Solved a disk read error occurred press ctrl alt del to restart
ariaza
4
HELP
I have a toshiba laptop running windows 8. I went to delete photos off a usb when my laptop froze. I turned off the laptop by the power button waited, then when I turned the laptop back on it came up with the message
Each time I press ctrl alt del it returns to this message. I can only go to F2 or F12. I know a little about computers but not enough to fix something like this. All replies would be greatly appreciated.
Thanks for your time
HippsieGypsie
It's Gururrrrrr8!
Lilymoor, IL
13,547
Welcome to EightForums, ariaza.
It's a USB thumb drive I assume. I suggest to unplug the drive, then try to reboot.
    8.1 Pro X64
    Acer T690
    Intel Pentium D Dual Core
    Acer/Intel E946GZ
    2GB (max upgrade)
    Acer AL1917W A LCD
    1440 X 900
    Thumb drives
    Standard 250 watt
    Dual case fans + CPU fan
    Acer Windows PS/2
    Wireless Microsoft Arc
    54mbp/s
    IE11
    Defender
ariaza
4
Hi HippsieGypsie
Yes it was a usb thumbdrive and I removed the usb after i first turned off laptop and waited a bit before I turned it back on.
Thanks
ariaza
HippsieGypsie
It's Gururrrrrr8!
Lilymoor, IL
13,547
And so you still have the problem?
    8.1 Pro X64
    Acer T690
    Acer/Intel E946GZ
    2GB (max upgrade)
    Acer AL1917W A LCD
    1440 X 900
    Thumb drives
    Standard 250 watt
    Acer Windows PS/2
    54mbp/s
    IE11
    Defender
Mystere
1,925
Sounds like your hard disk crashed. Bring it to a shop.
    Intel i7 3770K
    Gigabyte Z77X-UD4 TH
    16GB DDR3 1600
    nVidia GTX 650
    Onboard Audio
    2560x1440 + 2x 2048x1152
    Antec SOLO II
    Logitech MX
HippsieGypsie
It's Gururrrrrr8!
Lilymoor, IL
13,547
Thanks, Mystere. I suppose there's no way he can test with exterior equipment?
I know it's something you may not want to hear, ariaza, but Mystere is probably correct. He's more savvy at this stuff than I.
Please report back what happens.
    8.1 Pro X64
    Acer T690
    Acer/Intel E946GZ
    2GB (max upgrade)
    Acer AL1917W A LCD
    1440 X 900
    Thumb drives
    Standard 250 watt
    Acer Windows PS/2
    54mbp/s
    IE11
    Defender
Mystere
1,925
#8
Well, certainly, there are ways to test if you are savvy enough. But if you're savvy enough, you probably know them already. Maybe you've got a neighborhood geek that can help you out ;)
The easiest way to test the hard drive is to put it in another computer... You can also listen to it careful, and listen for "clicking" or other strange noises.
    Intel i7 3770K
    16GB DDR3 1600
    nVidia GTX 650
    Onboard Audio
    Antec SOLO II
    Logitech MX
Mustang
Australia
716
#9
A lot of people have had boot issues with W8. This is a post I just did in another thread on this forum. Click --> here. I also got the error message: "No disk detected", but there was nothing wrong with the disc. Do you have a windows installation disc, or third party partition manager CD, that you can put in your burner and boot off? This would detect and show your HD if it's still operable. Also maybe a friend could help you re-set your BIOS to default. Do you know how to remove the battery pack? If so, take it out, and leave it out for awhile to let all residual current drain, and then replace and restart which I have found sometimes helps in situations like this.
    Windows 7 Ult Reatil & Win 8 Pro OEM
    Built as DIY
    6 core 12 thread & 4 core
    Inel Extreme & Intel standard
    12GB & 8GB
    3 top end SLI linked & onboard
    In built in graphics card & onboard
    24 & 23 inch Samsung LED backlit
    High def
    Corsair Force 128GB SATA3 SSDs in each machine. Plus several external USB3 and eSATA spinner HDs
HippsieGypsie
It's Gururrrrrr8!
Lilymoor, IL
13,547
#10
The head slamming against the platter ticking. Not a pleasant sound! I had that happen once on a slave drive. I intuitively knew that something was wrong and sure enough -> Trashed. I was using it for backing up. Luckily I had a spare to replace.
    8.1 Pro X64
    Acer T690
    Acer/Intel E946GZ
    2GB (max upgrade)
    Acer AL1917W A LCD
    1440 X 900
    Thumb drives
    Standard 250 watt
    Acer Windows PS/2
    54mbp/s
    IE11
    Defender
Mustang
Australia
716
#11
The worst sound is the sound of silence when you hit the start button and you can smell that electrical burning odour. Like I did after an electrical storm had passed.
    Built as DIY
    12GB & 8GB
    High def
ariaza
4
#12
Hi HippsieGypsie and Mustang
I do have a friend that is great with computers. He came and helped me. I have an external hard drive that I keep all my important photos, documents on, so we just put windows 8 back on the laptop from scratch and it worked.
I now have a fully functional laptop again.
Thank you for both answering my queries.
Cheers
ariaza
HippsieGypsie
It's Gururrrrrr8!
Lilymoor, IL
13,547
#13
I'm glad it wasn't a hard drive. :)
    8.1 Pro X64
    Acer T690
    Acer/Intel E946GZ
    2GB (max upgrade)
    Acer AL1917W A LCD
    1440 X 900
    Thumb drives
    Standard 250 watt
    Acer Windows PS/2
    54mbp/s
    IE11
    Defender
2
#14
I have a dell laptop running windows 8. I went to delete photos off a usb when my laptop froze. I turned off the laptop by the power button waited, then when I turned the laptop back on it came up with the message
Thanks for your time[/QUOTE]
    win 8
2
#15
i have a dell laptop running windows 8. I went to delete photos off a usb when my laptop froze. I turned off the laptop by the power button waited, then when i turned the laptop back on it came up with the message
each time i press ctrl alt del it returns to this message. I can only go to f2 or f12. I know a little about computers but not enough to fix something like this. All replies would be greatly
thanks for your time
[/quote]
help
i have a toshiba laptop running windows 8. I went to delete photos off a usb when my laptop froze. I turned off the laptop by the power button waited, then when i turned the laptop back on it came up with the message
each time i press ctrl alt del it returns to this message. I can only go to f2 or f12. I know a little about computers but not enough to fix something like this. All replies would be greatly appreciated.
    win 8
XweAponX
Cheers
ariaza
I'm glad you got going. You should not have had to reinstall from scratch, there are several disk checking programs you can use from a boot disk. You can get them all from Hirens Boot Disk, or you can download them individually. GWscan can repair most seagate and WD drives, the seagate disk scanner works well in both dos and GUI mode. western digital uses a program similar to GWscan. For hitachi, samsung and Toshiba, use their tools.
If this happens again we'll help you make a boot disk with the drive scanner on it.
Just to be safe, you should run a full CHKDSK in windows 8, on all visible partitions, there may still be an inconsistency in the drive.
    AMD 4400+/4200+
    2 GB/3GB
    GeForce 8400 GS/GeForce 210
    Hitachi 40" LCD HDTV
    "1842 x 1036"
    WD My Book 1140 USB Device
    Works 550w
    MSI "M-Box"
    Water Cooled
    Dell Keyboard
    Microsoft Intellimouse
    Cable Medium Speed
    Chrome/IE 10
    Eset NOD32 6.x/Win Defend
