Access problems in C drive
op00iuy
Hello everyone,
I am facing several weird problems in my Windows 8.1 installation. My first problem is that when I try to copy/create a file to my C: drive it throws an access violation error. Please see the image below-:
But this not the case if I copy/create a file in any of sub directories in C:. For example I can copy/create files to system32 or program files with any such problems. Oh and this didn't happen before plus I am the administrator of my pc.
My second problem is that I no longer get a popup when I connect a external HDD to my system. It doesn't even show up in "My Computer" I have to open up disk management and then assign a drive letter to the external HDD then only will it show up in File Explorer.
Now are these two problems related ?
Also are they caused by malwares ? if so please specify some free tools for getting rid of them.
Thanks.
    Intel i7
Dude
Active Member
Try disabling UAC and see if that works. It sounds like you don't have the right permissions.
    W10 Pro X64
    Dude
    Intel(R) Core(TM) i5-3570K CPU [email protected] 4.5 GHZ Turbo
    MSI Z77MA-G45 (MS-7759)
    8.00 GB DDR3 1600Mhz
    PNY GTX 760
    Realtek High Definition
    Dell S23O9W, HP L1710
    DELL-1920 x 1080 HP-1280 x1024
    Crucial m4 256 SSD WD 7200RPM 500GB
    Seasonic X650 Gold
    Zalman Z12
    Antec Kuhler 920
    Logitech
    MSI DS100 Interceptor
    50 down 5 up
    Chrome, IE 11
    Logitech X-620 Speakers
Arpan
The Boy Who Lived
Hello,
Right click File Explorer > Run as Administrator. See if it works now.
    Windows 8.1, Windows 7, Linux Mint 14
    Name
    Arpan Nath
    HP Pavillion g4
    Intel(R) Core(TM) i3-2330M CPU @ 2.20GHz
    4 GB
    1 GB Radeon Graphics
    Generic PnP Monitor
    1366x768
    500 GB HDD
    Country Flag
    India
Arpan
The Boy Who Lived
Not on the taskbar. Go to start screen (Press the windows logo key) and start typing: File Explorer. Now right click and run as administrator.
    Name
    Arpan Nath
    HP Pavillion g4
    4 GB
    Generic PnP Monitor
    1366x768
    500 GB HDD
    Country Flag
    India
TechnoMage
Active Member
One thing to do, that takes a lot of the Bite out of the Permissions thingy.....
Download and install "Grant Admin Full Control"....then you will be able to Take Control of every file or folder in your PC....except the root directory. It comes up in your Right Click context menu, so you can right click on any file or folder and Take Ownership of that file or folder. If you Take Ownership of a large folder, like Program Files, it does one file at time, so the process will take a while.
But I've found it well worth doing.
During a setup on a Windows 8 or 8.1 PC, I install several scripts and batch files and my location of choice is the root directory, but then the permission thing bites me in the pants.
One solution I've begun to use is to first create a folder under the root and copy things there. That never fails.
It seems like Windows is overprotective of the root directory. Eh?
When I'm running many of my Install Batch Files or even just installing programs, if I right click on the file and "Run As Administrator" things work a lot better. And when installing older programs, using Compatibility for an older OS works great and always check "Run as Administrator"....just for safety.
Just a thought!
TechnoMage :cool:
    Win-8.1
    Gigabyte
    AMD 8 Core
    Gigabyte
    PNY, 4GB
    NVIDIA, GForce 210
    21" HP
    Seagate SATA III, 500GB
    Antec Earthwatts, 650
    Occupation
    Retired Computer Tech.
    Pac-Man Case
    HP Professional
    GearHead Wireless
    5 Meg
    AVG Free
    Using Classic Shell on Win-8.1 pro
    Country Flag
    USA
    State/Region Flag
    us florida
op00iuy
Just a thought!
TechnoMage :cool:
Thanks TechnoMage but I need control of my root directory. I can create files under folders in the root directory fine. I don't know why this problem is happening previously everything was fine. Will icacls or cacls commands help me ?
    Intel i7
Maybe this:
    Name
    David A. Bailey
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Package Socket FT1 BGA
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Occupation
    Trying to live a good life before I die.
    Opera 24.0
    Avast Internet Security
    Country Flag
    USA
    State/Region Flag
    us virginia
op00iuy
    Intel i7
Arpan
The Boy Who Lived
Btw love your avatar. Are you Hindu ? I am a Hindu from India so its very nice to see someone from outside India using Ganesha as an avatar.
We appreciate it. But discussing religion here is prohibited (against forum rules).
    Name
    Arpan Nath
    HP Pavillion g4
    4 GB
    Generic PnP Monitor
    1366x768
    500 GB HDD
    Country Flag
    India
op00iuy
I apologize. Anywhere with my problem I am still stuck with it. Will editing local security policies do anything ?
    Intel i7
    Name
    David A. Bailey
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Occupation
    Opera 24.0
    Country Flag
    USA
    State/Region Flag
    us virginia
gospelmidi
Try taking Ownership of SysWOW64 folder where explorer.exe is located:
That is not possible given the existing permissions for the Windows directory.
"Users" has Read/execute, List folder contents, and Read. The other permissions are not allowed.
"ALL APPLICATION PACKAGES" has the same three permissions, with no others allowed.
"TrustedInstaller" has List folder contents.
ALL of the other identities have only Special permissions, whatever that may include in each individual case.
    Windows 8.1 x64
    ASUS
    AMD Phenom II 3-core 2.3 GHz
    ASUS M4A785-M (AM2+)
    4 x 1GB Crucial DDR2 1066 Mhz
    onboard ATI HD 4200 256MB
    Dell ST2421L
    1366 x 768
    SSD Mushkin Chronos 120 GB (24 GB system partition)
    Rocketfish 500W
    redundant
    wireless
    different wireless
    12 MB/s max, 1 to 2 MB/s typical
    Opera 20.0.1387.91 stable
    Yes, I've got one.
XweAponX
I see you are using IObit Unlocker? can you make the file using that?
    Name
    Jon William Vitas
    AMD 4400+/4200+
    2 GB/3GB
    GeForce 8400 GS/GeForce 210
    Hitachi 40" LCD HDTV
    "1842 x 1036"
    WD My Book 1140 USB Device
    Works 550w
    Occupation
    Retired
    MSI "M-Box"
    Water Cooled
    Dell Keyboard
    Microsoft Intellimouse
    Cable Medium Speed
    Chrome/IE 10
    Eset NOD32 6.x/Win Defend
    Country Flag
    USA
    State/Region Flag
    us california
I just took ownership of mine:
& I just gave myself Full Control:
Why it doesn't work for you, I do not know. :(
    Name
    David A. Bailey
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Occupation
    Opera 24.0
    Country Flag
    USA
    State/Region Flag
    us virginia
gospelmidi
The User, although running as Administrator, probably doesn't have permission to make such changes.
    Windows 8.1 x64
    ASUS
    Dell ST2421L
    1366 x 768
    Rocketfish 500W
    redundant
    wireless
    different wireless
    Yes, I've got one.
op00iuy
I can take full control but even taking full control doesn't allow me to create files in the root directory. But if I sign in as Administrator then I can create files in the root directory.
    Intel i7
op00iuy
Here is something that I learned the hard way. Always create a system restore point before messing with permissions of you Windows installation drive.
If you do mess up something that cannot be repaired you can perform an in-place upgrade or repair install. Do that only and only if something that you have messed up is beyond repair.
Please have a look at this if you are repair installing Windows 8 or 8.1-:
Repair install on Windows 8 and Windows 8.1
And remember if you are not confident about what you are doing while modifying permissions on the Windows root drive.
THEN CREATE A SYSTEM RESTORE POINT BEFORE ANYTHING.
    Intel i7
