noise like no ground
    MD
    Windows 10 Pro x 64
    hello
    I have Bose speakers with my Dell XPS 8300 and run Win 10 Pro.
    I have noticed that since I got my speakers a couple of years ago, when I plug them into the PC or nudge the wire to the port I get a buzz or hum as though the card or the speaker is not grounded. I have run diagnostics but nothing shows up.
    It only occurs when I touch the wire to the port or plug or unplug it. Once seated it is OK.
    TY for your opinion
    Peter
    P.S. I just noticed that I am in the Win 8 not 10 forum and am sorry for the error.
    N. Calif
    W10 Pro (desktop), W10 (laptop), W10 Pro (tablet), W10 (laptop)
    Unless I misunderstood your post, it seems that you have found the solution, "Once seated it is OK." To me that implies that you have found that when the plug is properly inserted and seated, the ground does it's job and your issue is solved. Am I misunderstanding what you said?
    MD
    Windows 10 Pro x 64
    I think you have it right. If I ever hold the tip of the wire that goes into the port or touch anything with it, it makes that noise until and unless I seat it within the port.
    I assume you are implying that is normal.
    Thank you for your advice
Whenever I start playing a game, no matter what game, I get weird buzzing feedback from my headphones or speakers, depends on what I use when I play. They both make the same noise at the same places (certain menus, while in-game, etc). I also can't make my built in mic on my earphones to work. I...
Solved strange noise from PC in Drivers & Hardware
About 2 days ago i opened PC case to do my regular maintenance of dusting inside. Usually use Compressed air. Have 2 case fans (1) 92mm (1) 80mm plus the CPU Cooler fan, my Graphics card has dual fans. Just other day and this only happens when i am booting the PC, i hear what sounds like and...
Bad noise on quite new laptop. in Drivers & Hardware
Hi, I hope somebody can give me an opinion from his experience. This laptop is 4 months old, Asus X501A. I had to return another one to Amazon because it made some bad clicking noises and the hard disk was faulty as Hard Disk Sentinel said it was with 68% health new. So, this laptop model might...
Irritating buzzing noise in Drivers & Hardware
Seem to be plagued with problems at the moment. Have just fixed one and now the Sandy Bridge is making a fairly loud buzzing noise a bit like a doorbell being pushed. It is fairly intermittent and the sound lasts for a few seconds or for a minute or so. It doesn't seem to be related to anything I...
HDD locking noise? in Drivers & Hardware
I've recently just updated my BIOS on my asus laptop to fix my "ACPI.sys" problem but now, whenever I plug an external USB drive in, or do a hybrid shutdown my hard drive makes 2 loud-ish locking kinda noise (similar to when I turn on my laptop), i'm guessing its the HDD head parking... Should I be...
