Automatic restore points is not working in system restore
Hello Rocasan,
Double check to make sure that System Protection is turned on for your Windows drive.
Next, use the free program CCleaner to see what it shows for what restore points you may have like below.
Hope this helps for now, :)
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
Normally System Protection creates a scheduled restore point only if no other restore points have been created in the last 7days, and before significant system events such as a program, Windows Update, or driver installation.
Is your PC turned on long enough for a restore point to be automatically created. If it's turn off most of the time or not turn on for very long when running, then it may not have had a chance to create one.
Double check to make sure that the SR task (middle pane) for SystemRestore (left pane) in Task Scheduler has not been disabled.
In addition, check to make sure that Automatic Maintenance is turned on.
    Lumia 1520 phone
    Lumia 1520 phone
They work in Windows 8 as well. :)
    Lumia 1520 phone
Vadikan
It looks like the thread is going in the workaround direction without attempts to troubleshoot...
Absence of automatic system restore (SR) points may be caused by either of the following:
  • Task Scheduler is not working
  • Automatic Maintenance (AM) and/or SR tasks are disabled
  • Not enough space dedicated to SR points
So it's worth looking into these settings.
1. http://www.eightforums.com/tutorials/3047-sfc-scannow-command-run-windows-8-a.html. If some files can't be restored, copy C:\Windows\Logs\CBS\CBS.log to the desktop, zip it up and attach.
2. Unzip the attached CMD-file, right-click, Run as administrator.
3. Attach diag.txt from the desktop.
Vadim
  • sched-diag.zip
    Windows 8 Pro x64
    HP Pavilion dv7t (17.3'', i7-2630QM, HD 6770M 1Gb, 8Gb RAM, 2 SSD@120Gb + 1 HDD@750Gb)
Rocasan,
As Vadim pointed out, what I recommended was a workaround for you to be able to have restore points created when you like.
To actually fix this, you may need to refresh or reset Windows 8 if you do not have a restore point dated before this wasn't working that you could use.
Personally, I would recommend to use the workaround for now to avoid a refresh or reset until you have time to do them.
    Lumia 1520 phone
rocasan
JUST A REMINDER :
I received this HP Notebook g6-2237us, on March 19th, 2013, from Hewlett-Packard.
Since that day I have had:
5 Resettings with the help by telephone from HP technicians, due several problems in operating the Notebook.
Installation of the OS by HP technician (free House call), using the CDs provided Free of charge by HP, as I could not get the R
recovery disks the regular way.
Sent the HP Notebook to HP facilities in La Vergne, Tenn., THREE (3) WEEKS AGO, to change the "connectivity card" as I was having continue problems with Internet.
Also, they reinstalled the OS, ONE MORE TIME, as I was having problems using the System Restore (Restoration UNSUCCESSFULLY....).
Then, After I received the "repaired Notebook" from La Vergne on July 24th, 2013, I started having problems with the screen: when I started up the screen was blinking ALL THE TIME every 3 seconds, for 2 days. I contacted the HP Case Manager and I was told to send the Notebook to La Vargne "for repair". During these 2 days I kept trying to get the screen to normal using functions keys F9 and F10 keys individual and together until I could enter the country until it started working again.
So, as you can see it does not pay to do another reinstall or reset .
Thank you.
I'd say that if it's still under warranty, then I'd be asking for a new replacement. There's some defect with that one.
    Lumia 1520 phone
Vadikan
To: Vadikan,
I already had ran sfc /scannow twice and no errors found.
Good for you, but it's not clear why you ignored the rest of my instructions. It's up to you, though, whether to use the workaround or just refresh/reinstall the OS or even send it back to HP, given other problems of which you informed us suddenly in a form of reminder o_O
    Windows 8 Pro x64
