 GB
    Radeon HD graphics
    Internet Explorer
    Norton
    Country Flag
    USA
    State/Region Flag
    us california
my2cents
Veni, Vidi, Vici
Hello way2ob2se,
After reading your post, I'm still a bit lost as to what you primary goal is when establishing two accounts in your current situation. Specifically, do you want to limit/restrict access to one account because it seems like you are try to give full access to the second account. Now, if my assumptions are correct, then why not just share the same account? Please understand that I am not trying to undermine your intentions but right now I'm just not understanding the logic. So, maybe you could try and reword it; however, if you think you have explained your issue clearly, then please wait for additional responses. For the record, my wife and I use the same acount on our single PC. Good luck in getting the response that your are looking for.
my2cents
    Intel G2020
    ASRock B75M-DGS R2.0
    8GBs @ 1333 MHz
    Samsung 840 EVO
    400w
    Occupation
    Happily retired early and living off my investment
way2ob2se
2-cents, I really appreciate the response. Let me try to clarify (and please let me know if what I'm aiming for isn't the right thing to do).
My new machine came with Win8 (now 8.1). I copied folders/files from my old Win7 machine and pasted them in the Documents, Pictures, Music, etc., folders on 8.1. If I log in with my original owner/admin account, everything seems fine.
Then, I created a new "standard" account for everyday use. I don't want the machine to always be logged in as Admin, because when hubby gets frustrated he's a multiple-button pusher without knowing what he's doing, or remembering what he did. I wanted this new user to be able to see/read/write all those same files (documents, pictures, music and such), but not be able to do any real damage to the system, like uninstalling or deleting system stuff. I went through the permissions of each folder, and granted the user account permissions at the root of each of those folders (under This PC - not C or D or anything like that) ... but the standard account still can't see them.
So, I wondered if I needed to be in a homegroup or move everything to Public Folders for the standard account to use them. There's also something I'm also unfamiliar with in "taking ownership." I'm assuming I don't want the standard account to "own" any of these folders/files. Right?
I'm looking for the two of us to share a standard account, and only use the password or run-as Admin account when necessary. We already have our documents in a file structure where we have His, Hers, and Ours folders. This "structure" for lack of a better word, worked great in Win7. But in Win8.1 I just can't seem to get this set up right. I'm probably missing something clearly obvious, but it sure isn't obvious to me at this point.
Thanks so much for your patience.
    Windows 8.1 (x64)
    HP Envy 700-010
    AMD A10-6700 APU
    8 GB
    Radeon HD graphics
    Internet Explorer
    Norton
    Country Flag
    USA
    State/Region Flag
    us california
DustSailor
Hello,
Just both you use the standard account, and use admin only when doing admin tasks. Additionally, you can still use the admin password on the standard account when doing anything through the elevation prompt, so you don't even need to log off.
In other words, you can install programs, etc. by just using the admin password while maintaining the additional security of the standard account (and there is a bit of security added when using a more restricted account vs a full admin).
hope this helps
Read this: Why use a standard user account instead of an administrator account?
    Windows 8.1 Pro with Media Center x64
    Name
    Dusty
    Custom
    Intel Core i7-3820 CPU OC @ 3.80GHz
    Gigabyte G1.Assassin2
    Corsair Dominator 16GB Quad Channel DDR3
    Nvidia by EVGA - GeForce GTX 670 4GB
    On board Creative SB X-Fi
    acer 24" H243H
    1920 X 1080
    Main 500GB Hybrid Drive @ 7,200RPM
    Secondary OCZ SSD Vertex 3 Max IOPS
    Silent Pro 1000w gold 80+
    Azza Hurrican 2000
    Liquid CPU cooler & fans
    Microsoft Comfort Curve 2000
    Tek Republic Wired Laser Mouse
    5ms Ping 5.15Mb/s Download .64Mb/s Upload
    Internet Explorer
    Defender, Malwarebytes
    Country Flag
    USA
    State/Region Flag
    us california
my2cents
Veni, Vidi, Vici
Hi way2ob2se,
Thanks for that rewrite! now I can clearly understand why you want to establish two unique accounts. I also see that DustSailor has already started to assist you, so please continue to work one-on-one with him and he'll get you through your issue. Good luck and thanks for that rewrite again!
my2cents
    Intel G2020
    8GBs @ 1333 MHz
    Samsung 840 EVO
    400w
    Occupation
DustSailor
^ Your answers are as good as mine. I'm just offering another option that might fit well with the problem. Keep it up! If anything, I should be listening to you. You've got a higher ranking than I do anyway ;)
And I'm not always around these parts.
Take care, mate!
    Name
    Dusty
    Custom
    acer 24" H243H
    1920 X 1080
    Azza Hurrican 2000
    Internet Explorer
    Country Flag
    USA
    State/Region Flag
    us california
way2ob2se
Thanks to both of you for your help. I'm fine with the two user account set-up. My problem remains: how can I allow the standard user to see/read/write/save documents, pictures, music, etc., that are currently under This PC. I've gone in as Admin and added the account with these permissions to the root of each, but that didn't work. The standard account still can't see them.
Do I need both accounts to be in a "Homegroup" to share the files?
Do I need to move all the files to the Public directory to share the files?
Am I missing a better option? I'm trying to make this idiot-proof when I'm the idiot. aaarrrgghhhh :confused:
    Windows 8.1 (x64)
    HP Envy 700-010
    AMD A10-6700 APU
    8 GB
    Radeon HD graphics
    Internet Explorer
    Norton
    Country Flag
    USA
    State/Region Flag
    us california
DustSailor
    Name
    Dusty
    Custom
    acer 24" H243H
    1920 X 1080
    Azza Hurrican 2000
    Internet Explorer
    Country Flag
    USA
    State/Region Flag
    us california
way2ob2se
Thanks for the info. I found out that I'd been missing a step, which I found in the link you provided, under the Troubleshooting section. I really appreciate it!
    Windows 8.1 (x64)
    HP Envy 700-010
    AMD A10-6700 APU
    8 GB
    Radeon HD graphics
    Internet Explorer
    Norton
    Country Flag
    USA
    State/Region Flag
    us california
DustSailor
:thumbsup:
Thanks for the reply :)
    Name
    Dusty
    Custom
    acer 24" H243H
    1920 X 1080
    Azza Hurrican 2000
    Internet Explorer
    Country Flag
    USA
    State/Region Flag
    us california
