weird sound.... coming from speakers
  1. #21
    Windows 8.1 Build 9600
    Quote Originally Posted by Kevin Ismail View Post
    Noel
    Just additional thought here.
    I think I agree your problem might be caused by an oscillating circuit in which some sensitive area in your motherboard's sound circuit isn't properly shielded or grounded, and something is caught in your netbook casing. It could just caused by (possibly) the repairman forgot to put back the shield or or drop something into it (who knows).
    If you decide to open the screen cover yourself to check the cable assembly, you'd better do it cautiously as the screen mostly using delicate transparent ribbon cables routed trough the hinge with double adhesive tape.
    I feel like you should insist in having the repairman reopen and reassemble it.
    Kevin
    yeh i should, but it costs a lot for me to let them recheck i know it may seem overpriced but in the mall it costs 1500 php or around 35 USD to check and repair there's no separate fee of repair/check
  2. #22
    Portsmouth Hants
    What could find that information on the internet?
    Aspire one D255 disassembly perhaps:
    Let me google that for you
    Look out for manuals, you tube videos, things that say walkthru or tutorial perhaps.
  3. #23
    Solo.
    Windows 10 Pro 64-bit
    That weird, 1500 pesos for check and repair? I can understand why it get hard to deal with those people.
    Without experience, I might say it is not advisable to open it yourself. But you can ask for some assistance from well known friend with some experience with notebook repair.
    Kevin
  4. #24
    Kevin
    thanks
    for now mark as solved.....
  5. #25
    Did you get it resolved then? Will you please share how?
  6. #26
    sorry didn't know , i asked them to open and check all cables again then they did .... i dont know whats wrong on the cables but they routed something
  7. #27
    Thanks for sharing that it's fixed. Good that you're up and running! Enjoy!
  8. #28
    Solo.
    Well. Let's assume they did mess up with your machine and got it fixed up now. Maganda talaga
  9. #29
    Quote Originally Posted by HippsieGypsie View Post
    hehehe... sorry for not giving detailed info on how i fixed it... they messed up my system and wont show me to their room where they fix things xD
  10. #30
    yeh they did .... thanks... wee you used google translate ? :P (out of topic)
Page 3 of 4 FirstFirst 1234 LastLast
I have an HP laptop running 8.1. I did update my computer or I restarted after an automatic update but no sound comes from speakers or head phone jacks. I have checked my drivers and they are working. My sound is not on mute. Any suggestions?
No sound from speakers in Sound & Audio
Hi. Just got my Acer Aspire E5 572g back from repair at Acer Repair Center. They switched out my prosessor, but now i got no sound. The computer came back with a clean install og win 8.1. Added a screenshot showing drivers and that sound is "playing"...
Just set up new asus essentio series desktop with windows 8.1. After initial set up the monitor speakers are on but no the connected external speakers. I assume I need to make some change in the control panel. Is that true. I want sound to come through external speakers.
Latest version of W8 This will take a while A few months ago W8 quit producing sound through my speakers - overnight. I've tried a number of things I'll list here. Volume Control - red 'x' in bottom right corner. AMD HDMI OUTPUT and HEADPHONES are checked. Troubleshooting Speakers/headphones...
Ghost sound/speakers.. in Sound & Audio
Hey guys So this is a weird one... I have a Xonar D2 sound card, and the Xonar D2 Audio Centre, all sound thru my speakers and headphones fine. All music, games, skype are heard and picked up on the D2 Audio Centre just fine. HOWEVER When I open the Volume mixer, almost every program I have...
Hello, I just bought a new pc and received it today, and i plugged my headset in to check if i hear audio from both speakers and headset but its not working. When i plug my headset in i only hear audio from my headset and not the speakers. Ive been googling and found something about it but with...
