Autoloads wrong driver for printer on wireless network.
1
Windows detects my Ricoh AC104 on a wireless network but insists it's an HP 5Si MX and installs that driver. When it adds the printer, it loads the driver automatically and without choice or prompt. Perhaps the misidentification has something to do with the printer driver in between (Hawking HMPS1U). I need to force it to use the printer driver from Ricoh, but I've had no luck so far. Some things I've tried:
1. There's an installation program with the Ricoh driver, but it doesn't see the printer on a wireless network.
2. Going to the advanced options for the printer on the device manager, I can see the driver info but Windows will not permit changes. I tried as Administrator also. No difference.
3. Attempting to update the driver just leads to Windows telling me the (wrong) driver is up to date.
Any thoughts would be appreciated. Thanks in advance.
alphanumeric
slightly off center
Gold Member
Got to Devices and Printers and try the Add Printer option. If that works and you can get it setup correctly, you can then delete the other incorrect one.
    Windows 10 Education 64 Bit
    Asus
    Thermaltake TR 620
    Stock heatsink fan
    Logitech Wireless K350 Wave
    80 Mbps Down 30 Mbps Up
play2mefish
162
Using the Add printer option, install the printer to a local port...LPT1 or USB whether it exists or not. Once the driver is installed on the workstation even though it is pointing to LPT1 or USB, you can then go in and change the port to point to the ip address of the wireless printer. That should do it.
    Windows 8 Pro
    ASRock 990FX Killer
    AMD FX 8320
    ASRock 990 FX Killer
    32gb
    Gigabyte GTX 750i
    Realtek (Stock on MB)
    ASUS 27 HD Monitor & a 37" LCD HD TV Screen (For movies)
    1 250 GB SS hard drive for OS
    1 1TB hard drive for data / mirrored to a second 1 TB hd.
    650W
    No name tower
    Enermax Liqtech 240
    Logitech
    Logitech
    Dnload 10.48 Upload .48
    IE 11 and Chrome when IE doesn't work
    F-PROT
