A required CD/DVD drive device driver is missing.
pranitkhedekar
guys i want to install win8 on my computer...so i downloaded win8 iso file...after that ive make the bootable usb of win 8...when i try to install win 8 it shows error....just like this
pls help me
    Windows Xp SP2
    Intel DG35EC
    2gb
bobkn
I'm not sure.
If it's the same as Windows 7, the most likely cause for that is corrupt installation media. As you're using a USB installer, the problem may be with the .iso itself.
If you can check the hash code on the .iso. that'd be the surest way to verify it.
    Window 8 Pro
    homebuilt
    I7-3930k
    Asus P9X79 Pro
    16 GB Gskill DDR3-2133
    eVGA GTX 680
    Soundblaster Zx
    Asus PA246Q
    1920X1200
    Corsair Force GT 120GB
    WD Cavair Black 1.5TB
    PC Power & cooling Silencer 750
    Silverstone FT02B-W
    Noctua NH-D14 w/ PWM fans
    cheap Logitech USB wired
    old 5 button Microsoft USB optical
    6Mb cable
theog
Gold Member
Where do you buy your DVD from?
    ME, XP,Vista,Win7,Win8,Win8.1
    Notebooks x 3
    Desktops x 5
    Towers x 4
pranitkhedekar
and also when m tring to install win7 from cd same error apears...so now i m on win xp...
and even in past months i can successfully installed win7 on my computer using same cd...bt now i dnt knw wats the problem...
    Windows Xp SP2
    Intel DG35EC
    2gb
