Audio manager stops working, and essentially breaks comp
    US
    Hello,
    For as long as I can remember, I've had an issue where audio manager will stop working, and it will break the entire computer. Once audio manager stops, anything requiring audio ceases to work, including games. When I press the mute/unmute button on my keyboard, the taskbar will freeze up and become unresponsive.
    I've figured out a "solution", which involves leaving a game open the entire time I'm using the computer. If I close the game, sometimes audio manager dies instantly. Other times it takes a few minutes. There are times where audio manager dies when I start up the computer for the first time in the day, forcing me to restart.
    There's no viruses, as I've done several scans...I have no clue what the issue could be.
    I'm using a Lenovo ideapad U530 touch.
    Look at what is in startup (and the notification area - lower right). Maybe a program that is starting is causing it.
    Unfortunately, it may take a "clean" reinstall to fix it.
    US
    I don't think it's necessarily a start up specific problem. It can happen at any point if I exit out of a game. It's as if my laptop is relying on games to keep audio manager working.
    I've seen games cause various problems when they are exited. Poorly written games may not release the audio, for example and thus after the game there is no audio.
    US
    None of the games I've used have been poorly written or had said issue. It seems to just be something on mine.
    Does this happen if you do not play any games?
    US
    Yes it does. What seems to trigger this is if any type of app that uses audio is opened, such as a browser tab that has Youtube.
    Still sounds like whatever app is using sound is not releasing it.
    What browser are you using? I.E. 11 or some other such as Chrome or Firefox?
    US
    I use both FireFox and Opera.
    If they aren't releasing sound, how do I force it to?
Sound stops working for one second or two
Hello, for a couple of days I started to get thoose sound bugs, it stop working for a second and then the sound continues again. This happends when i'm watching a serie or listening to music, whenever I open a new tab on my chrome the sound stops for like a second maybe even a milisecond or so. ...
Help: audio stops working after a while
I am having some problems with my laptops audio. The audio always cuts off after a while and doesn't work until I restart the PC. I have installed the newest drivers and also rolled back to the older drivers, I have tried disabling and enabling the sound card nothing seems to be working. After I...
Audio stops when plugging earphones / speakers to 3.5mm
Hello, I have a Lenovo G510, and many times (most of the times) when I plug earphones or speakers to the 3.5mm jack, the audio stops, and a red X appears on the Speakers icon in the notification area, and I have to press Solve problem and then it detects that the speakers stopped working (I will...
Realtek HD Audio Driver stops working when comp sleeps.
Hello, I recently got a set of 2.1 HiVi Swan M-10 speakers and hooked them up to my laptop until I can finish my build. When I first hooked them into my E55-A Toshiba Satellite the bass wasnt coming from the sub in fact it was combining into my L/R speakers making them sound terrible. A quick...
Audio driver stops working, system hangs at shutdown
For the past few days my laptop, a Windows 8 Samsung model with Intel core i5, has been acting up for the first time since I purchased it last year. I've been away on vacation for three weeks, and have not used it during that period, so when I returned the system naturally installed itself with new...
Sound/Audio randomly stops working?
Okay well this happened like 2-3 weeks ago, i have an extremely annoying problem.. The sound of my computer would randomly stop working for some reason.. Not only that, but when i watch youtube the video or any video it won't load and it would literally pause or freeze. To fix this i would have...
Install stops at HP ProtectTools Security Manager Suite not compatible
Does anyone know an easy way to uninstall/remove HP ProtectTools Security Manager Suite on a HP ProBook 4510s notebook running Windows 7 to allow Windows 8 upgrade to continue? The install message is that it is incompatible with Windows 8 and needs to be uninstalled.
Installation & Setup
