Audio Alerts Disrupt Java Audio While Live Streaming
tsmerling
When I live steam video in Windows 8/Chrome, using Adobe Flash, the audio portion is silenced each time I receive an audio prompt from my system. When I say "audio prompt" I mean a beep that I believe provides some sort of notification. The video continues, but all sound disappears for a few minutes when it then reappears. I have a dual boot system. The problem only exists in Windows 8. In Windows 7 I do not have this problem. My Chrome is fully updated, which means, I believe, that my Adobe Flash is also current. I disabled (or at least attempted to disable) audio alerts in Windows 8 and in Outlook 2007 and GMail (my email clients), but the audio alerts persist as do the disruptions of Java Live streaming audio. Any ideas or suggestions for fixing this problem - either by disabling all audio prompts or solving the problem of sound disruption in Java Live Streaming.
caperjack
Just the Janitor
2,627
hi,on your desktop ,using your mouse highlight the start icon lower left corner ,and right click on and go to control panel/sound/ click the sound tab and check off no sounds,and click for no sounds in sound scheme
    win8.1.1 enterprise
    Hinze57
    AMD FX 6100 6core 3.30gHz
    gigibyte ga-78lmy-s2p
    4gig ddr3
    Radon hd5000 Series
    onboard realtek hd
    19" viewsonic/ 22"Samsung
    1680x1050
    128gig ssd Kingston
    80gig WD 10000 rpm spinner
    micro
    microsoft curve 200
    Logitech wireless M215
    high speed 20
    ie 11
    windows defender
    updated enterprise apr 2/14
tsmerling
The Problem Persists
Thank you for the response. I tried to disable sounds as you described, but I still receive audible alerts (a beeping sound) and my audio is still disrupted when playing videos with Java. Is there something I am overlooking?
caperjack
Just the Janitor
2,627
an assumption only,if windows sounds are disable then it has to be another program making the sound ,one would think anyway ,its been years ,but i kind of remember this from the past ,and a person had same problem ,but i cant remember if it was a virus or just another program that was running all the time in the background, check your computer viruses
    win8.1.1 enterprise
    Hinze57
    4gig ddr3
    Radon hd5000 Series
    onboard realtek hd
    1680x1050
    128gig ssd Kingston
    micro
    microsoft curve 200
    high speed 20
    ie 11
    windows defender
