Battery icon not showing up in taskbar notification area.
RajDhakate
actually i dont know in which category i should post this threat. so i posted it in general category.
i have installed Windows 8 on my notebook few days back. I didnt paid much attention in the starting but now it gives me trouble when my battery status is not being shown on the notification area on the taskbar. Is there any solution?
    Windows 7 32bit build 7600
    HCL Infosystem Notebook 28 PDC
    Intel Pentium Dual CPU
    1 GB
    Realtek
    Generic PnP Moniter
    1280x800
Coke Robot
Gold Member
Yep, right click on the Taskbar, Properties, and you should see Notification area. Click on Customize... It brings up the Control Panel and you should see blue text saying Turn system icons on or off. Click that. You should see the battery icon and be able to change that to on.
    ASUS
    AMD FX 8320
    Crosshair V Formula-Z
    16 gig DDR3
    ASUS R9 270
    1440x900
    x2 3 TB Toshibas
    OCZ 500 watt
    Microsoft Touch Mouse
RajDhakate
this is it. :/ not able to change it.
it becomes editable when notebook is on charging.
when its fully charged, it becomes like that.
    1 GB
    Realtek
    Generic PnP Moniter
    1280x800
FSeal
On laptops, a lot of internal hardware like the battery status is somewhat custom and needs a driver specifically for that laptop to be installed.
You can try looking on the manufacturers website for hardware drivers for that laptop and see if they have something. Usually the Windows 7 driver will work fine.
Sony is pretty good about putting all the drivers up for every laptop they sell for example...
    Windows 7/8
RajDhakate
not able to find any driver of this type :/
    1 GB
    Realtek
    Generic PnP Moniter
    1280x800
