How to get volume on screen display?
qwertymz
I just installed Win8 on my acer netbook, upgrading from Win7. On my previous os, whenever I changed the volume on the keyboard, a little image would pop up on the screen, showing a bar representing my speaker volume.
This is not on win8. Can anyone tell me what to install to get it back?
Thanks.
    Win8 Pro
You need to reinstall the drivers and other "add on" files that originally came with your laptop.
If you are lucky, Acer will have these for download off their website for your model...
    Windows 7/8
Hi qwertymz,
Did you mean the one in the pic or the Acer's original Volume indicator?
As FSeal said, try Acer's Launch Manager Application, volume indicator in the pic works in Win 8RP.
    Win 8.1
    Acer Aspire E1-571
    i5-3230m
    Acer Type-2
    8GB DDR3 1333MHz
    Intel HD 4000
    High Definiton Audio Device
    Generic
    1366x768
    Samsung 850 Pro 256GB
    Generic
    QWERTY
    ELANTECH Touchpad
    12.68Mbps
    IE11
