permission problem "unable to display the current owner"
    I am unable to change any permission for any folder . every option that supposed to be available for setting the permission is gray out!! , for some of my files I see the owner is "unable to display the current owner".
    I have attached the 3 screen shots !!
    please help me
    Windows 8 Pro
    Do you have UAC toggled on?
    you need to do that then take ownership of the folder(s) from the advanced properties.
    The UAC is toggled on as always. the problem is the same for every single folder and file. I checked other systems and they are working just fine ! but I am just unable to modify any permission for any folder or file !! even I tried to change the owner but it didn't worked !!
    Windows 8 Pro
    The last time I had this problem , I had to download and boot into Linux mint from a DVD I made and used
    chmod -R 777 \mydirectory
    and
    chown -R username \mydirectory
    to set read/write/execute and set owner from there , it's not ideal , but it was a workaround which let me then set permissions under Windows afterwards.
    I am fairly sure you can do the same from the GUI under linux mint as well.
    I keep my linux mint DVD handy at all times these days , sometimes it's the only way to fix drive/file permission problems under Windows.
How to Turn Navigation Pane "Expand to Current Folder" On or Off in Windows 8 and 8.1 This tutorial will show you how to turn Automatically Expand to Current Folder on or off in your File Explorer navigation pane in Windows 8. If Expand to current folder is turned on (checked), the navigation...
In Internet Explorer which I only use for safe sites and testing (my main browser is Firefox) I am getting an annoying message which I can't get rid of - it comes back on every new page. "Your current security settings put your computer at risk". It's obscuring a not insignificant part of...
Arrrgh! :mad: When I copy into certain folders I keep getting nagged that I have to get "Administrator permission to copy to this folder". I am the administrator and I know what I am doing. Please before I go crazy with all this patronising nagging............. please tell me how to turn this...
Hello, I have searched extensively for a solution to my problem and everything I have found thus far simply shows me how to setup permissions to modify files. I apologize in advance if this is not the proper place or etiquette for posting. I have a game file that I have deleted/modified many,...
I was hoping these permission issues from Windows 7 would have been resolved, but apparently not. Using the default Scan software, I've specified the directory for saved images to be on a secondary drive, but the images won't save. Any suggestion as to how I can resolve this issue? Preferably...
Hello all, I'm new here, so please bare with me. I'm assuming this is the appropriate section of the forum to post this question, so here it goes.... I've just had Windows 8 Home installed over the past months, and have now come across a strange problem, which seems not uncommon from other...
Hello! I'm trying to registrer the .ocx's mentioned above. I first put the .ocx's in the windows/system32, and thereafter ran the regsvr32 command in cmd (as an administrator). I also tried to registrer them from the windows/SYSwow64. (I run x86). However, I get the following error for both of...
