ATI Radeon 3650 HD PCIe problem
flufyy
Hi everyone,
I have formated my laptop and i've installed windows 8,
After i finished with the drivers and programs i've tried to play a game ( World of Warcraft),
i had some problems, the text doesn't appeared normaly, it appear with a blur effect or something like that.. the text wasn't displayed corectly.
Which can be the problem?
i've installed that driver, same problem:-?
here is a picture how the problem looks like : p1.PNG
and here how the text must look like: p2.PNG
Ya, that's not a driver problem. It looks to me like you have some kind of Arabic or other Mid-Eastern type of language set for Windows.
I'm in the US and fortunate enough that MS is also based here, so it is not necessary for me to deal with languages.
You can look into setting the proper Windows language for what you desire, along with the correct keyboard support for it.
I wish I could help you better than that, but I'm unaware how.
If you look at the first white line (Soulbound) it looks quite similar to the other picture. It's just missing a whole bunch of parts. I think it's just artifacts which seems to be common in windows 8 unless you get a good driver.
Have you tried updating DirectX?
can't find any directx website to download it :|
i've searched on google and microsoft for a directx for windows 7 x64 but couldn't find any links
You can type dxdiag in the start menu then press Enter. What does it say for your Language?
Seems like WoW is the issue itself, to me. Patch it to latest if it is not already. Other games work fine, right?
Nothing at all to do with it, but you should install the latest bios update for your board. 2008 is a little old and they probably made advancements.
Edit: I know the problem. You have a laptop and not a PCI-e card. Give me the hardware id of your graphics adapter and I'll mod the 12.3 WHQL for you so it installs.
In device manager, right click it. Properties. Details tab. Change the dropdown to say Hardware ids. Copy/paste results to here. (No screenshots please, for this.)
no, other games work not fine.
Have a problem with Pro Evolution Soccer 2012 too.
The problem is that on the field appear black triangles.
Pci\ven_1002&dev_9591&subsys_9035104d&rev_00
pci\ven_1002&dev_9591&subsys_9035104d
pci\ven_1002&dev_9591&cc_030000
I just noticed you have 64 bit Windows and not 32. I can still make it but you will be much better off just finding a laptop driver to install for 64 bit.
guys, i'll give up
I will format my laptop and install windows 7
I'm waiting for a better verision of windows 8.
but thanks for your help
