Any way to lock "advanced startup options"?
fhuge
6
My Dell Latitude 10 tablet runs Windows 8. I have created a standard user account and want to forbid the user from accessing the "advanced startup options", which he might use to go to safe mode and reset my tablet. How can I do it? Thanks.
    Tablet
    Dell Latitude 10
alphanumeric
slightly off center
Gold Member
You might be able to do that in the Group Policy Editor.
    Windows 10 Education 64 Bit
    Asus
    Thermaltake TR 620
    Stock heatsink fan
    Logitech Wireless K350 Wave
    80 Mbps Down 30 Mbps Up
DavidY
Active Member
955
I think you won't be able to stop access to Advanced Startup for one user, because one way to get there is from the Login screen itself, before you've actually logged in as any user (whether Administrator or Standard).
(You right click on the "power button" icon that's in the bottom-right corner of the login screen, and hold the Shift key down as you click on Restart.)
Once in Advanced Startup, some options seem to require Administrator access, but when I tried it just now, I could get a long way into Reset before I chickened out (the screen where you choose whether you just want to wipe the Windows partition) without it asking me for a password.
I certainly got further than Step 3 in this Tutorial, which is when I expected to be asked for an Admin-level password. (My PC has both Admin- and Standard-level accounts, all with passwords.)
http://www.eightforums.com/tutorials/2302-reset-windows-8-a.html
However I was doing this with a Windows Setup DVD in the CD drive; it may be different if the user is accessing files on the local PC's Recovery Partition instead and doesn't have access to a Setup DVD. But it's not hard to get hold of the images to make a Windows Setup DVD - for one thing the Windows 8.1 Preview currently has ISO versions which you can download freely, which I strongly suspect would have the capability to Reset your computer and lose your information.
    Windows 8.1, 10
Why do you associate with people you can't trust ?
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Package Socket FT1 BGA
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
    Avast Internet Security
fhuge
6
Yeah, you can definitely reset your pc without providing a password, through advanced startup - troubleshoot - reset your pc. I have tried this before as a standard user.
    Tablet
    Dell Latitude 10
fhuge
6
Is it something available only in Windows 8 pro? I typed gpedit.msc in "Run" and it said there is no such thing. My tablet runs windows 8 standard.
    Tablet
    Dell Latitude 10
DavidY
Active Member
955
#8
I think this is correct - Group Policy editor is in Windows 8 Pro (and Enterprise) but not Windows 8 Standard.
    Windows 8.1, 10
alphanumeric
slightly off center
Gold Member
#9
Yes it looks like its only available with Pro or Enterprise, I have 8 Pro. Sorry. :(
    Asus
    Thermaltake TR 620
    Stock heatsink fan
fafhrd
Active Member
Portsmouth Hants
772
#10
Autologon as standard user - thus bypassing the logon screen? Netplwiz in start screen etc - give the standard user a password that is only known to the administrator.
No that's flawed, you would have to also disable the restart option if you logged out or tried to switch user.
    HP COMPAQ Presario CQ57
    inbuilt
    4GB
    ATI
    notebook
    1366x768
    Seagate ST9500325AS
    Google drive 15GB
    Skydrive 25GB
    BT Cloud
    external 20v
    pretty good
    inbuilt
    touchpad
    Chrome Canary usually
    no Start menu modifications
fhuge
6
#11
So it seems that isn't quite possible. Anyway, thanks so much for your help.:)
    Tablet
    Dell Latitude 10
DavidY
Active Member
955
#12
The only thing I wondered about was whether encrypting the drive with Bitlocker might help?
I think it's possible to use TPM (or something??) so that a standard user can log into the PC with just their ID without knowing the full Bitlocker keys.
I know that once you've encrypted the drive, you have to manually suspend encryption before doing certain tasks, which might involve entering the Recovery password.
However there are several things against this...
  • I don't know enough about Bitlocker to recommend it
  • You'd need to upgrade to Windows 8 Pro to get Bitlocker and
  • You may not have the right hardware to use Bitlocker in that way
  • My suspicion is that a Reset might still be able to wipe a Bitlocker'd PC (what I've read suggests that some configurations allow this and some don't; but I don't know which is which).
I'm not sure it's a solution, but thought I'd mention it, in case someone who knows about Bitlocker chips in.
    Windows 8.1, 10
XweAponX
    AMD 4400+/4200+
    2 GB/3GB
    GeForce 8400 GS/GeForce 210
    Hitachi 40" LCD HDTV
    "1842 x 1036"
    WD My Book 1140 USB Device
    Works 550w
    MSI "M-Box"
    Water Cooled
    Dell Keyboard
    Microsoft Intellimouse
    Cable Medium Speed
    Chrome/IE 10
    Eset NOD32 6.x/Win Defend
