Audio Stuttering
    Audio Stuttering
    Hey guys this is really annoying me, whenever I am playing any video and/or audio file with any browser open and loading pages the audio stutters extremely badly, I use Chrome but also does it in Cyberfox, the players I have tried are VLC, Media Player Classic, Windows Media Player, Foobar 2000, Janngle, plus a few others.
    It is driving me nuts as I can't listen or watch vids while browsing sites. Chrome use 100% of CPU on startup which to me is strange.
    My PC stats are in my sig.
    Sounds like the shared IRQ (Interrupt) that the sound is on could be causing it. Sound is always on a shared IRQ and Sound is the lower priority of the two and thus can get interrupted.
    If you uninstall the sound in the Device Manager (BUT DO NOT uninstall the drivers) then restart the PC, when Windows starts it will reinstall the sound and sometimes will put it on a different shared IRQ and help minimize interruptions.
    Thanks will try that later.
    Cheers mate, seemed to have worked great, watching music clips and listening to songs without stuttering!
Audio Stuttering
Solved stuttering mouse and lag help in Performance & Maintenance
So i have done everything i can think of to fix this even re-installing mouse software, but for some reason not all the time i will get mouse lag and stutter were i will move the mouse but the pointer barely moves on my screen, is there a fix for this? someone help please.
Audio/Visual Stuttering in Sound & Audio
I have been experiencing stuttering both audio and video. This occurs after the computer has been running for two days (hibernating at night). For the first day it works perfectly, youtube, MPC, etc work flawlessly. Then towards the end of the second day, stuttering, with no apparent cause. ...
Hi, I'm Locky, I am usually a pretty competent computer user, and have never had to post on a forum for help, but I am by no means skilled, thus I came here seeking help. I'll give you as much detail as I can, I am very much in need of help. I have been experiencing a problem the last few...
Hello, When I watch youtube videos, or videos in Windows Media Player Classic my audio randomly stutters. This also causes my mouse to stutter and skip and move slowly. I have tried to fix this issue for awhile. However still no solution. Any ideas or tips would be great, Thanks
Video, Audio and mouse skipping or stuttering in Performance & Maintenance
Hey guys, I just did a fresh install of windows 8 on my system. Specs are Win 8 intel 3570k 8 gig 1600mhz ram Asus p8z77 - pro
Video app stuttering in Software and Apps
Hi all I have windows 8 pro and when I use the video app and begin playback the video stutters very badly. I see about 1 frame every 5 seconds. The audio works fine. Then after about a minute the video clears up and everything plays perfectly. I can play the same videos in windows media player and...
after about 10 to 20 minutes of use the whole computer begins to stutter, audio video... the mouse skips around and it is almost unusable just upgraded from 7 ultimate to 8 pro, and ive included the diagnostics what in the world is causing this?
