Malwarebytes downloading problems
tinmar49
Having only MSE on two W7 pc's and on three W8.1 pc's, I thought that it would be sensible to heed the experts on this forum and on the W7 forum and start using Malwarebytes. I installed the free version on the first four, but forgot to untick the "trial version" on no 5. When it finished loading, I uninstalled from the W8.1 pc and when I reinstalled the option for free only no longer existed. I don't want the pro version so if anyone knows how to solve this problem, I would be grateful.
    win7 64
    athlon2x2 240e
    asus m4a87td evo
    2x4gb ddr3 1600
    ati 5670
After running the uninstall you can use CCleaner to clean up Registry Issues. I advise making a Restore Point and selecting to back up the Registry before selecting to resolve all issues. CCleaner is reliable but I did get one buggy version where I got burnt because I didn't select registry backup when cleaning. In the very next version that bug was fixed. Better safe than sorry though.
I'm guessing MBAM leaves a setting in the Registry so that you won't keep running Trial and getting a new 30 days or whatever it is, by uninstalling then installing again.
    Windows 8.0 x64
    AMD EI 1200
    4 gb DDR3
    Raedon 340 MB dedicated Ram
    Built in
    1366 x 768
    640 GB (spinner) Sata II
    Built in
    Touch pad
Perhaps if I wait for the trial period to expire I will be able to load the free version?
    win7 64
    athlon2x2 240e
    asus m4a87td evo
    2x4gb ddr3 1600
    ati 5670
