Solved Acer Aspire E1 570 Battery Dies at 40%
hi there,
I have a Acer Aspire E1 570 laptop that I use for college, the laptop is less then 8 months old. For some reason recently it starting going dead at 40% battery charge remaining. I ran a powercfg -energy from the command prompt and it said that my batterys designed charge is 37000 and last full charge untill the battery read it was fully charged is 36526. If some one would happen to know why this is happening that would be great, as i use the laptop on the battery all the time while i'm at school. I was thinking maybe just refresh the PC from the recovery i made using the provided software with the computer. I'm unsure if that would correct the issue. As well as i haven't found anything on google for this issue on my laptop.
Thanks
RitualJman
    Windows 8.1 Pro 64-Bit
    Custom Built
    AMD BullDozer FX-9590 @4.7GHz
    Asus SaberTooth 990FX R.2
    16GB G.Skill DDR3
    EVGA GeForce GTX 980 K|NGP|N ACX 2.0 x2
    Realtek High Definition Audio
    ViewSonic vx2025wm Acer P191W
    1680X1050 1440X900
    Crucial MX100 512GB SSD
    Seagate 2TB
    WD 2TB USB 3.0 External
    EVGA SuperNova 1200W
    NZXT Phantom 410
    CoolerMaster Siedon 240M
    Logitech G510 Gaming Keyboard
    Razr Abyssus Gaming Mouse
    Realtek Intergrated Gigabyte
    Avast
    Internal USB 3.0 54 In 1 memory card reader, Wired Xbox 360 controller, Wired Guitar Hero Guitar, Logitech Wingman
broe23
Retired from the grind
Central IL
3,468
I would contact Acer, since the laptop is still within the warranty period. There are programs out there that can "fix" errors like this. Most likely you just have a bad battery pack in your laptop.
    Linux Mint 17.2
    12GB
    AMD Radeon™ HD 7310 Graphics
    Realtek HD
    LCD
    1366 x 768
    Crucial M500 240GB SSD
    Logitech M525
    45/6 - ATT U-Verse
    None needed. It is Linux.
Problem with that is that i have to pay to ship the laptop to them and i don't have money to pay to ship it as they won't pay the shipping. I was hoping there was some kind of software glitch that could of been fixed
    Custom Built
    16GB G.Skill DDR3
    1680X1050 1440X900
    Seagate 2TB
    NZXT Phantom 410
    Avast
caperjack
Just the Janitor
2,627
I think it would be cheaper to ship it to them, than you having to buy a new battery for it
    win8.1.1 enterprise
    Hinze57
    AMD FX 6100 6core 3.30gHz
    gigibyte ga-78lmy-s2p
    4gig ddr3
    Radon hd5000 Series
    onboard realtek hd
    19" viewsonic/ 22"Samsung
    1680x1050
    128gig ssd Kingston
    80gig WD 10000 rpm spinner
    micro
    microsoft curve 200
    Logitech wireless M215
    high speed 20
    ie 11
    windows defender
    updated enterprise apr 2/14
Okay, thanks every one I will see about getting the money to ship the thing to them.
Thanks
RitualJman
    Custom Built
    16GB G.Skill DDR3
    1680X1050 1440X900
    Seagate 2TB
    NZXT Phantom 410
    Avast
lastof
151
First, go to your Power Options control panel (Windows Key + X > Power Options).
Under the plan that you use (actually you can check all of them), click "Change Settings".
Now click on "Change Advanced Power Settings".
Find the entry for "Battery" and expand it. Check the following nodes:
"Low Battery Level"
"Critical Battery Level"
"Reserve Battery Level"
What are the respective %'s showing?
If nothing there seems amiss, proceed with the following:
Go to Acer's driver download page:
Acer | Download
Click on the "Application" tab. Download and install the "ePower Management" software. If you already have this, just do it anyways.
If you still have no luck - go to this page to recalibrate the battery, here is the first line that is on the page, which sounds like the same problem:
So you’re using your laptop and, all of the sudden, it dies. There was no battery warning from Windows — in fact, you recently checked and Windows said you had 30% battery power left. What’s going on?
How to Calibrate Your Laptop?s Battery For Accurate Battery Life Estimates
    Win8 Pro
