Battery life?!?!?!?!?!?
Nambiaab
Hi. I run on windows 8. It is a great OS except for one thing that I need some help for. I can't find out where the battery life is anywhere! It isn't in the taskbar and it isn't in the Charms bar. It is really starting to annoy me now....:mad:
I have tried going into the notifications area and changing the behaviour of it but that doesn't work either. This is what shows up. Please help me!!!!BATTERY LIFE.PNG
MrShowdown
Do you have the battery drivers installed?
    Windows 10 Pro x64
    Lenovo Y520
    Intel Core i5 7300HQ
    OEM Lenovo
    4GB DDR4-2400
    NVIDIA GeForce GTX 1050
    Realtek HD
    Seagate 1TB 5400 RPM
    OEM Lenovo
    Logitech G502 Proteus Core
    100 Mbps
    PC:
    AMD Athlon X4 760K
    8GB DDR3-1866
    AMD Radeon RX 460
    Seagate 500 GB 7200 RPM
phillipduran
No I don't think so :think:
Sorry I'm not the most computer savvy person....
What is a battery driver?
It is software that communicates between the hardware (battery/charging hardware) and the OS. It is usually manufacturer specific.
What model of laptop are you using (HP 6560b for example)? you can usually find the model name/number around the bezel of the monitor screen or on a label on the bottom of the laptop. I've seen some that put the model label info underneath the battery.
    Windows 7
    Pssh. Who buys prebuilts?
    Intel Core i7-2600k 3.4 Ghz
    Asus
    8 GB
    NVIDIA GeForce GT 520
    Dual Asus 22" Widescreen
    1920 x 2160
    OCZ SSD boot drive. Spinny secondary drive.
    Diablotek
    Air
    Razer BlackWidow Toureny edition.
    Logitech
    50 down 10 up
    FireFox
    HAHAHAHAHAHAHA. AV is for noobs.
    I like Macs.
phillipduran
Are there some numbers after the TS such as 13sb or 44hr?
    Windows 7
    Asus
    8 GB
    1920 x 2160
    Diablotek
    Air
    Logitech
    50 down 10 up
    FireFox
    I like Macs.
phillipduran
Here is the driver download section for Packard Bell. You can check here, but I'm not seeing a driver for this unless it is a part of the chipset driver or mgmtengine driver. I think maybe there is a setting that needs to be changed or a another application that might have taken control of the battery life and displays it elsewhere. I'll take a look for this and get back to you.
Oops, forgot this.
Support Download
    Windows 7
    Asus
    8 GB
    1920 x 2160
    Diablotek
    Air
    Logitech
    50 down 10 up
    FireFox
    I like Macs.
phillipduran
Here ya go. Get into the Control Panel > Notification Area Icons > Click on "Turn system icons on or off"
Turn on the power icon and you should be good to go. This pic shows the power icon screen.
(control panel can be found in the metro tiles screen, Right Click in an open area and then left click on the All Apps circle in the lower right corner.)
    Windows 7
    Asus
    8 GB
    1920 x 2160
    Diablotek
    Air
    Logitech
    50 down 10 up
    FireFox
    I like Macs.
phillipduran
    Windows 7
    Asus
    8 GB
    1920 x 2160
    Diablotek
    Air
    Logitech
    50 down 10 up
    FireFox
    I like Macs.
phillipduran
    Windows 7
    Asus
    8 GB
    1920 x 2160
    Diablotek
    Air
    Logitech
    50 down 10 up
    FireFox
    I like Macs.
phillipduran
My guess then would be that Packard Bell has an app installed that is overriding the battery icon setting. See if there are any apps from Packard Bell installed that have something to do with management of the laptop.
There is the Packard Bell Launch Manager application. It might have battery settings.
    Windows 7
    Asus
    8 GB
    1920 x 2160
    Diablotek
    Air
    Logitech
    50 down 10 up
    FireFox
    I like Macs.
brummyfan
Yes, download and install from that link posted earlier by phillipduran.
    Win 8.1
    Acer Aspire E1-571
    i5-3230m
    Acer Type-2
    8GB DDR3 1333MHz
    Intel HD 4000
    High Definiton Audio Device
    Generic
    1366x768
    Samsung 850 Pro 256GB
    Generic
    QWERTY
    ELANTECH Touchpad
    12.68Mbps
    IE11
