external mic not listed under recording devices
    windows8
    So as the title says, I have an external microphone that uses a XLR to 3.5mm jack plugged into my computer (laptop with seperate 3.5mm jacks for output/input) but the microphone is not even listed under recording devices and cannot be used.
    When clicking show disabled/hidden devices the Stereo mix shows up, otherwise it is just the default built in interior mic. I have tried checking for driver updates but when running the windows option for automatically check driver updates it says I am fully updated.
    I'm not sure how to even start to approach this problem, and really appreciate any help. Thanks!
    Sounds like the adapter is the issue. I have a recording studio but have never used an XLR to 3.5mm adapter. If the XLR microphone requires phantom power, that could be the issue as the mic will not work without the phantom power (normally 48VDC and the PC mic jack will only supply 5VDC which is not enough for most mic's. Even if that worked you are going to have problems with the mic volume level, unless the adapter is also amplifying the mic volume level. Mic level is very low (more like "instrument level") and a PC sound requires a high volume level, almost "line level".
    windows8
    Thanks for the response. I do also have a phantom power supply hooked up. The mic is a neewer nw800, and I have a 48V neewer phantom power supply hooked up as well. Since the 3.5mm jack is dedicated input I am not sure what is going on, but I am going to buy an XLR to USB cable and see if that is recognized by the computer.
    I am trying to avoid buying a sound board or mixer to save money, but if I end up having to do so, would you have any recommendations of affordable ones that work well?
    Thank you for the response and help
    A USB "Recording Interface Unit" is really what you need. Along with providing a proper preamp interface for a mic, they also provide the 48V for Phantom Power. There are many relatively inexpensive USB bus powered interfaces.
    Here is a Behringer for $39.99 from Sweetwater Music (my on-line store of choice for recording hardware).
    Sweetwater.com (800) 222-4700
    windows8
    Thanks for the help, I appreciate the recommendation! As someone new to audio recording this was really helpful, thank you.
    The Behringer I linked isn't great but will get you started. If you are serious about recording, you will want to migrate to something better and a full recording program instead of something like Audacity. I use Cakewalk Sonar in my studio.
I recently got a USB headset setup. It wouldn't seem to work with my internal mic. I disabled the internal mic under the recording tab in sound in the control panel. Once I did that, the headset started working. However the internal mic is no longer listed in the recording tab. Does any one know...
Sorry, very new at all of this. I have a Dell Inspiron 660 PC w/windows 8.1 no matter what I plug into the usb port I cannot find it on my computer. I hear the connect/disconnect sound, but can't find anything on the computer as to where it is at or how to open it. The device is a storage device...
Duplicate PCs Listed in Browsers & Mail
So I have been using IE on my Windows 8.1 tablet and I've noticed that on all of my PCs, my tablet shows up twice. Here are the synced tabs/PCs that show up: MMComp (Family desktop - Windows 8.1) - Current Tablet (My tablet - Windows 8.1) - Current Tablet (My tablet again) - Appears to be...
hi there, I have an iomega portable usb drive. I can plug into any of my windows 7 machines and access the files and store data on it. when I put into my win 8 machine it shows in devices and printers and in my computer shows as removable disk but you cannot open it up. I have went into...
External Devices stay Offline in Network & Sharing
Hi, Hope this is in the correct section I have a small problem under the Devices and Printers option I have 2 external devices (Xbox 360 & BluRay Player), these devices are shown in Windows as Offline (even when turned on), so when I try and to a 'Play To' it says no devices If I go into...
After upgrading to 8.1 all of my previously listed devices are no longer listed under devices... in fact there are no devices listed. I can also not add a device. If I look in device manager they are listed there and if I go to print the printer shows up and I can print. The screenshot below...
Why is one of my four internal hard drives listed as a Portable Device in Device Manager? Removing it from Portable Devices does not remove it from Disk Drives and then it all looks normal and functions normal, until I scan devices or Windows reboots. It also functions normal when it is...
