7-ZIP and administrator rights problem.
streetwolf
New Jersey
114
  1. I've got a strange problem running 7-Zip 9.28 alpha [64 bit] under Windows 8 Pro x64 RTM. Hope you can help.
    In order to be able to click on a zip file and then extract it's contents to a folder I have to set 7zFM.exe to run with Administrator rights via Properties | Compatibility. However, when I do this the 7-Zip 'Open Archive' context menu does not work.
    When I remove Admin rights from 7zFM.exe the 'Open Archive' context menu works but I can no longer click on a zip and extract it's contents. I get multiple messages for various files like this one: 0 ERROR: Can not delete output file <file path is here> .
    Interestingly, I get these same exact messages if I try to extract to a folder that is open by a running program.
  2. Keep in mind I can't use the 'Run as Administrator' context menu option because I am clicking on the zip file not running the 7-Zip GUI directly. My only option is to use compatibility mode to set Admin rights. I've had many programs that require Admin rights under Windows 8 then I ever had with Windows 7. Any thoughts/ideas on my problems?
    Windows 8.1 Pro X64
    Homemade Rig
    Intel Core i7 Quad 3770K @ 5 Ghz
    ASUS P8Z77-V Deluxe
    Corsair Dominator-GT 16GB @ 2400 Mhz
    Sapphire HD7970 3GB OC Edition
    Realtek HD
    ASUS PA246Q & PA249Q IPS 24" LCD
    1920x1200
    Samsung SSD 830, 840 256GB |
    2TB Seagate SATA3 |
    Hitachi eSata 500GB
    Corsair Professional Series 1050W
    Corsair Obsididan 800D Full Tower
    Corsair H100 Liquid CPU Cooler
    Logitech Wireless K520
    Microsoft Wireless Explorer
    Fx41
    UEFI BIOS with a GPT SSD boot drive.
streetwolf
New Jersey
114
Windows 8 is driving me nuts. I got 7-Zip to work fine when I gave my user account full control over the folder I am extracting to. Why did I have to do this to get it to work? I never had to do this in Windows 7. I've run into all sorts of Administrator rights problems with W8.
For example, the Registry Scanner from NirSoft. If you try the to Open the Registry on a key RS is displaying nothing happens. Either you have to run RS as Administrator or set RS to have Admin rights in compatibly mode. Once again I never had to do this in W7.
Is it just me that is having these sort of Admin issues?
    Windows 8.1 Pro X64
    Homemade Rig
    ASUS P8Z77-V Deluxe
    Realtek HD
    1920x1200
    2TB Seagate SATA3 |
    Hitachi eSata 500GB
    Fx41
cluberti
Cat herder
Redmond
651
What folder are you attempting to extract to? If it's at the root of a drive, or one of the protected folders (\Program Files, ProgramData, \Windows), then yes, you need admin access to do this. If it's a profile folder (like your desktop or documents), that wouldn't make sense unless 7zip is doing something "bad" when launching (for what it's worth, I've been using WinRAR without problems on Win8, but I've not tried 7zip yet).
    Windows 8.1 x64
    Custom
    Intel Core i7 4790K @ 4.5GHz
    Asus Maximus Hero VII
    32GB DDR3
    Nvidia GeForce GTX970
    Realtek HD Audio
    1x Samsung 250GB SSD
    4x WD RE 2TB (RAIDZ)
    Corsair AX760i
    Fractal Design Define R4
    Noctua NH-D15
streetwolf
New Jersey
114
It's my Firefox folder in \Program Files (x86). Nothing special about it. As I stated, the error messages I were getting were exactly the same as when I try to extract to the Fx folder when Fx is running.
FYI
I run Fx hourlies. I download the latest one, open it in 7-Zip via the Fx download menu, exit from Firefox, then extract it to my Firefox folder. This always worked in Windows 7 without having to give full control to my Fx folder.
Perhaps the reason the folder did not have full control for my user account was the fact that I manually created the folder the first time because I use the ZIP version of the hourlies. Maybe if I ran the EXE version it would have created the folder with full control for me.
    Windows 8.1 Pro X64
    Homemade Rig
    ASUS P8Z77-V Deluxe
    Realtek HD
    1920x1200
    2TB Seagate SATA3 |
    Hitachi eSata 500GB
    Fx41
cluberti
Cat herder
Redmond
651
Perhaps - in Windows 8 (and technically, it was the same in Windows 7 too, unless it was changed by the installer or manually by the user), \Program Files folders are "protected". By default, they're read only except for administrators running with a full admin token (aka, elevated process run as administrator) and the SYSTEM account. You can use icacls to change this, if you need to, and once you do the problem will go away.
    Windows 8.1 x64
    Custom
    32GB DDR3
    Realtek HD Audio
    Corsair AX760i
    Noctua NH-D15
streetwolf
New Jersey
114
I had to reinstall W8 Pro x64 due to problems I had running Modern Apps like the Solitaire Suite from MS. After installing 7-Zip, the latest x64 alpha version, I can't seem to get the context menus to work. Some options do nothing while others give me this error message :
7-Zip
The requested operation requires elevation.
C:\Program Files\7-Zip\7zG.exe
OK
I gave all three of the exe's in the 7-Zip folder Admin rights and also took ownership of the folder. This same version of 7-Zip was working on my previous W8 install, btw.
Any ideas on getting the context menus to work? Within the 7-Zip GUI I can do what all the context menu options do because the exe has Admin rights. Do I need to give the context menu programs Admin rights too? I haven't found a way to do this.
    Windows 8.1 Pro X64
    Homemade Rig
    ASUS P8Z77-V Deluxe
    Realtek HD
    1920x1200
    2TB Seagate SATA3 |
    Hitachi eSata 500GB
    Fx41
Hopachi
Polyhedric Stellation
Orbiting the Moon
2,975
Never encountered this before. Using the beta.
Maybe the latest alpha's have some bugs related to Win8?
I'm using the x64 7-zip 9.22 (not the alpha) and all works well on Win8.
The e-mail shell commands seem to be better in latest version but I don't use those.
If you try extract to Program Files directly, then you can expect some problems.
Always extract to your user folder or desktop and then move files to Program Files.
Try to run 7zFM.exe as Admin and then Tools -> Options for resigning the context menu's.
This should have worked, but as I see, you allready run it as admin. Oops.
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    multiple resolutions
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
    That's basically it.
streetwolf
New Jersey
114
#8
I had 9.3 alpha working on my previous W8. I've always had trouble with 7-Zip, it never worked out of the box. I have to give the executables Admin rights to work in all cases. I don't recall if I had to do something similar with the context menu items under my previous W8. All I know is that they worked.
Based on the error message I need to elevate something in 7-Zip but I don't know what at this point.
    Windows 8.1 Pro X64
    Homemade Rig
    ASUS P8Z77-V Deluxe
    Realtek HD
    1920x1200
    2TB Seagate SATA3 |
    Hitachi eSata 500GB
    Fx41
Hopachi
Orbiting the Moon
2,975
#9
What were you trying to do?
Maybe I can reproduce that error on 9.22.
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
Hopachi
Orbiting the Moon
2,975
#10
It says that 7z alpha is not recommended for normal usage.
It messed up some of my archives in the past (corrupted the files) so I believe that now.
Weird error there because I didn't saw it yet on Win8.
I'll wait with the 9.3 until it stabilizes a bit more.
Maybe try uninstalling and remove all registry entries or 7-Zip then try reinstalling. You can of course try different versions as well.
Good luck
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
streetwolf
New Jersey
114
#11
As I stated in my first couple of posts made when I installed W8 the first time I had problems extracting a firefox zip build to the firefox folder in program files(x86). I eventually discovered that I had to give Admin rights to 7zFM.exe. I had to do the same thing this time around for my W8 install. For good measure I gave the other two executables Admin rights also.
That's about all I did. I just can't get the 7-Zip context menu in Explorer to do any options on the menu. Either nothing happens or I get the 'elevated' message.
    Windows 8.1 Pro X64
    Homemade Rig
    ASUS P8Z77-V Deluxe
    Realtek HD
    1920x1200
    2TB Seagate SATA3 |
    Hitachi eSata 500GB
    Fx41
Hopachi
Orbiting the Moon
2,975
#12
Have you tried the 9.22 yet?
Or you probably want the speed improvements for Ivy Bridge in the latest alpha.
This is 7-zip 9.22 on Win8 RTM x64:
-The Windows theme is from RP version, I said it just to avoid confusion.
-The 7zip theme is my own, for the rest, original 9.22 version.
-I ran 7z as admin just to assign it to its format (see icon left)
-The shell commands in the right click menu work, I just removed the e-mail links with in the options just to prove it works, and I don't need those.
So I think it has to be new code in the alpha that still needs some testing. I'm not gonna use it until it becomes more stable.
Win8 is also on Ivy Bridge here and for the moment 7z has been stable.
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
streetwolf
New Jersey
114
#13
I tried v9.20 and it does the same thing. Also as I said, I had v9.30 alpha working on my old install of W8 Pro x64 so it's not a problem with the alpha version in my case.
I tried a couple of other similar products and they all worked fine. None of them required me to do anything regarding security rights. Why the heck do I have to it with 7-Zip? Never had this problem with W7 btw.
    Windows 8.1 Pro X64
    Homemade Rig
    ASUS P8Z77-V Deluxe
    Realtek HD
    1920x1200
    2TB Seagate SATA3 |
    Hitachi eSata 500GB
    Fx41
tseax
7
#14
.... Why the heck do I have to it with 7-Zip? Never had this problem with W7 btw.
Yep. Went through <exactly> the same steps trying to find an answer, found none. And years later, we're still here in 2012.
    8x64 | 10x64
    DIY
    i7 3770K
    ASUS P8Z77-V Deluxe
    16GB Corsair Vengeance 1600
    EVGA GEForce 660 Ti SC
    n/a
    Samsung SyncMaster 305T
    2560x1600
    System: 8.1 - Intel® SSD 530 Series 240GB
    System: 10 - Corsair Neutron GTX 240GB
    Assorted storage hard drives.
    Corsair TX-850
    Silverstone Raven II E
    Corsair H80i (still unuseable LINK software)
    Fujitsu (mechanical) | Gyration (wireless)
    M$ Wheel Mouse Optical | Logitech Couch
    50 Mbps
    FF, Chrome, IE
    G Data or Avira or Trend Micro or TrustPort
Skyferia
1
#15
Through trial and error, here's how I fixed it in order:
  1. Uninstall (using uninstaller in the 7z folder) -> Restart PC -> Re-install
  2. Run this program as administrator for 7z.exe, 7zFM.exe, 7zG.exe
  3. Ran CCleaner, analyzed & cleaned 7z
  4. Disabled Run this program as administrator for 7z.exe BUT the privilege remained active -> error gone, able to use the program normally
I hope that helps.
If anyone knows what actually happened, do inform. I'm interested.
    Windows 10 Pro
Telepod
33
#16
WinRar rocks, never had a problem and has everything. Workin great on 8.1 pro
    toshiba
    i3
    6Gb
    Firefox, Comodo
    Avast
