ATI Radeon HD3450 512mb AGP
Youlooked
I can't install the drivers, when i run the setup it only installs AMD Catalyst Install Manager, no drivers the ATI Techonologies folder is empty. I tryed installing it manually from device manager but it says "The driver selected for this device dose not support this version of Windows". I really hope that i don't have to revert to Windows 7.
Mark Phelps
Goto the link and use the pull-downs to select your graphics card and the version of Win8 drivers you want (32-bit or 64-bit): AMD Graphics Drivers & Software
BTW, ATI no longer exists; they were bought out by AMD. The folder on my "C" drive in Win8 is "AMD", not "ATI".
UPDATE: on that same page, you will see links in the lower right for the HD4000 - HD2000 series. You can try those instead of using the pull-downs.
But then, I recalled you said you had an AGP card -- and I don't think these work for AGP cards, sorry.
bobkn
Which drivers are you trying to install?
The latest ones for AGP cards only list support through Windows 7:
AMD Catalyst
If they are real Windows 7 drivers (WDM 1.1), they may work for Windows 8 as well. Getting them to install may be a little tricky. (Compatibility mode?)
    Window 8 Pro
    homebuilt
    I7-3930k
    Asus P9X79 Pro
    16 GB Gskill DDR3-2133
    eVGA GTX 680
    Soundblaster Zx
    Asus PA246Q
    1920X1200
    Corsair Force GT 120GB
    WD Cavair Black 1.5TB
    PC Power & cooling Silencer 750
    Silverstone FT02B-W
    Noctua NH-D14 w/ PWM fans
    cheap Logitech USB wired
    old 5 button Microsoft USB optical
    6Mb cable
Brooklyn567
Do you even need the drivers? Windows 8 drivers should be more than adequate for an AGP card..
    HP G60
    3 GB
    Nvidia GeForce 8200M G
    1366 x 768
    Chrome and Chromium
    Avast Free & Malwarebytes
