Optimizer Pro problem
frenchman96
Southport, UK
I try so hard to avoid adware, pop ups and such, but these sites sneak them in if they can.
I use Revounistaller to get rid of unwanted progs and I swear by it, but even after using it today, and it showed it had been removed, up to an hour ago, it was still appearing.
So...safe sites if you know any
This Optomizer Pro, if you know much about it
Cant get rid of this blighter
Hi Guys
Although I uninstalled this invader with Revo-Uninstaller, it still keeps appearing, but its not in the Revo list of installed progs, any advice please
Try Crap Cleaner it may show up with this
    Windows 8.1 Pro, 64 bit
    Samsung Series 5
    1tb
    IE 11
    Norton
Have you tried running any malware removal programs, such as Malwarebytes?
If not, please d/l it, the free version will work fine, make sure to uncheck the "start pro trial version" & do a full system scan with it. Check the box of anything it finds & let Mbam quarantine it.
https://www.malwarebytes.org/free/
Also, see this article:
How to Remove PC Optimizer Pro (Uninstall Guide)
It also wouldn't hurt to d/l & run these programs:.
AdwCleaner
AdwCleaner Download
TDSSKiller (To rule out the possibility of a rootkit)
TDSSKiller Download
    Win 7 32, Win 7 64 Pro, Win 8.1 Pro
    It's a Dell, Dude.
    Intel Caffinated Core Duo
    Father is bored too.
    4 GB
    NVidia something-or-another
    24" HD TV/Monitor/Alternative Dimensional Viewing Portal
    Fuzzy after a couple drinks
    2 or 3, depending on if it's a night they're arguing about having a "split personality crisis" because I partitioned the drive.
    Don't get on my case....man
    Scotch on the rocks on the weekends..
    Mad Catz Cyborg V7. Or maybe Cyborg Catz Are Mad At V7's??? I know it lights up...far out.
    currently being stalked by the cat...
    Never fast enough...
    Defeated by Mario...wait...OH...BRowser...
    Various
I'd get the latest version, install it, then uninstall it though the windows installer, restart your PC.
    Self built
    Intel Core i7-4790
    GA-Z87X-D3H
    G.SKILL 8GB (2 x 4GB) DDR3 F3-10666CL9D-8GBNT
    Sapphire ATI Radeon R7 250
    Realtek ALC892
    Samsung UN32EH5000, Dell 1703FPT
    WD5003AZEX
    WD10EZEX
    Samsung HD103SJ
    Samsung 128 GB 840 PRO
    SeaSonic M12II SS-500GM
    Fractal Design Define R4
    Zalman CNPS9900ALED
    Logitech K800
    Logitech M705
    16 Mbps
    Avast
    Bose Companion 2 Multimedia Speakers
Those links are safe. More-then-likely the malware trying to protect itself.
PC Optimizer Pro it’s technically not a virus, but it does exhibit plenty of malicious traits, such as rootkit capabilities to hook deep into the operating system, browser hijacking, and in general just interfering with the user experience.
    It's a Dell, Dude.
    4 GB
    Various
Hello,
If PC optimizer Pro Latest Program has come bundled with an updater service or registration service.
I believe it can be removed out of start up, or MS configuration Utility/+ Services. As well to delete the service with Auto runs.
This could help remedy the issue of the updater service.
Link Here:
Autoruns for Windows
    toshiba Satellite C850D
    AMD E1-1200 APU with Radeon(tm) HD Graphics
    4096MB RAM
    AMD Radeon HD 7310M
    AMD High Definition Audio Device Version=9.0.0.9902
    Video AMD Radeon HD 7310MVersion=13.151.1.1000
    1366 x 768 Pixels
    500GB installed
