an error while setup , please need help fast.
8
Hello everyone!
while I was installing windows 8 pro 64x I had this little problem
(Windows cannot be installed to this disk. The selected disk has an MBR partition table. On EFI systems, Windows can only be installed to GPT disks)
any suggestions??
    4 GB
theog
Gold Member
5,591
    ME, XP,Vista,Win7,Win8,Win8.1
    Notebooks x 3
    Desktops x 5
    Towers x 4
theog
Gold Member
5,591
Microsoft said:
Make sure you’re on the PC you want to upgrade. This must be a PC that is currently running Windows 7, Windows Vista, Windows XP with Service Pack 3 (SP3), Windows 8 Release Preview, Windows 8 Consumer Preview, or Windows Developer Preview. (Windows 8 Setup checks that your PC meets all system requirements before it installs Windows 8.)
Have your product key handy. You can find it in your online order information, in the confirmation email for your purchase, or on the packaging. The product key will look something like this:
XXXXX- XXXXX- XXXXX- XXXXX- XXXXX
Make a backup of everything you want to keep. Save it somewhere you can get to it later, like an external drive or a DVD.
Restore Backup User and System Files - Windows 7 Forums
http://www.eightforums.com/tutorials/9044-backup-restore-files-folders-windows-8-a.html
    Notebooks x 3
    Desktops x 5
    Towers x 4
8
I don't have an operating system on pc now and even if I have the only solution that is suggested requires me to format all the darh desk
so how can I back up my files?
    4 GB
theog
Gold Member
5,591
#8
Why did you delete the OS?
    Notebooks x 3
    Desktops x 5
    Towers x 4
8
#9
I had a windows 8 debugged and I wanted to install a x64 pro version so I had to delete the old operating system and that was when I had the problem
    4 GB
theog
Gold Member
5,591
#10
Reinstall the Windows 32 & backup.
Than do a clean install.
Welcome to EightForums.
Clean the HD Drive, using Step one in this tutorial:
SSD / HDD : Optimize for Windows Reinstallation - Windows 7 Forums
Than type> convent gpt
& than Reboot PC to install.
How to install with a uEFI BIOS:
http://www.eightforums.com/tutorial...e-firmware-interface-install-windows-8-a.html
    Notebooks x 3
    Desktops x 5
    Towers x 4
8
#11
I've already lost my files
that's not my problem any more
I get an error while loading the windows cd
I reinstalled the win 32
but when I tried to get in again to do step one
I get the error 0xc00000e9
now what to do?
    4 GB
8
#12
I've already lost my data so that doesn't matter now
the problem is that after the whole hard is new
I get the error 0xc0000185 or the error 0xc000009
so I can't install windows what can the problem be with?
    4 GB
theog
Gold Member
5,591
#13
Where do you buy your DVD from?
    Notebooks x 3
    Desktops x 5
    Towers x 4
sajadwani
2
#15
I have problem in installing windows 8 through windows, it can run from startup boot. but it will clean my disk. i want to upgrade it.
when it try to open windows 8 setup. it pops up this error
"use the other installation disc that says 64-bit. when you insert it, windows setup will restart automatically."
My current version windows 7 64-bit, trying to install windowss 8 pro 64-bit
Need help Please
    SAMSUNG
    I3
    Samsung
    4Gb
    no
theog
Gold Member
5,591
#16
    Notebooks x 3
    Desktops x 5
    Towers x 4
theog
Gold Member
5,591
#17
Need help Please
Your DVD has a bad burn, redownload on PC with x64 OS & burn to DVD.
How to make the ISO the easy way.
by one of your top app makers SIW2.
http://www.eightforums.com/installation-setup/12559-cant-find-option-burn-iso-disk.html#post138356
    Notebooks x 3
    Desktops x 5
    Towers x 4
sajadwani
2
#18
Need help Please
Thanks for your help.
yes, it worked but I cannot still proceed because of another issue im facing.
the error its showing is language pack. its telling that u have different language installed.
I m try to update the language pack but it fails.
please help me
thanks
    SAMSUNG
    I3
    Samsung
    4Gb
    no
