All of a sudden, "No audio output device is installed"
Jack Rosen
1
Hi, I was using my computer today and I left it alone for a short while, then when I came back suddenly the sound was not working, even though the volume was turned all the way up. I restarted it a few times, and eventually the audio output device was gone (there was an x in the icon instead of sound waves, and when I hovered over it it said "No Audio Output Device is installed"). I also did a clean reboot, which didn't work. I went to the control panel, clicked Sound, tried right-clicking where it said "No audio devices are installed" so that I could choose to show disabled devices, but that was already enabled. I went to Device Manager and clicked "Sound, video and game controllers", but the only thing in the dropdown was "Bluetooth Audio Device". Does anyone know what I could do about this?
    64-bit
fireberd
Beach Observer
Inverness, FL
1,811
Please provide some system specs. Helps us to try and help you.
Since nothing is being shown, reset the BIOS as a first step and see if that helps (If you have any customized settings you will have reset those after resetting the BIOS).
popeye
United States
3,090
Yea, more info would help but doesn't sound good, could be hardware failure.
    Windows 8.1 Pro 64-bit
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    8GB DDR3 PC3-12800 (800 MHz)
    HD4000 + GeForce GT 730M
    Realtek High Definition Audio
    1600x900 pixels
    Samsung SSD 850 EVO 250 GB
    ADATA SSD SP900 128GB
    90 watt brick
    Bluetooth
    Comodo
