Adding Features to 8.1 Industry Pro
Gator1
9
Hello everyone, I'm a member on sevenforums and usually post a lot there but its my first time here. I do plan on possibly helping out here on issues in the future but I have a question today.
I got a copy of Windows 8.1 Industry Pro and it seems like a stripped down version of 8. My question is, what app do I need for the Search feature to look for/suggest Apps from the windows store and/or other results?
For example, on a normal 8 install if I search for Netflix and I don't have the App, I get suggestions on where to download it. For me, it will display no results if I don't have the program/app Im searching for locally.
Thanks in advance!
    A10-7700k Kaveri
    Asus M4A88T-V
    8gb Ripjaw
    Radeon R7
    FireFox
    Vipre
alphanumeric
slightly off center
Gold Member
Where did you obtain this version of Windows 8.1? Google seems to think its Windows 8.1 Embedded ? If true what is it installed on?
    Windows 10 Education 64 Bit
    Asus
    Thermaltake TR 620
    Stock heatsink fan
    Logitech Wireless K350 Wave
    80 Mbps Down 30 Mbps Up
Gator1
9
Thanks for your reply.
I got it through Dreamspark and yes Windows Embedded Industry Pro. Its on a custom PC I built.
    A10-7700k Kaveri
    Asus M4A88T-V
    8gb Ripjaw
    Radeon R7
    FireFox
    Vipre
alphanumeric
slightly off center
Gold Member
    Asus
    Thermaltake TR 620
    Stock heatsink fan
Gator1
9
IMHO, not the right choice for that hardware. Embedded is meant to run on Point Of Sale systems etc. At least that's my understanding. I think you'd be better off with the regular 8.1 Core or 8.1 Pro. Pro if you can get it.
See if this fixes your search issue, http://www.eightforums.com/tutorials/27645-search-online-bing-turn-off-windows-8-1-a.html
Yeah I realize its not the optimal OS for my machine but its free and actually very fast.
That link actually sort of helped but I think I found my problem and its that when I search, I don't have the option to search Apps via metro screen and it doesn't seem to search Windows Store either.
    A10-7700k Kaveri
    Asus M4A88T-V
    8gb Ripjaw
    Radeon R7
    FireFox
    Vipre
alphanumeric
slightly off center
Gold Member
I haven't looked at the ins and outs of Embedded versus normal Windows but you may find other restrictions as you keep using it. Can you not get the regular 8 Core or 8 Pro where you got Embedded?
So what exactly happens when you do a search? I have the Integrated Bing search function (that I linked to) disabled. I don't need or want online search results when I'm looking for something on my PC locally. Usually I just launch the Start Menu and start typing. If I need an App for something I just open the Windows Store and use its search function. I have 4 PC's so usually I just go to the My Apps section of the Store for Apps I've already used/bought.
    Asus
    Thermaltake TR 620
    Stock heatsink fan
Gator1
9
No I had one Windows 8 key but I installed it on my mothers PC. I actually like the stripped down version and so far I haven't seen any significant restrictions. I can use Hyper-V and AD (for learning purposes) just fine I just wanted to add a few features to make it a little prettier.
    A10-7700k Kaveri
    Asus M4A88T-V
    8gb Ripjaw
    Radeon R7
    FireFox
    Vipre
alphanumeric
slightly off center
Gold Member
#8
If you go to the Windows store and do a search, can you find the Apps you want? It sounds like some of the standard Apps include with 8 Core or Pro are not standard on Embedded.
    Asus
    Thermaltake TR 620
    Stock heatsink fan
Gator1
9
#9
Yeah, I was supposed to edit that post but got pulled away..
Basically I want it for aesthetics and laziness reasons. I can go to windows store but I really just want it on the search charm. I want to go to the metro screen/search and type "weather" and get options from Windows Store. If Im not mistaken I've seen that happen on an MVA video I was watching recently.
I'll just check out the standard apps that comes with the normal 8 installs and stop being lazy. :)
Thanks for the help.
    A10-7700k Kaveri
    Asus M4A88T-V
    8gb Ripjaw
    Radeon R7
    FireFox
    Vipre
alphanumeric
slightly off center
Gold Member
#10
That link I posted earlier has to do with the desktop search also searching the Internet. http://www.eightforums.com/tutorials/27645-search-online-bing-turn-off-windows-8-1-a.html There is an option to turn it off during the Install, I do. Have a look at the settings, your fix may be as easy as turning a few things back on.
    Asus
    Thermaltake TR 620
    Stock heatsink fan
Gator1
9
#11
Yeah I already followed the link and it gets me close so that I get other results rather than only local results but I still never get to Windows Store results via the search charm. Am I just mistaken about this?
    A10-7700k Kaveri
    Asus M4A88T-V
    8gb Ripjaw
    Radeon R7
    FireFox
    Vipre
alphanumeric
slightly off center
Gold Member
#12
I don't know, I have the Bing search function disabled. I just open the Windows Store and search from there when I'm actually looking for an App. I would think you'd get adds for Apss, that if you clicked on and followed would lead you to the Store.
    Asus
    Thermaltake TR 620
    Stock heatsink fan
Gator1
9
#13
You're probably right and Im probably just being unreasonable I just didn't want to have to go to Windows Store and search. I'll probably just bite the bullet and use the store or when I stop being lazy about it I'll go crazy and compare the apps between the two. :)
    A10-7700k Kaveri
    Asus M4A88T-V
    8gb Ripjaw
    Radeon R7
    FireFox
    Vipre
