Audio Craziness
    Windows
    Audio Craziness
    Hi Guys,
    So fairly new to the forums. I finally got W8 up and running after some drama with my SSD and WLAN drivers. Now i'm online and all but the audio drivers/settings are going kinda crazy. I'm running an ASROCK Extreme4 970 with the HD audio connector connected to headphone jack of my tower's front panel. Through that I use a set of Audio Technica M80s. Now, the crazy thing is when I've got my headphones plugged in while in W8, the system seems to detect my headphones/audio device over and over again. IE, it'll see my headphones and my onboard audio, then lose it, and then redetect it. Everytime it does it I hear a "boop" sound and it gets pretty annoying (think someone plugging/unplugging a USB device over and over again).
    I was wondering if anyone has had a similar problem and has a solution or know of where I can find it.
    Thanks in advance,
    Jason.
    Orbiting the Moon
    Windows 10 x64
    Hi there. Welcome to the forums.
    There are some options:
    Recommended:
    Since you're on Win8, try to find sound drivers for your card here:
    Microsoft Update Catalog
    (Use IE for this site!)
    Search the (model) name of your sound card. (or the hardware ID's)
    If there are new drivers, install them (cab files -> extract first) from Device Manager.
    After that, if the problem is still there, there is a chance to be an improper connection between the jacks (cable problem, connector problem)
    Optional:
    When sound get annoying (I know what you mean) it's better to disable that ridiculous sound scheme:
    right click here:
    This is just a tweak in case the new drivers (if they exist) don't fix the problem. But can be applied when sounds get annoying.
    Hope this helps.
    Hopachi
Audio Craziness
Hi all, I recently bought a Win 8 box and all seemed to be going well for the first few days. Since then, several of my apps have started acting weird - eg, crashing upon launch, hanging, not responding for a minute or two and then coming back t life. Unfortunately, Windows Update is also...
