Any way to get context menu on right click for Start Screen
pparks1
I pinned an application to my start menu, occasionally I need to run that app with Admin privs. All I can find in the Start Screen is the "Run As Admin" option that appears at the bottom of the screen.
It's a real pain to have to click the app near the top of the screen and then slide all of the way to the bottom for "run as admin".
Am I out of luck on this one...aside from pinning it to taskbar in Desktop (whch is probably where it belongs anyway)?
    Windows 7
    Self-Built in July 2009
    23" Acer x233H
    Intel X25-M 80GB Gen 2 SSD
    Corsair 620HX modular
    Antec P182
    stock
    ABS M1 Mechanical
    Logitech G9 Laser Mouse
    15/2 cable modem
pparks1
Ivo,
Thanks, the CTRL-SHIFT-Click method indeed does work. It's still a pain because now I have to use both hands, one on the mouse and 1 on the keyboard, but it's better I guess than scrolling all over the screen.
Like most things, in Windows 8 I would simply do this at the desktop so I could continue to do it the way that is familiar and works well.
    Windows 7
    23" Acer x233H
    Antec P182
    stock
    ABS M1 Mechanical
    15/2 cable modem
mdmd
Closed as requested
Since the Start Screen and ALL APPS are WinRT and not Win32,
(the desktop is Win32)
things are a little different.
...but 2 clicks to launch anything is not any different than
launching the CLASSIC start menu and right clicking (for context menu)...
a link...
with Admin...
or...
Unless you install a customized icon dock launcher...
on the desktop.
    Server 2012 / 8.0
    Intel i7 QuadCore 3770k
    Asrock Extreme 4
    16GB Crucial Ballistix
    intel embedded gpu
    Sound Blaster Z
    AOC / Westinghouse
    Plextor pcie msata
    Rosewill Silent Night 500W Fanless / PicoPSU
    open bench - no case enclosure
    Silverstone HEO2 Passive Silent
    logitech washable K310
    logitech wired
    ie / maxthon
    Totally silent. No fans at all.
mdmd
Closed as requested
I was bored, so I did a few posts.
:confused:.
    Server 2012 / 8.0
    Asrock Extreme 4
    intel embedded gpu
    Sound Blaster Z
    AOC / Westinghouse
    Plextor pcie msata
    logitech wired
    ie / maxthon
pparks1
a link...
with Admin...
or...
on the desktop.
But when I have a shortcut on my desktop, I can right click once, and select run as admin without having to move my mouse across the entire screen. I like that much better.
    Windows 7
    23" Acer x233H
    Antec P182
    stock
    ABS M1 Mechanical
    15/2 cable modem
topgundcp
Can you just locate the executable for the app->Properties->Compatibility then put a tick on "run this program as an Administrator"
    Home Brewed
    I7 4970K OC'ed @4.7 GHz
    MSI-Z97
    NVIDIA GeForce GTS 450
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    Logitech Performance Mouse MX
    35/12mbps
XweAponX
You trying to get the Properties to pop up from the Start Screen? Seems there is yet something else you can't do. Hm, never tried it, all it does is bring up the bar on the bottom.
    AMD 4400+/4200+
    2 GB/3GB
    GeForce 8400 GS/GeForce 210
    Hitachi 40" LCD HDTV
    "1842 x 1036"
    WD My Book 1140 USB Device
    Works 550w
    MSI "M-Box"
    Water Cooled
    Dell Keyboard
    Microsoft Intellimouse
    Cable Medium Speed
    Chrome/IE 10
    Eset NOD32 6.x/Win Defend
pcRat
Could you move that application tile to the 3rd tile from left in bottom row on Start screen? Right click and move down to Run as Administrator
    i7-3770K
    ASRock Z77 Extreme4
    16 GB
    onboard
    17" 24"
    1 TB WD
    550w
topgundcp
May be you are not following what I am trying to say.
  1. Right click on the application tile
  2. Instead of clicking on "Run as admin", Click on "Open File Location".
  3. Right click->Properties->Compatibility and set it to "run this program as an Administrator"
  4. Now even you left click on the tile, the program will run as admin.
    Home Brewed
    MSI-Z97
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    35/12mbps
HippsieGypsie
It's Gururrrrrr8!
I had few exe's on my 8 side until I got rid of 7 to notice this. As soon as I can rep you, you get one! I learned something. :) You are surely mastering the system. :thumb:
And yet another plus for Windows 8/8.1 Start Screens. :D
    8.1 Pro X64
    Acer T690
    Intel Pentium D Dual Core
    Acer/Intel E946GZ
    2GB (max upgrade)
    Acer AL1917W A LCD
    1440 X 900
    Thumb drives
    Standard 250 watt
    Dual case fans + CPU fan
    Acer Windows PS/2
    Wireless Microsoft Arc
    54mbp/s
    IE11
    Defender
XweAponX
Yah, I guess if hes trying to run the EXE elevated, that'll work, good idea.
    AMD 4400+/4200+
    2 GB/3GB
    "1842 x 1036"
    Works 550w
    MSI "M-Box"
    Water Cooled
    Dell Keyboard
    Cable Medium Speed
    Chrome/IE 10
lehnerus2000
You could already do that with shortcuts in W7.
    Windows 7 Ultimate SP1 (64 bit), Linux Mint 18.3 MATE (64 bit)
    n/a
    AMD Phenom II x6 1055T, 2.8 GHz
    ASRock 880GMH-LE/USB3
    8GB DDR3 1333 G-Skill Ares F3-1333C9D-8GAO (4GB x 2)
    ATI Radeon HD6450
    Realtek?
    Samsung S23B350
    Western Digital 1.5 TB (SATA), Western Digital 2 TB (SATA), Western Digital 3 TB (SATA)
    Tower
    Wired Optical
    Linux Mint 16 MATE (64 bit) replaced with Linux Mint 17 MATE (64 bit) - 2014-05-17
    Linux Mint 14 MATE (64 bit) replaced with Linux Mint 16 MATE (64 bit) - 2013-11-13
    Ubuntu 10.04 (64 bit) replaced with Linux Mint 14 MATE (64 bit) - 2013-01-14
    RAM & Graphics Card Upgraded - 2013-01-13
    Monitor Upgraded - 2012-04-20
    System Upgraded - 2011-05-21, 2010-07-14
    HDD Upgraded - 2010-08-11, 2011-08-24,
HippsieGypsie
It's Gururrrrrr8!
Thank you. Yes, I knew that. What I wrote wasn't fully explaining. I should have wrote " I had very few exe's on my 8 side until I got rid of 7 to notice this on the Start Screen menu of 8 and 8.1".
Non-executable tiles, of course, have less options within the menu.
Tiles/live tiles are desktop icons "reimagined" for use on the Start Screen. Far more useful and implemented IMO.
    8.1 Pro X64
    Acer T690
    Acer/Intel E946GZ
    2GB (max upgrade)
    Acer AL1917W A LCD
    1440 X 900
    Thumb drives
    Standard 250 watt
    Acer Windows PS/2
    54mbp/s
    IE11
    Defender
