I can't hear speaker rear in 5.1
    Windows 8.1 64x
    Hi
    i can't hear sound from speakers rear. I have 5.1 configuration.
    I try click in Speaker configuratio and all speakers works correctly
    Also i can't set off audio improvement
    I try unisnstall Real Tek audio drivers.
    Also i try to reinstall old and new drivers.
    I have DTS Audio control panel
    When i try to test with click on any speaker there isn't sound
    In some game ad application there aren't audio at all.
    When i set improvment with ambient check i hear all speakers, but in this case in some game and application the sound is off and can't hear anything
    Thanks
    Lorenzo Farina
    Windows 8.1 64x
    Some idea ?
    Disable DTS. See if this fixes the problem.
    Windows 8.1 64x
    How can i disable dts (there isn't in program install/uninstall)
    I try to uninstall (reboot) and install newest driver realtek (and reboot), but the problem remain
    When i try to uninstall the real tek drivers dts disappears, but when i reinstall drivers dts it's again in notification area
    Check the startup (msconfig) and see it is there. That is an enhancement to the basic sound (Realtek).
    This may not be the problem, but one item to consider.
    Windows 8.1 64x
    Ok i find it and disable, but problem remains.
    Windows 8.1 64x
    It is not hardware problem
    If I read correctly, it works properly when testing? That means the program(s) are where the problem is.
    Windows 8.1 64x
    Yes But in DTS the test clicking on speaker doesn't works.
    Now i install another pannel control test works correct
    But when i enable sound effect the test on control panel doesn't works; and in some game there aren't sound at all.
    When i enable sound effect with ambient set on generic the sound of windows works on all speakers 5.1.
    Windows 8.1 64x
    If you want I can put a word (in images) in English for a better understanding.
Page 1 of 2 12 LastLast
Source: You can now hear Bing's homepage | Search Blog
Solved Cannot record what I hear in Sound & Audio
Hi All, Last year I had a problem with a high definition audio device, posted here. https://www.eightforums.com/sound-audio/52453-hd-audio-device-not-working.html Now I have the same issue again, but this time I cannot record what I hear and there is no Stereo MIx in Recording Devices. I...
Hi everyone. Im newbie on this forum and ive bad english for this sory. Ive Asus P8Z64-V Pro motherboard and i cant get sound from the rear speakers in 5.1 surround sound if and when install a new version software/driver cauze its only supports side speakers in 5.1 surround sound. If i dont install...
so i can turn up audio and watch videos but i cant hear audio in my edit software so i know whats the problame but i dont know how to solve it take a look at this pic57997 srry that it is in dutch it basicly means there are no audio istalled and srry for my bad english i hope someone responds soon...
Solved Rear usb ports non responsive in Drivers & Hardware
HI, I have problem that just crept up, my rear usb ports are malfunctioning. when I plug my mouse in the light underneath it comes on, but the mouse is not operational. The keyboards numlock light doesn't even go on. My front ports are working now, but this is greatly inconveniencing me...
rear speakers not working in Sound & Audio
all plugged in new computer drivers up to date set to quadraphonic they were working yesterday but they appear to have stopped on their own. the test speaker option worked at first but now they dont when i click the speaker icon to test on the sound playback options tab the level indicator...
More...
