32 bit, 64 bit?
602
    WCP
    HP
    [email protected] 4.9 Hz
    64 gig
    Nvidia 9600
    integrated
    laptop
    1440x900
    300gig internal and a bunch ext
    not much
    Built-in
    Logitch Anywhere Mx wireless mouse
    50 down 1.5 up
MadHorseman
Hi Pegasus01,
Take a look at:-
Intel® Atom)
This is your processor? - 32 bit intruction set. No Virtualization features which is probably why the Accelerator Tab won't work in Virtualbox.
Regards
Robin
    WIN7 Home Premium 64-bit
    Homebuilt
    Intel I7 920
    Asus P6T-Se
    6Gb
    Sapphire HD5770
    On-board
    ASUS VW246H, Samsing Syncmaster 2233, Samsung Syncmaster T200HD
    2 x 500Gb
    Coolermaster Silent Pro M700
    NOX
    Logitech Marble
    10Mbps
    Dell Inspiron 1501 with Win 8 CP 32 Bit - flying along!
Kevin Ismail
Revived
Solo.
2,161
If you have Atom N455 in it, with 2gb RAM. I guess it works well with 64-bit. Did it to My Samsung Netbook. The idea abut RAM is that 64-bit is capable to handle RAM up to 2 tb, while 32-bit just 4 gb or less.
    Windows 10 Pro 64-bit
    Home Built system
    Core i5
    Intel DH55PJ
    4 GB
    ATI 4650
    Realtek HD Integrated
    1280:1024; 1366:768;1920:1080
    SSD 256 GB
    Seagate Barracuda 500 GB
    WDC 1 TB
    Power
    Simbadda
    Conventional
    Logitech Wireless
    Logitech Wireless
    1.4 MBPS
    External HDD WDC 2 TB
    Dial Up Modem Huawei
    Home-made Home Theater
JaidynM
BSOD Kernel Dump Analyst
Gold Member
64-bit can be used on any system, regardless of how much RAM you have. 32-bit can do that also, however, it can only utilise up to 4GB of that RAM. Therefore, if you have anything less than 4GB of RAM, 32-bit is the way to go.
You said in your first post though, that you'll be upgrading to 4GB RAM. If you want to use all of that RAM, a 64-bit OS is recommended.
To make things a bit easier for us, would you mind filling out your system specs? You could do so by going to your profile (here) and clicking on the System Spec tab. From there, you should be able to fill them out one by one. Alternatively, you could simply fill out or post the brand and model of your netbook.
    Windows 7 Ultimate x64/Windows 8 Consumer Preview x64/Ubuntu 11.04
    Custom Build
    Intel Pentium Dual Core E6700 3.2GHz
    ASUS P5G41T-M LX
    Strontium 8192MB DDR3 1333Mhz
    msi GeForce N560GTX-M2D1GD5 1GB
    Realtek HD Audio
    CHIMEI CMV 221D 22"
    1680x1050
    Seagate 3.5'' 2TB HDD/WD Elements External 1TB HDD
    SHAW Viper-1500w Gaming PSU
    Black eMaxx ATX Mini Tower Case
    Microsoft Wireless Keyboard 1000
    Microsoft Wireless Optical Mouse 2000
    100GB @ 4.76Mbps
MadHorseman
N455 is 64-bit, but says max 2Gb memory:-
Intel® Atom
I reckon the Virtualbox route would be v slow - a dual-boot 64bit would be ok. I presume there's space on the HDD for a 25Gb partition?
Regards
Robin
    Homebuilt
    Intel I7 920
    Asus P6T-Se
    6Gb
    Sapphire HD5770
    On-board
    2 x 500Gb
    NOX
    Logitech Marble
    10Mbps
Ivan the SoSo
1,396
#8
Starter only comes in a 32 bit, two gig max ram.....So you will need a full copy of Windows home....
Also since this system was set up with Windows starter in mind it may not even be possible to upgrade the ram:(....How about those specs?:)
    Windows 8 Developer 32 bit
    junk system
    3200+ 2.2 gig Amd
    1 gig
    8500 GT
    Garbage from behind local computer store
    40 gig
    No front bezel, no sides,hard drive dangling by it's cables
    Heat rises....See case
    Old HP
    Pink, made in China, Ebay special
    DSL
jimbo45
Hafnarfjörður IS
4,373
#9
Hi there
I've got an acer aspire 1 netbook with the V105 processor -- upped memory to 4GB and changed to an SSD drive.
64 bit W7 / W8 preview works fine -- running also vmware workstation 8.02 with a W2003 Virtual server !!!! on the netbook.
Works ok so long as you don't try and run too many applications at the same time --especially if playing a movie using an external monitor opr the HDMI output.
A Netbook isn't intended to be a complete replacement for a more powerful machine but its surprising what you can actually do with it.
Cheers
jimbo
Cheers
jimbo
    1 X LG 40 inch TV
    2 X 3 TB sata
    5 X 1 TB sata
    0.12 GB/s (120Mb/s)
Kevin Ismail
Revived
Solo.
2,161
#10
I did it to my Samsung netbook. Another pleasure for a show-off-class teaching 3 days a week. :thumbsup:
    Home Built system
    Core i5
    Intel DH55PJ
    4 GB
    ATI 4650
    SSD 256 GB
    WDC 1 TB
    Power
    Simbadda
    Conventional
    Logitech Wireless
    Logitech Wireless
    1.4 MBPS
