Auto sign-in doesn't work if remote connection enabled
Amphor
5
I would like for my computer to sign in automatically with my Microsoft account, however, when I enabled Remote Desktop Connection (for I would also like to be accessed remotely), the automatically sign-in function doesn't work, because sign-in screen is now set by default to log in with local account rather than Microsoft one. However, I do not possess one, and if I tried to create on and make it sign in automatically, the screen said wrong username or password. Which I don't understand at all
24,025
    3 x 27" Asus VE278Q
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
Amphor
5
No, it is available to select, but by default the "local or domain account" option is selected on the start-up screen's sign-in options. When remote Desktop was off, there were no "sign-in options" at the start-up screen at all and everything worked like a treat
24,025
Are you able to go through and change the settings again to the MS account and re-enter the password for it work?
    3 x 27" Asus VE278Q
    Logitech MX Master
    Lumia 1520 phone
Amphor
5
I haven't change the settings of my MS account at all, i just enabled remote desktop eature, which messed with y automatic sign in since Remote Deskop feature appears to be needing some kind of local or domain account
24,025
    3 x 27" Asus VE278Q
    Logitech MX Master
    Lumia 1520 phone
Amphor
5
No i dont think you understood me. I am not trying to remotely auto-login to windows, it's just that "normal" windows wouldn't let me auto login. "Go ahead and change the settings to set it again for your MS account to see if that may help." set what again to my MS account?
24,025
#8
    3 x 27" Asus VE278Q
    Logitech MX Master
    Lumia 1520 phone
24,025
#10
I do have RDC turned on, and I'm still able to set Windows to sign in to my MS account automatically at startup.
Please go through those steps to turn off, then turn back on to setup auto sign in at startup again to see if it may toggle it to work again.
    3 x 27" Asus VE278Q
    Logitech MX Master
    Lumia 1520 phone
