Advice Required: My C drive keeps getting filled
ern815
11
Hi there,
Currently my C drive is almost full but I have no idea what makes it full. I have removed quite a few programs but yet the space keeps getting filled, hence I would like to seek help from anyone here.
Let me know what information you would need further and I will try my best to provide them. Thank you!
KYHI
2,739
without seeing all the files present... I would assume your PC is set to hibernate..
Open command prompt (admim) and type the following
powercfg /h off
which will turn off hibernation, because the hiber file can become a very large file and use a lot of disk space
    Windows 3.1 > Windows 10
    Dell XPS 8700
    I7
    24 GB
ern815
11
^ I did but still didn't clear much space.
Also, cant run the hibernation off in command prompt, i received an error, unable to perform operation, you may not have permission to perform this operation.
Elsewhere, somebody was having a C-drive fill-up, and other posters suggesting using any one of free utilities that give either percentages, graphs, color charts, etc. of which directories are loaded the most all the way to which directories are nearly empty.
    2 Acers & 1 Antec[?]
    i7 in 2 Acers, i5 in desktop
    Desktop w/Gigabyte
    Two w/16GB, 1 w/8GB
    Laptops GameWorthy; Desktop maybe GameWorthy
    flatscreens; 2 are BluRay worthy
    1368x768; 1600x900
    1TB internals; 2 ext usb WD 1TB HDs
    what's PSU?
    Regular plus external fans
    desktio w/PS2
    desktop w/PS2
    DSL middle level [160?]
    from Netscape 0.9 to FF 36
    well-balanced, well-configured mult-layered defense is best
    From MS-DOS 3.3, MS-DOS 6.22, from Windows 3.1 to WFW 3.11 to Windows 95-98SE, now to Windows 7 Pro.
    Security for now: Windows 7 Firewall, Emsisoft AM, MSE [scan-only], SpywareBlaster, Ruiware/BillP combine
14
Was the command prompt run in administrator mode?
For disk cleaners, I've been using Wise Disk Cleaner.
    Windows 8.1 64-bit
    None
    Intel Core i5-4690
    MSI H97M-G43
    8 GB 1866 MHz Kingston HyperX Fury Black
    Inno3D N770 GTX770 2 GB DD5 256-bit
    Realtek HD
    Samsung SyncMaster S23B300
    Intel SSD 250 GB
    Seagate 2 TB
    WD 2 TB
    WD Mybook 2 TB
    Corsair HX750W
    Antec 900
    Intel Water Cooling
    Logitech K120
    A4Tech X7
    50 GB
    Cyberfox 64-bit
    Avira Free
ern815
11
#8
^ yea I think so.
Thanks for recommending the Uncleaner, managed to clear 1gb of space, but because my drive is almost full, i am thinking to move some things from my C drive to my D drive to save some space. Could people advise me what kind of things they would normally move?
samuria
crewe cheshire uk
461
#9
I wonder what apps you have one app sky news when you goto add remove it caches 12 gig of space worth checking when you click on it it tells you the cache and you can delete it other apps may be doing the same
    win 8 pro
