Solved antivirus opinions sought
jimbo45
Some URL addresses that I use frequently were blocked MSE
So I had to install Avast to solve my problem…
Hi there
If these URL addresses were blocked by MSE
1) you weren't running Windows 8 --no such animal as MSE on W8
2) the URL's were blocked obviously for a reason -- you can set exceptions though.
If AVAST allowed access while MSE didn't then it also proves my point --What USE is this type of AV system if every time a URL is blocked you find another program to get round it.
Please understand how W8 Security actually works before mentioning MSE blocks a URL.
What can sometimes happen is that Windows defender in W8 will issue a WARNING message saying that a program or file isn't commonly downloaded and you are given the choice to download it or not. - I think that's quite a decent feature.
Cheers
jimbo
    1 X LG 40 inch TV
    2 X 3 TB sata
    5 X 1 TB sata
    0.12 GB/s (120Mb/s)
dj07
Avast will be fine, I’m also using it with Immunet. (Immunet – Just for adding extra layer of protection). Actually I have not heard much about AVG that's why can't say anything about that.
    xp
azasadny
Moved to ten*****s.com
    Win 10 Pro 64bit
    Corsair M65 wired
    85MBps DSL
    Chrome and Edge
    1GBps Ethernet ports
