32GB Micro SD Card Slower than 16GB
Spoonhead98
Leicester
Hi, I have an Asus Transformer Book T100 and I wanted to use my SanDisk 32GB UHS Speed Class 1 Micro SD Card however when I copy files onto it (Usually large files) it starts to copy really slow but eventually stops. Comparing this to my 16GB Micro SD card which is only Class 4, it copies way faster. Both cards are SDHC andmade by SanDisk. Why is the 32GB card slower than the 16GB even though the 32GB card is rated faster?
Thanks
Yeah right. A Class 1 is really slow. You should really have a Class 10 card. I use that in my T100 and the performance is acceptable - but not more. I have all my user files on it and I also store images on it.
I also use a fast USB3 flash drive. That is a lot faster.
The 16GB card is Class 4. The 32GB card is UHS-1. The are both formatted with NTFS and the Default allocation size. I do not understand why the 32GB card is slower.
I just made the HD Tune test on a Class 10 MicroSD card. Read transfer rate is 10.2MB/sec and access time is 0.85ms. This may serve for comparison.
PS - don't get confused by the funny colors. This is a high contrast theme.
