a required CD/DVD drive device driver is missing
dumble
He guys,
im trying to install the new develp build of win8 (x86) on my asus eeepc 1005pe. This is a netbook which doesnt even have a cd/dvd drive.
So anyway, I extracted the iso on a bootable usb flash drive. I boot, and when I click install it just hangs for about 10 minutes and then it gives me this error:
I tried setting the bios from AHCI to IDE. This does not help, I even get a bluescreen of death when I boot up in the current win7 sp1 install. But anyway on google I read a lot about this problem and one of the solutions is to put it on AHCI.. but not for me as it was already on AHCI. Anyway IDE is not workin either.
So im kinda lost.. just recently I installed win7sp1 on this netbook without a problem. I checked the sha1 hashes of the win8 ISO and they are confirmed, so that is not the problem either.
Can anyone help me with this problem?
    win7/win8/ubuntu
myzr
    WDP 8 x86
    Dell Lat 530 Lappy
    Dual Core
    24 Mbps sometimes high speed cable
theog
Gold Member
Did you Disable Boot Booster in BIOS setup.
    ME, XP,Vista,Win7,Win8,Win8.1
    Notebooks x 3
    Desktops x 5
    Towers x 4
dumble
im not really planning to install a develepors build for everyday use, so upgrading is not an option.
i know how to make a bootable usb, as you have seen my screenshot, this is not the problem..
I dont have boot booster option in my bios..
This is what I have tried allready:
- checked sha1 hash of iso
- configured bios tn AHCI
- tried fat32 and ntfs usb format
- This
    win7/win8/ubuntu
jflores80
I am getting the same error with the 32bit version. I will download again and burn it again see if that helps. It could be that the data got corrupted somehow. Will let you know as soon as I do.
    Windows 7
dumble
ok, but with me its not the ISO. so downloading it again is a waste of time.. you can check the sha1 hash.. if that is correct then there must be something else wrong.. the q is, what?
    win7/win8/ubuntu
jflores80
Could be something ese is wrong, but I downloaded another copy of the iso last night, burnt it and I was able to install it with no problems at all.
I'm just saying give it a try, your spending way more time in trying to fix it. If the new iso does the same thing, then we can start looking at other options.
    Windows 7
Bill2
Seems to be random, i booted from a dvd and got the error but not on booting from a flash drive made from the same iso.
dumble
You do know what a SHA1 hash is do you? If that is correct then there is no reason to download the ISO again. Anyway you probably downloaded a corrupted ISO, so thats why it solved ur problem..
I also managed to fix it, finally, after lots of hours work, I realized that I got an 4GB SD card in my camera.. Made that bootable with win8,, and it worked flawlessly
    win7/win8/ubuntu
myzr
thanks for telling us your resolution. enjoy
    WDP 8 x86
    Dell Lat 530 Lappy
    Dual Core
2mad4
you've try only with card SD or dvd....i've try only with dvd...and the result is like in your image.
    windows 7
Dave76
Team Member
Try re-burning your DVD, at the slowest possible speed.
    76~2.0
    Intel Core i5-3570K 4.6GHz
    GIGABYTE GA-Z77X UD3H f18
    Onboard VIA VT2021
    22" LCD Dell SP2208WFP
    1680x1050
    Corsair HX650W
    Cooler Master Storm Scout
    Logitech Wave
    CM Sentinel
    Abysmal
    Opera Next
    Desktop: eSATA ports,
dumble
@2mad4
I tried first with my USB stick, several times. This did not work. Then I used an SD-card, because I have an sd-card reader in my netbook. With the 4GB SD-card it worked fine. I dont get why it worked with my SD and not with my USB... but this was the solution for me.
I did not try with DVD, because I have a netbook which doesnt have a CD/DVD drive. Which makes it even more strange that its asking me for a CD/DVD drive driver, but eh.. maybe because its still in beta stage, this could be a bug..
    win7/win8/ubuntu
calvinada991
I was having the same error when trying the installation using a Micro SD with the elago USB adapter. Then, tried the Micro SD in a SD Card adapter which was then inserted into a USB adapter. Boot it up. Voila! Installation was a breeze.
    Windows 7 & 8 Dual Boot
    HP HDX18t 1200
    Intel Core 2 Duo P8700
    4GB
    NVIDIA GeForce 9600M GT
jimbo45
Hi there
I had this problem too when trying from a USB device.
However using the BOOTSECT from the W7 x-64 disc fixed the problem.
Use the Manual way (command line) to create your USB and ensure it's bigger than 4GB -- a 4GB one isn't enough -- an 8GB stick is fine.
Copy the directories and data from the ISO --- mount the ISO as a virtual device using daemon tools / alcohol52% Free edition or whatever Virtual drive program you use.
Why the bootsect from the W8 disc didn't work I don't know. BTW when copying the data copy all the files from the W8 image -- only use the W7 image when you are using the BOOTSECT command to make the usb bootable.
Cheers
jimbo
    1 X LG 40 inch TV
    2 X 3 TB sata
    5 X 1 TB sata
    0.12 GB/s (120Mb/s)
khalil55
there's no need for all of this :D
When Windows is asking for driver, just click Cancel. You will be brought back to the welcome screen. At the welcome screen, remove your USB drive, insert it back to DIFFERENT USB PORT. Click Install Now again. The installation process will be like usual.
This problem happened to all new version of updated Windows 7 installer. I think, it is due to failure of Windows installer to remain its detection to the USB drive. It lost the connection, and became confused, don't know where to find the USB drive it used to read before.
When we re-insert the USB drive, Windows installer will detect the USB drive back, and continue like usual.
good luck guys :)
vanowm
I had the same problem installing Windows 7 from a USB stick. The problem I was having is that Windows 7 doesn't have driver from the USB3 controller the stick was plugged in.
An easy way to check it, when you press browse button, if you don't see drive "X" then this is the problem and you should find the driver for the USB controller.
From that window installing USB3 driver fixed my problem.
P.S.
Another interesting thing to note, if you have combined 32bit and 64bit installation files, then you'd need use 32bit driver even if you planning install 64bit OS (because it uses 32bit boot.wim if combined properly)
    W7
