No sound
Eve
I am a person
Behind you
Hi I installed Windows 8 on my laptop and got the audio drivers installed all fine and dandy... Except that's what Windows says.
The driver says it is working properly and when I use the sound (Like playing something on Itunes) windows does the animation in the sound mixer like it is working but there is no sound.
Acer Aspire 5315
Realtek High Definition Audio
Windows 8 RP (x86)
Any help appreciated.
    Windows 7 SP1 + Linux Mint KDE x64
    Custom
    AMD A8-3850 APU
    ECS A75F-M2
    10 GB (8GB Kingston + 2GB Kingston) DDR3
    AMD Radeon HD HD 6550D (APU)
    "High Definition Audio Device"
    DELL E171FPb
    1280 x 1024
    Seagate 1TB
    120W
    Antec 900
    1 CPU fan, 2 HDD (front) fans
    Dell Keyboard
    Logitech M305
    down: 12.92mbps up:3.86 mbps
    Mozilla Firefox
    Avast!
I have an Acer T690. Although a PC, it's similar so far as brand and Intel made MOBO.
Your system specs on the Acer site states that your Sound Subsystem is an Audio system with built-in speakers - SoundBlaster Pro and MS-Sound compatible. Acer Support: Aspire 5315 Series Specifications
Was it working with prior OS? If so, what OS? Do you know if it has a SoundBlaster card?
The Realtek High Definition Audio may not work on your system. Did you install that or was it installed during 8 install?
Try and update the driver in Device Manager. Check the lQQk online. If that doesn't work, you may wanna try to uninstall the Realtek driver and get the SoundBlaster driver or one from M$.
    8.1 Pro X64
    Acer T690
    Intel Pentium D Dual Core
    Acer/Intel E946GZ
    2GB (max upgrade)
    Acer AL1917W A LCD
    1440 X 900
    Thumb drives
    Standard 250 watt
    Dual case fans + CPU fan
    Acer Windows PS/2
    Wireless Microsoft Arc
    54mbp/s
    IE11
    Defender
I tried all of the above except for the soundblaster drivers(because I know I don't have soundblaster) and none of it appeared to work... I was up until midnight and even did a system refresh.... nothing....
I hibernated my machine to go to bed and started working on it again about 10 minutes ago and somehow I have sound...
I honestly don't know how (if I did I'd tell).....
Thanks for the reply anyways..
Mods you can close/delete if you want.
    Custom
    AMD A8-3850 APU
    ECS A75F-M2
    DELL E171FPb
    1280 x 1024
    Seagate 1TB
    120W
    Antec 900
    Dell Keyboard
    Logitech M305
    Mozilla Firefox
    Avast!
That's good! I love it when a bug works itself out. Like a noise in my car. Before I find the time to see what it is, it goes away.
Enjoy your sound.
2-a-roo for now.......
    8.1 Pro X64
    Acer T690
    Acer/Intel E946GZ
    2GB (max upgrade)
    Acer AL1917W A LCD
    1440 X 900
    Thumb drives
    Standard 250 watt
    Acer Windows PS/2
    54mbp/s
    IE11
    Defender
Well.... Installed video drivers and no sound again... hibernate computer, wake it up, sound again...
Is there a process that controls sound I should restart (other than windows audio service, I tried that)
    Custom
    AMD A8-3850 APU
    ECS A75F-M2
    DELL E171FPb
    1280 x 1024
    Seagate 1TB
    120W
    Antec 900
    Dell Keyboard
    Logitech M305
    Mozilla Firefox
    Avast!
No process. Shouldn't have to do anything. That's weird. I don't think I've ever come across this before. What would a new video driver have to do with it?!
Just after hibernation? When you restart, no sound? Was it working with prior OS? If so, what OS?
    8.1 Pro X64
    Acer T690
    Acer/Intel E946GZ
    2GB (max upgrade)
    Acer AL1917W A LCD
    1440 X 900
    Thumb drives
    Standard 250 watt
    Acer Windows PS/2
    54mbp/s
    IE11
    Defender
i had Windows 7 64bit (installed x86 windows 8 because I was running slow due to lack of ram.)
I had Windows 8 RP on this machine awhile ago and it worked perfectly fine... I'm not sure why this is so different...
and here's how it works:
I boot my computer
No sound
I Hibernate my machine
turn it on from hibernation
i have sound...
    Custom
    AMD A8-3850 APU
    ECS A75F-M2
    DELL E171FPb
    1280 x 1024
    Seagate 1TB
    120W
    Antec 900
    Dell Keyboard
    Logitech M305
    Mozilla Firefox
    Avast!
This has got me stumped. Any yellow exclamation points in Device manager anywhere? Is the modem working? Check that in Device Manager while there. I know that may sound weird, but that affects sound via hardware.
In the mean time, I'll run this by some friends to see what they think.
    8.1 Pro X64
    Acer T690
    Acer/Intel E946GZ
    2GB (max upgrade)
    Acer AL1917W A LCD
    1440 X 900
    Thumb drives
    Standard 250 watt
    Acer Windows PS/2
    54mbp/s
    IE11
    Defender
Nope.. Everything checks out okay with hardware....
    Custom
    AMD A8-3850 APU
    ECS A75F-M2
    DELL E171FPb
    1280 x 1024
    Seagate 1TB
    120W
    Antec 900
    Dell Keyboard
    Logitech M305
    Mozilla Firefox
    Avast!
Ok. I see no one has responded yet. Hold on for I'm sure they will.
    8.1 Pro X64
    Acer T690
    Acer/Intel E946GZ
    2GB (max upgrade)
    Acer AL1917W A LCD
    1440 X 900
    Thumb drives
    Standard 250 watt
    Acer Windows PS/2
    54mbp/s
    IE11
    Defender
I see no one has responded still. Howz things on your end? Any solution?
    8.1 Pro X64
    Acer T690
    Acer/Intel E946GZ
    2GB (max upgrade)
    Acer AL1917W A LCD
    1440 X 900
    Thumb drives
    Standard 250 watt
    Acer Windows PS/2
    54mbp/s
    IE11
    Defender
No :/
I'm thinking of doing a clean install (Every time I install Win8 I get a different outcome)
I'll let you know how that goes... I won't do that until Thursday or Friday because of work.
    Custom
    AMD A8-3850 APU
    ECS A75F-M2
    DELL E171FPb
    1280 x 1024
    Seagate 1TB
    120W
    Antec 900
    Dell Keyboard
    Logitech M305
    Mozilla Firefox
    Avast!
OK. Good luck!
    8.1 Pro X64
    Acer T690
    Acer/Intel E946GZ
    2GB (max upgrade)
    Acer AL1917W A LCD
    1440 X 900
    Thumb drives
    Standard 250 watt
    Acer Windows PS/2
    54mbp/s
    IE11
    Defender
No :/
I have the same problem and a reinstall did not fix it for me
    home built
    phenom II
    gigabyte
    2gb ddr2
    radeon hd4200
I found out it is just a driver problem... Realtek hasn't released the drivers for Windows 8 so Win8 is using the Microsoft drivers which aren't always the best. Hibernating wasn't a problem for me because that's basically what hybrid shutdown was. So as long as I didn't restart I don't have to hibernate and log back in.
    Custom
    AMD A8-3850 APU
    ECS A75F-M2
    DELL E171FPb
    1280 x 1024
    Seagate 1TB
    120W
    Antec 900
    Dell Keyboard
    Logitech M305
    Mozilla Firefox
    Avast!
Hi Eve.
Win 8 RP does have a problem here and there. I means different driver problem on different machine. My ASUS has problem with LAN driver, but it was fixed when installing Windows 8 RTM.
You may want to instal the RTM Version as it handles Win 7 drivers driver more friendly.
I presume that you already have the latest driver from Acer website. I found there are some workarounds to try, it might work but not always though. One of it is installing the driver in compatibility mode.
You also may want to check the physical sound port. The sound port has contact sensor if any audio jack is plugged or unplug. The driver software keep monitoring it to automatically decide the internal or external speaker to use with, as long as the system is on. it might get dusty. Try plug and unplug any audio jack several times to see if it responds.
Only my two cents. But hope it helps.
Kevin.
    Windows 10 Pro 64-bit
    Home Built system
    Core i5
    Intel DH55PJ
    4 GB
    ATI 4650
    Realtek HD Integrated
    1280:1024; 1366:768;1920:1080
    SSD 256 GB
    Seagate Barracuda 500 GB
    WDC 1 TB
    Power
    Simbadda
    Conventional
    Logitech Wireless
    Logitech Wireless
    1.4 MBPS
    External HDD WDC 2 TB
    Dial Up Modem Huawei
    Home-made Home Theater
Hi Eve.
Kevin.
I would install the RTM but the only one available to me is the beta and that times out after 90 days. I don't have a dev. account anywhere (trust me if I did, I would have it by now :p)
I thank you for your help, and I'll look into finding a way of getting the RTM somehow...
    Custom
    AMD A8-3850 APU
    ECS A75F-M2
    DELL E171FPb
    1280 x 1024
    Seagate 1TB
    120W
    Antec 900
    Dell Keyboard
    Logitech M305
    Mozilla Firefox
    Avast!
90 days worth a challenge. :p
Be a Technet subscriber will help. ;)
    Home Built system
    Core i5
    Intel DH55PJ
    4 GB
    ATI 4650
    SSD 256 GB
    WDC 1 TB
    Power
    Simbadda
    Conventional
    Logitech Wireless
    Logitech Wireless
    1.4 MBPS
    Win 8.1
    Acer Aspire E1-571
    i5-3230m
    Acer Type-2
    8GB DDR3 1333MHz
    Intel HD 4000
    High Definiton Audio Device
    Generic
    1366x768
    Samsung 850 Pro 256GB
    Generic
    QWERTY
    ELANTECH Touchpad
    12.68Mbps
    IE11
Try the Realtek Vista_Win7_R263. It is several versions ago. I run it in Vista compatibility mode. It is still, for me, the only 100% reliable driver set from realtek. I used it through the Windows 8 public releases, and now in the RTM. I recently tried the Realtek drivers, written for Win 8. They failed to re initiate after sleep.so I went back to the above
    Use several different computers during a day, so specs are irrelevant.
