How to get Realtek HD Audio Manager
    I have an HP-15 laptop running windows 8.1. It has the Realtek High Definition Audio.
    I have the driver installed, updated and all, but I don't have the manager.
    Can i download this somewhere? Thanks.
    Some of that is controlled by what was activated by the PC vendor.
    You can try the full driver direct from Realtek, which has the manager but no guarantees.
    Realtek
    I've seen others that had features limited (in the Realtek chip) by vendors and there is nothing that will restore it, other than using a separate sound card. On a laptop that would involve using a USB attached sound card that had the desired features.
    Yes I just tried the driver direct from Realtek and it did not install the manager. I guess I don't have this feature.
    That driver also does not have an "enhancement" tab in speaker properties to access the equalizer and presets. The latest driver from HP is similar - no enhancements. If I uninstall/roll back that driver, then the enhancements show. Turns out that I like the default sound just fine so its not a big deal. Thanks for the info.
    Quote Originally Posted by manters View Post
    The Realtek HD Audio Manager is supposed to show up in the Control Panel window of Windows 8.1 (click on All Control Panel Items to see if it is there). If it is not there even if all Control Panel icons are displayed, then your HP laptop may not really support it as fireberd said.
    BTW, the Realtek HD Audio Manager control panel app does show up on my father's Toshiba C55Dt-A laptop [I'm using v6.0.1.7801 and although v7831 is available from MS, I won't need to update to that version] and uses DTS Studio Sound enhancement (and I do get the Enhancements tab in Speaker properties dialog box AND a DTS tab in the Realtek HD Audio Manager app) - double whammy
    Thanx for the info. I have the same problem and I thought it would be easer to find the maganer but actually it is not.
    Quote Originally Posted by stefan woj View Post
    what kind of computer are you using?
    most of my Win7 & Win8x PCs that have onboard Realtek HD audio do have the Realtek HD audio manager installed and listed in the Control Panel, except for my brother's Sony Vaio laptop which also uses Realtek ALC269 audio but no audio manager app installed there.
    denmark
    windows 8.1
    Try Bongiovi DPS,it is an alternative sound card,I think you are gonna like it,I did anyway
I have the asrock z77 extreme 4 mobo and when i originally installed it it had realtek audio manager on it, but after a while and upgrading to windows 8.1 it doesnt seem to be on my system anymore. I have gone through my files and downloaded the newest drivers to no avail, if anybody could guide me...
If I jump forward or back to a different track, if I start a different video in VLC, if I jump back on youtube to replay a part in a video or click on a different video, anything I do and the graphic equalizer in Realtek HD Audio Manager resets. What gives? Thanks!
I am fairly sure I had this manager when I started with windows 8 . I have also done a clean reinstall after hard drive crash. it shows the in and out sockets on the back of the board(gegabyte GA-970A-DP3) AND ALOWS ME TO RE ASIGN THEM.. Can any one tel me how to get it back. very greatfull for...
I have Z87 G43 Gaming Motherboard, it is strange that the Realtek Audio manager no longer starts automatically on startup. I see there is no startup icon in that folder. I uninstalled and reinstalled the Realtek software, but still it does not start automatically. Not sure what could be the issue....
Whenever I use my computer, if I don't play any audio on my computer for a certain period of time, and I have to restart the computer. It's really annoying because I like to view Facebook and Tumblr for a while before I do something such as playing Team Fortress 2. Is there anything I can do...
Hi I need help, can't find a solution and this is slowly driving me crazy... I installed the realtek drivers and they appear as installed in the control panel but it does not show up at the start up of windows, I have tried installing the latest drivers from realtek official page and the lates...
I'm using a windows 8 pavilion g7 laptop. Long story short, I wanted to have realtek HD audio on my computer mainly for the cool audio effects that come with it because the audio drivers that came with my computer don't have those effects. Nonetheless, I installed realtek HD audio hoping it would...
