2nd monitor goes black and says "Input Not Supported"
pcRat
MISTRESS SPECS.png Both monitors work fine in 'Extended' :dinesh:
or one-at-a-time thanks to Brinks "Second Screen" Shortcut - Create in Windows 8 :dinesh:
But when I choose to 'Duplicate' the 19" monitor says "Input Not Supported" . I've been researching but haven't found the solution yet. :mad:
19" monitor is onboard VGA
24" monitor is onboard DVI-D
ASRock Z77 Extreme4 also has onboard HDMI
    i7-3770K
    ASRock Z77 Extreme4
    16 GB
    onboard
    17" 24"
    1 TB WD
    550w
pcRat
Do both monitors have to be same resolution for duplicating the image on both?
I was hoping to use the second one to give a clearer view when I try to help others learn some basic computer stuff like cut/paste and simple excel.
    i7-3770K
    ASRock Z77 Extreme4
    16 GB
    onboard
    17" 24"
    1 TB WD
    550w
CountMike
I also have 2 similar monitors and both work in duplicate mode but with funny results, secondary one (VGA) has very elongated picture and is no help at all in that mode. Problem is most likely that secondary can't achieve same frequency and resolution as primary (DVI).
If you lower res and frequency of primary monitor to match secondary's capabilities, it should work.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
pcRat
both are 60Mhzbut one is 1920x1080 while the other is 1440x900
either one will work in duplicate mode on a laptop VGA. Maybe its just DVI / VGA don't play well together when screen size don't match
guess I could always hook my big screen up to the laptop VGA with mouse & keyboard for helping others
    i7-3770K
    ASRock Z77 Extreme4
    16 GB
    onboard
    17" 24"
    1 TB WD
    550w
alphanumeric
slightly off center
Gold Member
I think its a resolution issue. I run three monitors in extend. One is 1920 x1080 and the other two are 1280x1024. If I switch to duplicate my 1080P monitor and one of the others run in 1280x720 and the other just shows a blank screen. My guess is for you, its switching to a resolution that is not supported on one of your monitors. In duplicate it tries to run the same resolution on all monitors. It also appears duplicate only works with two monitors.
    Windows 10 Education 64 Bit
    Asus
    Thermaltake TR 620
    Stock heatsink fan
    Logitech Wireless K350 Wave
    80 Mbps Down 30 Mbps Up
pcRat
I'm only using 2 monitors. Maybe if both monitors were DVI-D or VGA it would duplicate. Guess I'll get a DVI-D to VGA adapter to find out.
Thanks for your response.
    i7-3770K
    ASRock Z77 Extreme4
    16 GB
    onboard
    17" 24"
    1 TB WD
    550w
alphanumeric
slightly off center
Gold Member
Put it in duplicate and see if you can change the screen resolution on the one that works. Lower it one notch and see if the other monitor then works. I should have left my last statement concerning three monitors out of my post. My three monitors are all connected via DVI. my main screen is HDMI from the video card and then goes through an HDMI to dvi adapter. I don't think that matters. I think it's the resolution being used, some monitors just will not display certain resolutions. Ideally you want identical monitors when using duplicate, otherwise like CountMike said, you get a distorted image. I noticed on my setup. my dispayed image was picture framed on one monitor and an incorrect resolution on the other. Plain and simple, it just looked funny.
    Asus
    Thermaltake TR 620
    Stock heatsink fan
