Sound from all channels under IE10
    Windows 8 CP
    Whilst I plan on experiementing more, to work out what precisely is affected, I'm noticing something weird in Win8 RTM.
    I am using a Nvidia GTX680 over HDMI, taking 7.1 @ 16/48, to an external audio processor.
    If I play a .wav file through Windows Media Player, all is normal. Stereo output only, with all channels active but only the front pair carrying audio. If I preview some audio from a music vendor through IE10 I get audio from *all* channels.
    This is unusual behaviour, which I have never noticed prior. It is similar to if I left the audio output over HDMI to stereo and my external processor was set to "all channel stereo". Which I wouldn't do, heh.
    Anyone come across this, or have any ideas what is happening here?
    Cheers
    CDJay
    Windows 8 CP
    This is flash 11.4 related, so any fixes will come from Adobe.
    For anyone concerned!
    CDJay
Solved Audio channels reversed using USB in Drivers & Hardware
Not sure if this is a hardware or Win 8 problem. I've now run four dacs off two USB 2.0 ports and each has had the channels reversed, per the Windows 8 Sound test among others. There is no problem with the Dacs - I've checked elsewhere - and the interconnects from the Dacs have run to the proper...
I have problem with Muliple Broswer tabs (self) opening & pointing to microsoft.com "IE10 start here" pages and when using Outlook it goes to MSOFFICE.com "start here" pages when trying to type in Outlook emails. It is quite something to see over a hundred cascading windows trying to get you...
Is there a way to swap left and right channels ? I couldn't find a way in my titanium x-fi sound card settings and software . Thanks.
Hi. Maybe you know a way to watch BBC channels online without that frustrating proxy business? Any ideas would be helpful :) Thanks.
Hi there Unfortunately it's currently (or seems) currently impossible to get Video to play in the IE version shipped with IE10. Even when you get it pinned to the taskbar and can launch it from the desktop --when you try and get Adobe flash player this is what appears. (screen shot enc). You...
Hi there the version of IE10 shipped with Server 2012 seems to have a defect -- can't play video from web sites -- sound is fine. Not sure if this is actually a real problem as you don't usually do much browsing on a server -- but as this version of IE10 is nearer RTM than that shipped with W8...
Hi, Sorry if this has already been asked - I'm trying to catch up with developments and it seems easier asking rather than blundering my way between Metro and Normal mode. For regular browsing I'm using IE10 from the normal Windows desktop. I find that if a program opens IE10, it opens the...
