Auzentech cards do not work
    Just a heads up, have auzentech prelude (junk I know) and the drivers dont work in windows 8
    Santo Domingo
    Windows 8 Enterprise x64 Evaluation
    I have a Prelude card too and I'm about to install Windows 8 Enterprise Evaluation. What's the problem? Is it that it just won't install or that it installs and doesn't work or work with issues? That's a real bummer and I really hate what Auzentech did to us customers.
    Quote Originally Posted by xankazo View Post
    What's the story on that? Checking my email, I bought a Prelude 11/2007, eBay'd it 11/2008. I ended up going with mobo audio for my HTPC/general PC and an X-Fi for my gaming PC.
    Santo Domingo
    Quote Originally Posted by gizbug View Post
    BTW, did you tried Windows 7 Compatibility Mode while installing?
    It installs, reboots, but does not work.
    Santo Domingo
    Damn! I guess I'll have to use the onboard soundcard then. I hope it is supported after all. It's an ALC-888 from a Gigabyte GA-P35-DS3L board.
    Santo Domingo
    So, I installed Windows 8 Enterprise Evaluation and the Auzentech Prelude works! Yes, everything I've tried works as it should, DDL, DTS, etc. The only drawback is that it reverts to Game Mode after every reboot. But I pay no mind to that.
    Just make use you use "Windows 7 compatibility" and "Run as administrator" when installing.
2 graphics cards? in Graphic Cards
Hey guys, I recently downloaded CPU-Z to check detailed specs about my laptop. When I went to graphics I encountered something I did not understand.. Please check the screenshots and explain to me what this is. Do I have two graphics card or what? http://i62.tinypic.com/vz9ekh.png ...
Two graphic cards in Graphic Cards
I have installed the windows 8.1 at laptop hp g62-a80sv and when i have installed the drivers for both cards the windows 8.1 it restart every time it doesn't go into windows 8.1. If i uninstall or disable one of these two graphic cards then for one time it begin the windows 8.1 but still find...
Alright guys, I have just refreshed my pc because I was having numerous problems with it and it turned out to be a bad stick of RAM. However, now I am having software issues. Whenever I try to make a call on the desktop version of skype, the program crashes. Whenever I try to open HP support...
Greetings. having som troubble with my soundcard, Auzentech X-Fi forte 7.1 Auzentech, Inc. X-Fi Forte PCI-Express Soundcard : World First soundcards for Music, HTPC, and Gaming after one of the win8.1 updates from Microsoft. Some times, but not every time, the soundcard resets all settings to...
SD cards hacked in Windows 8 News
Read more at: SD cards hacked | ZDNet
graphic cards do not appear in Graphic Cards
hi guys today i installed win8 , i have intel and nvidia my geraphic cards are working properly(the have correct in device manager) but when i right click desktop i can not see any option for access the propertise of them like win 7. or when i want to open a program by one of them there is no...
I hae a dell m1710, installed win8 rtm on it. In win 7 i have 2 options of digital audio out: 1. Turtle Beach Audio Advantage Micro usb with optical S/PDIF out 2. Dell composite video adapter with digital coax out. Sigmatel high definition audio codec In win 8 i tried first the Audio...
